Rear Disc's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Streaking10 Taco, Oct 18, 2012.
  1. Oct 19, 2012 at 9:39 AM
    The Phoenix
    The Phoenix Member
    Rocky
    Tonka
    Also, this should be considered with respect to my statements regarding wild variations in load. In the case of a semi, that could be as much as 80,000 pounds distributed across 4 axles -- two on the rear of the tractor, two on the rear of the trailer.
    Hey wait... did you just call me the devil?
  2. Oct 19, 2012 at 9:56 AM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    See, I told you these threads always get town apart by some guy stating drum brakes are better.
    The discussion was which Toyota models share the same basic rear brake design, but offer disc brakes. With the intention of performing a low dollar rear disc conversion.
  3. Oct 19, 2012 at 10:11 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Many class 8 trucks are going to discs believe it or not. FWIW
    and I know FAR too much about the damn systems while barely scratching the surface :frusty:
  4. Oct 19, 2012 at 10:16 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    The Phoenix [​IMG]
    Banned
    Gender: Male
    Well that was quick.
  5. Oct 19, 2012 at 10:19 AM
    MikeyLikesIt
    Based on his posts just in this thread, I was wondering if he was some member who was once banned before and just came back with a changed name. I know I wasn't dropping posts like that until I got to know this forum and my truck a little better.
  6. Oct 19, 2012 at 10:21 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ^Yep. Not a doubt in my mind.
  7. Oct 19, 2012 at 10:21 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  8. Oct 19, 2012 at 10:25 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  9. Oct 19, 2012 at 10:39 AM
    badger
    badger Well-Known Member
    07 SR5
    I know this is not a "which is better" thread, so I won't belabor it. I have built a few brake systems for vehicles from scratch and typically the rear axles in question came originally equipped with drums. The question of the disk brake conversion was there. Except in instances where the brakes had to endure long application or braking from extreme high speed, the benefit on the rear just wasn't there. The disks do have the advantage in resisting brake fade and that is what makes them so valualble in the front where braking force is very high. In fact all the disk/drum systems involved the use of a proportioning valve to dial down the braking in the rear to prevent lockup. More braking efficiency would have just meant a lower setting on the valve.
    In high performance applications like sports cars, a major factor to consider is unsprung weight. It's especially important on light vehicles with independent suspension. The decision to use disks on performance cars with 4 wheel independent suspension is largely driven by that. On a heavy solid axle, the added weight of the drum is less important.
    The need for a disk is design criteria specific, and you can't compare apples to oranges.
    Sorry if I interrupted :rolleyes:
  10. Oct 19, 2012 at 10:43 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Avoid this kit like the plague.
  11. Oct 19, 2012 at 10:46 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ^Was patiently waiting for you to post. :D
  12. Oct 19, 2012 at 11:02 AM
    mjp2
    NJ
    lol I was just spectating for a bit. :p
    On the bright side, at least Tundra Racing realized that its kit's parking brake it 100% useless and went with a more stout solution for those willing to shell out the cash. I hadn't seen this one before:
    That said, the stock master cylinder can only flow so much fluid. Something designed to flow for drum brake wheel cylinders is gonna have a crap time trying to keep up with the volume requirements of disc brake calipers.
  13. Oct 19, 2012 at 11:05 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    :quickdraw:
  14. Oct 19, 2012 at 11:07 AM
    mjp2
    NJ
  15. Oct 19, 2012 at 11:49 AM
    #35
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Perhaps you missed the part where I linked 5 threads on the subject on the first page...
  16. Oct 19, 2012 at 11:50 AM
    #36
    justinh
    justinh Well-Known Member
    Canton, GA
    2009 Tacoma TRD Offroad 4x4
    There is a shop on Pirate now that is offering a similar kit, brackets, brake hoses, etc. It's only about $100. :) I was able to source my stock 4runner components (calipers and rotors) for under $100.
    They haven't come out with a parking brake kit YET though. They are waiting on some legal stuff for that supposedly.
  17. Oct 19, 2012 at 11:53 AM
    #37
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    xrunner.jpg Sorry this was the only picture i had. I deleted the rear brake picture by mistake. SOS Performance did their homework on the rear disc conversion and bbk. Brake system worked BETTER than stock PERIOD ( also had steel braided lines f&r )! No mushy this or that. I Know cause I had them for at least 3yrs. NO COMPLAINTS .
    If you wanna do it. Than do it. Nothing to worry about.:D
  18. Oct 19, 2012 at 11:56 AM
    #38
    MikeyLikesIt
    Link??!!
  19. Oct 19, 2012 at 12:04 PM
    #39
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    It's for 5 lugs only, not sure if that matters to you or not.
    More importantly, I'm pretty sure SOS shut their doors a few years ago.
  20. Oct 19, 2012 at 4:55 PM
    #40
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    All of our cop cars had rear disks (both Ford and Chevy) they stopped fine and probably were a good thing on a cop car but they were a maintenance nightmare with hanging parking brake systems, sticking calipers and rotor issues.
