rear end harsh bounce and sway
Discussion in '2nd Gen. Tacomas (2005-2015)' started by outlawtacoma, Jul 8, 2010.
  1. Jul 8, 2010 at 7:54 AM
    outlawtacoma
    outlawtacoma [OP] Well-Known Member
    W. TN
    2018 T4R TRDOR Premium. ‘01 Tacoma Xtra Cab 4x4
    do any of you have a real harsh bounce and/or sway from the rear end when going over a bump or a hole?
    I have the leaf TSB done, got it done last year. Here as of late tho, my ride has been rough to say the least coming from the back, just curious to see if Im the only one.
    yes I am aware its a truck, and I use it as such.
  2. Jul 8, 2010 at 8:13 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I hated the way my truck rode in the rear. it seemed to be super stiff and it drove me crazy. I didnt have the TSB done but I did have a single AAL.
    I switched to a 3 AAL set from Wheelers and its so much better now
  3. Jul 8, 2010 at 8:20 AM
    outlawtacoma
    W. TN
    Thanks bro, I will look into that and some rear 5100s for good measure. gotta wait on some $
  4. Jul 8, 2010 at 8:22 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    :) you will loose a little towing capacity b/c you remove the overload leaf with this setup. But since I dont tow anything it wasnt a factor for me.
  5. Jul 8, 2010 at 8:27 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you checked your tire pressure lately?
    Just a thought.....
  6. Jul 8, 2010 at 8:28 AM
    outlawtacoma
    W. TN
    Keason, i need that extra leaf for towing too.
    Janster, yes. it does it regardless of pressure. 28psi-38psi. same hop and sway.
  7. Jul 8, 2010 at 8:28 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    ^^thats a thought. I went in for an oil change and noticed they aired my tires up to like 60 something PSI!!!!
  8. Jul 8, 2010 at 8:30 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    maybe try the 3 leaf pack and some firestone bags for when you tow? that would be a little pricey but not any more than a new leaf pack
  9. Jul 8, 2010 at 11:59 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Check if one of your rims are bent. My truck was behaving like that a couple weeks ago but it was a bent axle shaft.
  10. Jul 8, 2010 at 12:07 PM
    outlawtacoma
    W. TN
    Rims are good, just checked them a couple months ago. Axle shaft!? damn
  11. Jul 8, 2010 at 12:13 PM
    Asgard
    ^^Yea, met in a minor fender bender where the guy hit my back tire but no visible damage to the truck. His tire and rim was busted so I paid him on the spot for that (I was wrong). Next day driving through the mountains every left turn my tires would scream and going over bumps the rear end would sway and bounce around. Put it on the ramp and saw my right wheel wobbling, I was hoping it was just a bent rim but it turned out to be a bent axle and housing ! Stupid me I should of dealt with it correctly (insurance etc.).
  12. Jul 8, 2010 at 12:17 PM
    outlawtacoma
    W. TN
    dang bro. I am pretty sure mine is from the TSB. its not a big deal, it just seems that it has gotten more rough over the past few months.
    Im not worried about it. Im gonna keep on keeping on
  13. Jul 8, 2010 at 12:21 PM
    Asgard
    ^^I got an axle shaft and diff housing from a wrecked 4x4 Sport at a local junk yard for cheap, so for those wondering the 4x4 and PreRunner axle shafts are the same.
