Rear door latch malfunction
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bburnsman, Jul 12, 2020.
  1. Apr 1, 2024 at 10:48 AM
    umpire3
    umpire3 Well-Known Member
    Robert
    2004 Tacoma 4-door, V6
    4xdog likes this.
  2. Apr 1, 2024 at 1:57 PM
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    My 04 doing the same.
    FWIW I think the number posted above was for the left side. I think the right side is 69305-04020.
    Not cheap...
  3. Apr 22, 2024 at 9:32 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I think we might be talking about two parts in this thread. The door "latch handle" and the door "latch mechanism", let's call them.
    Changing the door latch handle -- the thing one lifts on the outside -- is indeed pretty easy. Changing the latch mechanism -- the thing that grabs onto the door frame to hold it closed -- is a helluva lot more complicated. I have my 2003's right rear door mostly apart, and I'm starting to believe that the window glass, regulator and its associated runs will indeed need to come off to change the latch mechanism.
    The mechanism has a sort of plastic bushing around the hook that grabs the post on the door frame, and that bushing gets worn out over time, apparently. Mine has worn or otherwise been shaved down to fragments. This lets that hook fall down and prevent the door from latching when it's closed. The hook can usually be lifted with a finger and then the door closed as normal. But that's a pain.
    Has anybody replaced a rear door latch mechanism on their Gen 1 double cab? Fingers crossed someone can chime in with some practical guidance!
    :fingerscrossed:
  4. Apr 23, 2024 at 10:35 AM
    umpire3
    Robert
    I've changed the LR and LF latch mechanism on my '04 D-Cab. The only difficulty I had was the last link to the lock on LF mechanism. Reviewing the video (https://www.youtube.com/watch?v=78yoVyTRUHU&t=930s from the begining) built confidence in me to complete the job.
    4xdog likes this.
  5. Apr 24, 2024 at 7:15 AM
    4xdog
    Santa Fe, NM
    Thanks, @umpire3. Do you remember how much you had to take apart to remove the rear latch mechanism? Did the window have to be taken out? Maybe just the window frame mounted inside the door panel?
    (Timmy's video, which is as helpful as always for his work and very useful for the front doors, didn't get into the rear door enough to give me specific guidance and it's not clear how much is the same between the front and rear).
  6. Apr 25, 2024 at 9:16 AM
    umpire3
    Robert
    I mostly followed the two videos (seen in post #19 and #24). No window frame was removed from the rear door. However, the front window guide was removed (see post #24 at the 11:52).
    4xdog likes this.
  7. May 10, 2024 at 9:59 AM
    umpire3
    Robert
    @4xdog, were you able to replace the door latch without any problems?
  8. May 12, 2024 at 6:52 PM
    4xdog
    Santa Fe, NM
    Not replaced yet. Too many other things going on to dig into it. It may be delayed until I complete a move to New Mexico over the summer, but I will update this thread with pix, etc., when I get into it.
    Madjik_Man likes this.
  9. Aug 29, 2024 at 8:15 AM
    mjhenks
    So.Cal
    @umpire3. Your post above suggests there are aftermarket sources for the latch but may also been talking about the door clips. Can you clarify please? I am finding second hand latches are almost as much as OEM in So. Cal. Might as well get new unless there is an aftermarket alternative. (I am looking for the rear passenger latch)
    Thank you.
  10. Aug 29, 2024 at 2:21 PM
    umpire3
    Robert
  11. Aug 31, 2024 at 1:57 PM
    AW11
    AW11 Well-Known Member
    Frank
    2002 Dbl Cab 4x4 3.4l
    My rear drivers side door does makes a clicking sound and is difficult to close. I wonder why it’s mostly this side that has the issue?
  12. Sep 14, 2024 at 5:09 PM
    augoose
    augoose New Member
    '01 Tacoma quad cab
    So the two door latches referenced in this thread, passenger 69305-04020 and driver 69306-04020, most definitely DO NOT fit either of the rear doors on a 2001 Tacoma quad cab. Maybe I'm a bit stooopid but I read the two pages of threads here several times and a few posts seemed to suggest that these two parts would fit the rear doors - well I ordered them and after going through the effort to remove one of the latch assemblies, they most definitely do not fit.
  13. Nov 15, 2024 at 11:16 AM
    whizbo
    whizbo New Member
    A little late now I'm sure, but...
    @augoose - Does your 2001 Tacoma have power locks? It looks like gen 1 Tacoma uses different units for powered vs. non-powered.
    Right Rear according to what I'm finding.
    -Powered -> 69305-04020
    -Non-powered ->69330-04010
    Left Rear
    -Powered -> 69306-04020
    -Non-powered ->69340-04010
  14. Nov 18, 2024 at 4:20 AM
    augoose
    augoose New Member
    '01 Tacoma quad cab
    I do have powered locks, maybe that explains it. Thanks for posting the part numbers, I'll take a closer look!
