Rear end leaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Emmetjmcc4, Dec 16, 2019.
  1. Dec 16, 2019 at 8:06 PM
    #41
    tbrown6145
    tbrown6145 Member
    Tyler
    Taco
    Stock
    You can buy a weld on diff cover.
    eon_blue likes this.
  2. Dec 16, 2019 at 8:08 PM
    #42
    eon_blue
    Azusa, CA
    Trail Gear sells a weld on diff cover for our diffs iirc. To be used as added protection but in this case it would work to reinforce his rusted diff
  3. Dec 16, 2019 at 8:16 PM
    #43
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It will be easier to repair the 3rd member than try to weld an entire cover over it.
    I don't think we are all on the same page.
    Wyoming09 likes this.
  4. Dec 16, 2019 at 8:23 PM
    #44
    tbrown6145
    tbrown6145 Member
    Tyler
    Taco
    Stock
    Maybe this will help.
    https://youtu.be/CO8ROcJl3jY
  5. Dec 16, 2019 at 8:26 PM
    #45
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I believe someone here has cut their cover out and welded this one in. Shoot I can't think of who it was but I remember a thread with this scenario
  6. Dec 17, 2019 at 1:02 AM
    #46
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    All it takes is some good paint and then keep a eye on things every spring to keep this from happening.
    I gotta say clean things good look for the right epoxy which has gotten so much better in the last 20 years.
    OP really does not want to weld I can understand. Besides welding would mean removing brake lines which would be even more work to the project replacing them and then you have the whole cascade effect
    Because it is winter your going to have to warm things up unless you have a radiant heat garage.
    Any vehicle you find down South is going to need major prep work before the first winter I got one from Texas and one from Alabama .
    What is normal rust for in the North is the end of the World for those brave people just waiting to slide into the Ocean or so I was taught in school
    mechanicjon and tbrown6145 like this.
  7. Dec 17, 2019 at 3:41 AM
    #47
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You cut the diff cover off and weld a new one on.
    koditten[QUOTED] likes this.
  8. Dec 17, 2019 at 3:50 AM
    #48
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  9. Dec 17, 2019 at 3:58 AM
    #49
    tbrown6145
    tbrown6145 Member
    Tyler
    Taco
    Stock
  10. Dec 17, 2019 at 2:12 PM
    #50
    Emmetjmcc4
    Emmetjmcc4 [OP] Well-Known Member
    Emmet
    Michigan
    2002 Tacoma 4x4 270k, 1995 Tacoma 4x4 353k RIP
    American Racing 15x8 -19 off. Cooper Discoverer stt pro 31x10.5r15 Allpro baja tube bumper Fox racing 2.0 all around
    Well I checked the diff breather first and it was so caked it shit I couldn't move the cap but once I got it to wiggle it came off, looks like the previous owner clamped it back on with pliers. Is it an issue if there is no cap on the breather? I also cleaned the shit out of the rear diff with brake cleaner and with closer inspection it looks like he sprayed some kind of rhino liner on it so I'm assuming there was rust holes in it and that was his fix but I cleaned it best I could and drove it a little with no diff breather cap on and couldn't see where it had leaked more. I will check again a little later.
    cruiserguy, GQ7227 and frenchee like this.
  11. Dec 17, 2019 at 2:24 PM
    #51
    Wyoming09
    New Tripoli Pa
    Super Springs
    It will clog up with dirt and build pressure in a few days if that long
  12. Dec 17, 2019 at 2:40 PM
    #52
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Bondo baby :rockband:
  13. Dec 17, 2019 at 3:51 PM
    #53
    cruiserguy
    Elijah
    SEKS
    Yeah you should keep some type of breather on it. Don't need any crap getting into the third member or axle housing. Might be easier and cheaper to just extend the breather with some vacuum hose, etc. Can search and find posts here in TW for extending the diff breather. It's easy to do. Run it up to someplace where it won't get all caked up with mud and salt and debris and shiz
  14. Dec 17, 2019 at 4:49 PM
    #54
    Emmetjmcc4
    Emmet
    Michigan
    Even if I'm on mostly pavement with this truck you think it'll still get caked? And if I didn't see anything leak out after I took that cap off and cleaned around it do you suppose it was just the breather being clogged?
  15. Dec 17, 2019 at 4:50 PM
    #55
    Emmetjmcc4
    Emmet
    Michigan
    Holy shit I can't wait to get rid of this truck :annoyed:
    To go find a different one that I want to give love and care to.
    koditten likes this.
  16. Dec 17, 2019 at 4:51 PM
    #56
    eon_blue
    Azusa, CA
    don't need to extend it if you only drive on pavement but you do want to make sure it doesn't get clogged...if it gets clogged up the pressure inside the diff will cause the oil to force itself out through the axle seals (or in your case, the cracks in your diff housing).
    cruiserguy likes this.
  17. Dec 17, 2019 at 4:54 PM
    #57
    Emmetjmcc4
    Emmet
    Michigan
    Okay, so should I just clamp that cap back on with pliers like the previous pos did to get me by instead of running without one?
  18. Dec 17, 2019 at 4:56 PM
    #58
    cruiserguy
    Elijah
    SEKS
    Yeah if that breather will still function correctly, definitely reuse it. But yeah something should be there. Especially in winter. Especially anytime.
  19. Dec 18, 2019 at 3:37 AM
    #59
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I got a spare breather. If you want it, pm me your address.
    frenchee likes this.
  20. Dec 18, 2019 at 11:04 AM
    #60
    GQ7227
    GQ7227 mw survivor
    J A Y
    sloppy winter roadspray getting kicked back up under there should probably be the only concern on caking the breather on mostly pavement
