Rear end off set a little
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jed1894, Jan 5, 2012.
  1. Jan 5, 2012 at 2:27 PM
    jed1894
    jed1894 [OP] Active Member
    2011 Tacoma 4x4
    Quick question before I waste a trip to the dealer:
    I just noticed that my back wheels are off set about 1/2 inch. That is, one tire is out (other tire is in) more than the other side. If you measure from the frame to the outside of the tire, on side is out 1/2 more than the other side.
    One explaination to this is that I had the leaf spring TSB done and I never really noticed anything until today. However, they alligned the truck and it drives okay. I'm assuming they can loosen up the u-bolts and move it about 1/4 inch one way, do another alignment and all will be good.
    Any of you had similiar issue?
    thanks, jed
  2. Jan 5, 2012 at 2:29 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i bet your bed has moved a tad or has never been dead on centered giving the ellusion that something is vitaly off..a common thing with our tacos!
    edit: i skimmed too fast and didnt fully comprehind that you are measuring from the frame. can you post a copy of the alignment numbers?
  3. Jan 5, 2012 at 2:38 PM
    jed1894
    2011 Tacoma 4x4
    "alignment numbers" ?? I don't think I have those unless you can tell me how to measure.
    I can get behind the truck and look down each side and see the left side tire is out more than the right side. I placed a tape measure on top of the tire and measured to the frame. It's off 1/2 inch. Can you give me some directions on some stuff to measure and I'll run outside and handle this.
    This is bugging the crap out of me now.......thanks for helping.
    jed
  4. Jan 5, 2012 at 2:40 PM
    MonkeyProof
    SoCal- SGV
    you should have recieved a print out of the alignment from the dealership
  5. Jan 5, 2012 at 2:42 PM
    okboatie1
    okboatie1 Well-Known Member
    Darrell
    Chula Vista, CA.
    03 PreRunner TRD SR5 DCSB
    OME 881's w/Dakar's, Deckplate mod, Debadged, door chime mod, 12V outlets always on,
    ^^ THIS ^^
    They should have given you the print out.
  6. Jan 5, 2012 at 2:48 PM
    jed1894
    2011 Tacoma 4x4
    They may have, but who knows what I did with them. I could call them and ask for a new copy. Anything in particular I need to say or just the numbers? Also, for my benifit and understand, what will the alignment numbers do for you?
    Thanks, jed
  7. Jan 5, 2012 at 2:56 PM
    okboatie1
    Darrell
    Chula Vista, CA.
  8. Jan 5, 2012 at 2:58 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    if his rear end is what is offset alignment numbers cant help. the alignment only messes with the front 2 tires and steering wheel not the rear end itself. correct me if im wrong
  9. Jan 5, 2012 at 2:59 PM
    jed1894
    2011 Tacoma 4x4
    Okay. I will try to get them. Could having the tires off 1/2 inch be okay or normal?
  10. Jan 5, 2012 at 3:03 PM
    okboatie1
    Darrell
    Chula Vista, CA.
    on the link posted, there are numbers for the rear as well. Guessing it depends on if the shop does the measurements for ther rear or not? I always ask them just to make sure my ubolts have adjusted themselves. I could be wrong too.
  11. Jan 5, 2012 at 3:07 PM
    2000GTacoma
    Snow Hill NC
    if you say so but i have never heard of that
  12. Jan 5, 2012 at 3:10 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Some places do 2 wheel alignments some do 4 wheel alignments. Its correct that the rear cant be adjusted but at least you get to see what the rear wheels are doing. My alignment below
    Edit: Looking at again I dont think you will be able to tell if one side is "pushed in" more than the other with what is measured though
    Hartford likes this.
  13. Jan 5, 2012 at 3:18 PM
    MonkeyProof
    SoCal- SGV
    you would be looking for something that is called "thrust angle" if a 4 wheel alignment was done. i believe on of the procedures for the TSB is a wheel alignment to ensure everything is in factory tolerances.
  14. Jan 5, 2012 at 3:22 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Thrust angle is at the very bottom of mine. How would you know if its off though? Like what would the thrust angle be if its not correct?
  15. Jan 5, 2012 at 3:24 PM
    bish54673
    bish54673 Well-Known Member
    Tyler
    Ruston, LA
    '11 Black PreRunner
    18" Enkei Black & Chrome Rims on BFG AT/s
    My truck is the same as OP's...I guess i've never thought too much into it though. I just assumed the bed was put on slightly to one side more. I'd like to know the reason for this too, now :rolleyes:
  16. Jan 5, 2012 at 3:25 PM
    jed1894
    2011 Tacoma 4x4
    Per the service manager, a 4 wheel alignment was done. I remember him telling me that when it was done.
    I just called him after I posted this thread. He was about to leave and busy, but told me to bring it in and he would put it on the alignment machine to make sure it's right. He said that when they put on the leaf, it could have been re-installed a little off. The alignment was done after the installation, of course, so the alignment would have matched the 1/2 off. He told me not to worry about and he would fix at next oil change if it was out. However, he also told me that if it aligns on the machine, it might not be touched. I can probably change his mind on this because it is bugging me now that I know one tire is in 1/2 more than the other.
    The way I'm thinking, the adjustment (loosen up the u-bolts) would only be a 1/4 inch, correct. A 1/4 adjustment should make both sides equal if one side is out 1/2 now.
    Thanks, jed
  17. Jan 5, 2012 at 3:25 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    After I install my new rims and tires, i find out the same thing, it dose off 1/2" passanger side stick out more than the driver side, is that your's the same?
    I do post a question on the forum before, a lot of members here said it is fine.
  18. Jan 5, 2012 at 3:34 PM
    jed1894
    2011 Tacoma 4x4
    Yep, same thing. The passenger side is the side that's out more. How about that.....
  19. Jan 5, 2012 at 3:44 PM
    jed1894
    2011 Tacoma 4x4
    Everybody is outside now measuring.......
    BandanaBerg likes this.
  20. Jan 5, 2012 at 3:55 PM
    bish54673
    Tyler
    Ruston, LA
    '11 Black PreRunner
    lmao nah, I just already have noticed it. I just didn't think much of it I guess.
