Rear End Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jackal419, Dec 22, 2009.
  1. Dec 22, 2009 at 11:59 AM
    jackal419
    jackal419 [OP] Active Member
    Colorado
    06 SR5
    Lightforce Lights, Softtopper Bed cover, TRD CAI
    Been using my 4 wheel drive all weekend to get around in the snow that the east coast is experiencing. Now I'm getting a pretty significant noise whenever I move forward and backward. It basically turns into a clicking while moving quickly, but when crawling to diagnose it makes noise every ~3 ft. Not really sure whats going on back there, any ideas?
  2. Dec 22, 2009 at 12:26 PM
    sibanez
    sibanez Well-Known Member
    Camp Hill, PA & New Orleans, LA
    2002 4x4 SR5 XCab
    Leer camper Thule rack
    Sounds like you may be using the 4x4 when it isn't needed. I only use it when the roads are slick or there is potential for ice and even then, I'll turn if off if I am turning a lot. The 4wd system is designed as a part-time unit and doesn't have a center differential to allow for full-time use when the roads are dry. The driveline is most likely binding and causing the noise.
