Rear E-Lock Diff Light indicator
Discussion in '1st Gen. Tacomas (1995-2004)' started by TROKITA, Dec 22, 2011.
  1. Nov 2, 2016 at 5:10 PM
    Rmartin517
    Rmartin517 Well-Known Member
    Robert
    Texas
    2001 4 door Tacoma limited trd
    Supercharger, 6" fab tech, 20" moto metal wheels, 34" Nitto trail grapplers
    Well now I started playing with t a little more and the light is staying on. Just did the grey wire mod to.
  2. Dec 20, 2016 at 8:46 PM
    Skawdee
    Skawdee SKOL Vikings!
    Star Valley, Wyoming
    2009 Tacoma TRD-Offroad, 6-spd Man.
    Old Man Emu 2.5” Full Suspension Lift w/ Wheeler's Off-Road Progressive Leaf Pack JBA Upper Control Arms Moog Lower Control Arms Victory4x4 Strike Front Bumper w/ Grill Tubing Morimoto XB Headlights Baja Designs Squadron Sport Amber Fog LED’s Baja Designs 20” White LED Light Bar Over-sized BFG All-Terrain Tires K&N Stock Replacement Air Filter Pioneer AVIC-W8400 Head Unit Apple TV Wireless Phone Charging Pad Bed rail mounting with ax, shovel, MaxTrax Bed Extender
    I'm also having the RR Diff Lock issue of when I have it in L4 and press the button it flashes. I do hear a click that is coming from near the glove box on the passenger side as I press it in and then a single click again when I depress the rear locking differential button. However I do not hear anything coming from underneath the truck like other people are. However, I do hear the electronics and gears doing their thing underneath the truck when I go from H2 to H4 modes. While the differential lock is engaged, I roll forward and in reverse in a straight line while also trying a full left and right turns, both forward and reverse and still can't get it to engage. I am guessing that my actuator has frozen like others have. When it's not freezing balls outside I will have to investigate that on my truck.
  3. Mar 6, 2018 at 7:07 AM
    MoonKnight
    MoonKnight Well-Known Member
    chris
    Oromocto New Brunswick
    2018 silver Tacoma TRD or
    old thread but i just recently bought mine its a 2011 off road my locker light just flashes at me i can hear it making sounds, sounds like its engaging but the light still flashes
    i dropped the spare tire today and pulled the 2 pin connector and whipped it off with a rage but still the light still flashing
    i was gonna take it off road today to test to see if its really working , but with out a winch and recovery equipment or someone to tag along i wanna wait out (friend i message isn't replying to come out and play i think he's being a wuss)
  4. Mar 7, 2018 at 5:30 AM
    Taco crazy
    Taco crazy Well-Known Member
    Chattanooga TN
    '97 Tacoma std cab V-6
    Locked front and rear, bumpers, sliders, cage etc..33" Cooper STT PRO's. Mild suspension lift.
    Were you in 4-lo?
  5. Mar 7, 2018 at 1:18 PM
    MoonKnight
    chris
    Yeah I was I figure it’s just the light the locker seems to work
    Did a few test
  6. Mar 8, 2018 at 5:18 AM
    Taco crazy
    Chattanooga TN
    I'd have to look at my '15 but my 1st gen has a plunger type switch on top of the axle housing that indicates the position of the internal fork. Basically put, when the locker is engaged the sliding fork contacts the switches' plunger, pushing it up, completing the circuit to illuminate the 'Diff Lock' light. I've had to remove mine more than once to clean the 'crud' out of it, basically a film of gear oil residue preventing the smooth movement of the plunger.
  7. Mar 8, 2018 at 9:27 AM
    MoonKnight
    chris
    On my 11 it’s just a 2 pin connector I took it off and whipped it with a rag but it’s still blinking
  8. Mar 9, 2018 at 7:06 AM
    Taco crazy
    Chattanooga TN
    So the switch the connector plugs in to is not removable? The switch the harness plugs in to should thread in to the axle housing. Remove that switch and clean internally.
  9. Mar 12, 2018 at 5:18 AM
    MoonKnight
    chris
    Ill take another look when I relocate my diff breather
