Rear End Clunking getting worse and cant find it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bassbasset, Jan 26, 2017.
  1. Jan 26, 2017 at 1:44 PM
    bassbasset
    bassbasset [OP] Member
    DJ
    Santa Rosa, Ca
    2010 TRD Sport
    Just paid her off, about to start the mods
    Hello all,
    So i am at a complete loss now. I have a clunk when i go over bumps, potholes, speed humps and so on coming from the rear end. Put it up on a rack pounded and shook all sorts of things. Replaced Center support bearing, had my U-joints removed cleaned and repacked. I have crawled under and torqued every bolt i can get on to. Added rubber insulation tape to noisy areas on my fenders and so on. I still have this clunk that is continually getting worse. I have newer procomp shocks on there and have pushed and pulled on them and found no problems. I am thinking of just biting the bullet and replacing those also to see if it is them. Looking for other ideas that i can look at. Any help out there?
    DJ
  2. Jan 26, 2017 at 3:27 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Check your spare tire. It's good to drop it and lube the cable and winch once in a while anyway.
    tirediron likes this.
  3. Jan 26, 2017 at 3:49 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Broken leaf?
  4. Jan 26, 2017 at 5:14 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Seriously, ya got a drawbar in your hitch? Mine makes all sorts of noises unless I wrap it with duct tape every now and then.
  5. Jan 26, 2017 at 5:45 PM
    bassbasset
    DJ
    Santa Rosa, Ca
    2010 TRD Sport
    @ toy4me alre4ady tried that. Pulled the spare, ran a few days with the cable pulled up without it.
    @ jeffch looked at both, they are good
    @08TacoTrD Pulled my hitch and it was still there also
  6. Jan 26, 2017 at 6:49 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    What's your rear suspension setup?
  7. Jan 26, 2017 at 8:15 PM
    bassbasset
    DJ
    Santa Rosa, Ca
    2010 TRD Sport
    @jtweezy all original except for procomp shocks
  8. Jan 26, 2017 at 8:28 PM
    gearcruncher
    Canadain bumper technician
  9. Jan 26, 2017 at 10:09 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    x2^ see if you can lift your bed on the passenger side, or any side for that matter but some peoples bed bolt came loose and got 1/4'' or more of play.
  10. Jan 26, 2017 at 11:01 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    i just discovered i have a loose passenger side bed mount last weekend... definitely check that out!
    Larzzzz likes this.
  11. Jan 27, 2017 at 4:46 PM
    2nd screen name
    2nd screen name Tacodelaplaya
    Bob
    LV/SD
    06 AC Sport Prerunner
    Front: Maxtrac, DK heim UCA, 6112 Rear: AP expos, Fox 2.5 RR DSC Fn fivestar with General reds
    make sure your u bolts are tight. i have an allpro flip kit and mine came loose and made wierd clanging noises. thought it was the spare tire thing the whole time.
  12. Jan 30, 2017 at 8:04 AM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Ok. I was going to suggest leaf spring bushings, but if you're on stock leaf springs then that shouldn't be a problem. Wouldn't hurt to check side-to-side play where the leaf springs mount anyway...if you can't track down the noise.
    Spare tire has also gotten me with a mysterious clunk. Lower it and raise it back up tight just to be sure.
  13. Feb 3, 2017 at 7:03 PM
    bassbasset
    DJ
    Santa Rosa, Ca
    2010 TRD Sport
    so, i replaced the procomos with bilstein 5100s and the sound is gone. no clear sign of it being blown, but when i tap it on the ground i can hear something loose inside.
  14. Feb 4, 2017 at 1:30 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Glad you found it and also posted for us !
  15. Oct 7, 2022 at 12:31 PM
    Sakisipper
    Sakisipper New Member
    C2
    2021 Tacoma TRD/Offroad
    Had a clunking sound in the rear going over bumps on my 2021 TRD Off Road. I thought it was the spare tire chain. I secured the chain and still had the noise. Found it today after more than a year . I had my wife bounce up and down on the rear bumper. I found that the noise was coming from the driver side rear leaf spring. I jacked up the rear end by putting a floor jack under the hitch and lifted it by about 3". That opened the bottom leaf spring a bit. I then cut a piece of 1 1/4" by 2 1/4" of "3/8" hard black rubber and inserted into the lower leaf opening. I let the jack down. No more noise. Hope this helps.
  16. Mar 2, 2024 at 8:17 AM
    NBTACO22
    NBTACO22 New Member
    22 taco off road
    I just had my rear right shock replaced under warranty when I heard the same knocking noise, two weeks after the fix the noise has started to come back. I have not checked the spare tire, bed bolt, or leaf springs but that will be my next mission. Once I look it over I will repost.
    2022 Tacoma Off-Road
