Rear end noise when braking??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rzimm001, Mar 14, 2011.
  1. Mar 14, 2011 at 9:49 PM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I've developed this noise on my 2wd prerunner. It sounds like it's coming from the axle and only occurs when I apply the brakes over broken pavement or dirt. It appears to be a result of the rear tires intermittently getting traction. It's a metal clanking/shifting sound that sounds very similar too say your u-bolts were loose or maybe you left your hitch in over a bump. Thing is i've checked all the bolts, hitch is out, and everything seems tight, even the spare tire. I could hit some nasty little washboard road and never hear the sound until I brake. It's seperate from the front brake pad clank. Whatcha think? Axle wrap? Something loose in the rear drums?:confused:
    Only relevant mods are add a leaf, rims, tires.
  2. Mar 14, 2011 at 10:10 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Try and adjust your rear brakes. Mine has done something similar before, and the sound disappeared with a rear brake adjustment.
