rear drive shaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dodgeram293, Mar 28, 2009.
  1. Mar 28, 2009 at 8:32 PM
    dodgeram293
    dodgeram293 [OP] Member
    montague nj
    2006 base 4+4 maroon
    hi any one had rear drive shaft wear out with only 35000 miles on truck .reg cab base 2inch lift with add leaf .silp shaft worn out toyota will not warreny it because lift.noise drive me nuts .pack with graese for now quieter .
  2. Mar 28, 2009 at 9:57 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Take out the AAL and take it to another dealer.
    That's BS that your AAL caused the issue. If you did the rear TSB it would end up the same height as you AAL.
    The dealer is just trying to screw you!
  3. Mar 29, 2009 at 6:18 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    A dealer can deny a claim for certain reasons & the warranty claim book lists those but to say your extra leaf caused it is bogus, as toku said I would try another dealer or call the customer service # & open up a claim, especially that close to your warranty running out.
    Also maybe someone will chime in who has experience with warranty work with a lift. There was some legal case where they have to prove your mods caused the problem or something. Best of luck don't give up Here's a bump for more info :thumbsup:
  4. Mar 29, 2009 at 6:23 AM
    Butler_Geek
    Butler_Geek Well-Known Member
    Berdo Mountains
    upyrs
    Wondering how a drive shaft can wear out? Are you saying a u-joint is going bad?
  5. Mar 29, 2009 at 7:00 AM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    A regular cab is not eligible for the TSB....correct?
  6. Mar 29, 2009 at 7:18 AM
    Butler_Geek
    Berdo Mountains
    upyrs
    he also said he was packing it with grease, the only thing you would grease is the u-joint. so are the splines on the tailshaft wearing or inside the yoke?
  7. Mar 29, 2009 at 7:21 AM
    TicTacOma
    Columbia,SC
    You can separate the shafts and pack it that way. He said slip shaft.
    They are probably denying it because of the angle caused by the lift. They may say it stepped-up the wear.
  8. Mar 29, 2009 at 8:56 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How did the slip shaft wear out? That's really unusual. They don't normally go bad unless they're never lubricated (rusted together) or bent up somehow...
  9. Mar 29, 2009 at 12:21 PM
    dodgeram293
    montague nj
    the slip shaft was some what dry . moves up and down 1/2 inch.thats why i packed it with graese.the teflon on splines worn ,wear in yoke .i chrysler tech i have not seen this.the slip shaft is not out to far.i just bought it 1 month ago .no sign of truck being beat.angle on driveshaft not bad .no binding .i do not give custmor problem with warrenty like this .last month i had a 2008 2500 dodge ram deisel pushing 500 horse .clutch went out i replaced it. but told last time .he needs after market clutch .on full boost in 4th truck went side ways down road .i was cool about warnty .
  10. Mar 29, 2009 at 2:03 PM
    TicTacOma
    Columbia,SC
    It would be so nice if people would hit the "preview post" before they hit the "submit post" and proof read what it is they are trying to say.
    Is the driveshaft in question yours? Is it a new driveshaft or a rebuilt driveshaft? Did you by the truck only a month ago or the driveshaft a month ago?. If only the driveshaft, why is it not the original driveshaft?
    We'll wait....
  11. Mar 29, 2009 at 6:53 PM
    dodgeram293
    montague nj
    i bought the truck a month ago.the driveshaft is original .
  12. Mar 30, 2009 at 3:23 AM
    TicTacOma
    Columbia,SC
    Understood....
