Rear End Rumble when slowing down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaZL, May 19, 2015.
  1. May 19, 2015 at 7:12 PM
    TacomaZL
    TacomaZL [OP] Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    Noticed that when I first start driving my truck, first couple stops I feel rear end vibration/rumbling. Noticed the vibration goes away after a little bit of driving.
    Just changed differential fluid, using Valvoline Synpower 75W-90, checked fuel level after changing and seemed good. What could be causing the issue?
    2013 Tacoma Base
  2. May 19, 2015 at 7:35 PM
    Pigpen
    Dan
    Northwest Montana
    How did the fluid look? Was the magnet covered in goop and shavings?
    Also are you certain it's not from the front? Could be your driver side clamshell bearing talking to you.
  3. May 19, 2015 at 7:39 PM
    TacomaZL
    Illinois
    Not familiar with what the "clamshell" is....it's only RWD if that matters...
    Fluid when I replaced it was black and smelled foul...changed at 33,000 miles, magnet had a small share of metal on it as well as goop.
    Should I be concerned? I didn't use lsd adative if it matters
  4. May 19, 2015 at 8:25 PM
    Pigpen
    Dan
    Northwest Montana
    No additive needed with the electric "LSD"
    If you're 2Wd, then no front diff (clamshell)
    Diff fluid will be dark and a little goop on the magnet is normal.
  5. May 19, 2015 at 8:28 PM
    Pigpen
    Dan
    Northwest Montana
    Could be brakes. I'm out of ideas though.
  6. May 19, 2015 at 8:30 PM
    D50boy
    D50boy Well-Known Member
    Kenneth
    Texas
    And rear diff fluid is always stinky. You never forget that smell.
  7. May 19, 2015 at 8:34 PM
    TacomaZL
    Illinois
    Anyone have any other ideas?
  8. May 20, 2015 at 6:13 AM
    TacomaZL
    Illinois
  9. May 20, 2015 at 6:27 AM
    Pigpen
    Dan
    Northwest Montana
    Okay, It's morning and my brain is working. Grease the zerks on your driveshaft. There's a good chance this will eliminate the noise. If that doesn't do it, move to the carrier bearing. Remove the CB bracket and rotate it 180 and bolt it back on. My money is on a sticky U joint though.
  10. May 20, 2015 at 7:00 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Not sure if this is like your problem and probably not what you want to hear, but from looking at your avatar it looks like you have a regular cab. My grandfather got a new base, 4cyl, regular cab and also had the same rumble/vibration like you're talking about. He took it to the dealer multiple times with no luck.
  11. May 20, 2015 at 2:08 PM
    TacomaZL
    Illinois
    So should I stop worrying? Is this worth taking to the dealer?
  12. May 20, 2015 at 2:25 PM
    benb870
    benb870 Well-Known Member
    Ben
    West Palm Beach Florida
    2008 DC
    TRD Supercharger with URD pulley,ARB Front Bumper, All-Pro Rear Bumper, OME Lift, Camburg UCA's, Rock Sliders, Rough Country 20" light bar and 30" light bar. Rigid LED lights in ARB bumper, Weathertech mats, Illuminated 4x4 switch, Dual A Pillar Gauge pod with Autometer Phantom II Boost/Vac & Oil Pressure Gauges, Black Headlight mod, GrilleCraft Grill, 20% tint on all windows, All-Pro IRS Skid Plate, All-Pro Transmission Skid Plate, All-Pro Transfer Case Skid Plate, Azentec Mirror with GPS & Back up Camera, LED Tail lights & 3rd Brake light, High Jack Lift.
    Check the drive shaft u joint. Could be the culprit.
  13. May 21, 2015 at 7:29 AM
    benb870
    Ben
    2008 DC
    Follow up from my previous post...... If the grease bearing dries out in the u joint, the needle bearings inside the u joint will turn to dust and then there will be some play in the u joint, causing the vibration.
  14. May 21, 2015 at 8:25 AM
    D50boy
    Kenneth
    Texas
    Won't it cause that "SqeakSqueakSqueakSqeakSqueakSqueak" sound if the joint were going out?
  15. May 21, 2015 at 8:34 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Is your truck a "5-lug" ?
  16. May 21, 2015 at 12:52 PM
    TacomaZL
    Illinois
    Yes my truck is a 5 lug...is this a common issue?
  17. May 21, 2015 at 1:59 PM
    deeezy
    Dana
    Hawaii
    I have a 5-lug company truck that I drive home everyday and sometimes when braking it looks as if the tranny is holding it in too high of a gear for the RPM's. The truck growls and vibrates until it down shifts. Look at your tach when it's happening. I don't care to get it looked at because I didn't pay for the truck.
