Rear end shot on a 2011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnetic11, Jan 3, 2014.
  1. Jan 6, 2014 at 11:23 AM
    #41
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    Mechanically; no, it did not
    technically; sort of...
  2. Jan 6, 2014 at 11:23 AM
    #42
    TrdSurgie
    TrdSurgie revised
    Oahu
    No it didn't. It came with A-LSD. Big difference.
  3. Jan 6, 2014 at 11:27 AM
    #43
    mick478
    Bott
    Stockton, CACA
  4. Jan 6, 2014 at 11:31 AM
    #44
    magnetic11
    magnetic11 [OP] Well-Known Member
    "some nuke plant"
    11 trd sport
    Fab fours front and rear bumpers, B.A.M.F. weld on rock sliders, softopper, removed mud flaps and D-Badged everything. Icon 2.5 Extended Travel coil-overs, Total Chaos upppers, 2.0 Icon extended travel shocks with the resi's and Dekar Leaf packs.
    This is exactly what the problem is.
  5. Jan 6, 2014 at 11:33 AM
    #45
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, LSD, Limited slip diff. It automatically engages when one wheel spins, the braking system applies pressure to that side, which engages the clutch pack in carrier to give to that wheel. That's what LSD is. So, yes it mechanical with aid, of braking system.
  6. Jan 6, 2014 at 11:37 AM
    #46
    na8rboy
    WI
    Oh ok, if that's what you think...LMAO...
  7. Jan 6, 2014 at 11:39 AM
    #47
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    This. There are no clutch packs with automated LSD.
    OP: You need to tell the dealer that they either prove to you that your lift caused the diff to break, or they fix it.
  8. Jan 6, 2014 at 11:45 AM
    #48
    mick478
    Bott
    Stockton, CACA
  9. Jan 6, 2014 at 11:47 AM
    #49
    na8rboy
    WI
  10. Jan 6, 2014 at 11:48 AM
    #50
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    like the others have said, you have an auto lsd...the same that i have on my 09 sport. the 2005-2008 sports came with a mechanical lsd that uses the clutch packs. yours (and mine) use the brakes to simulate an lsd. not the same and will not perform as well as a mechanical lsd.
  11. Jan 6, 2014 at 11:50 AM
    #51
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    Wow what a pain in the ass the dealership is being
  12. Jan 6, 2014 at 11:51 AM
    #52
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    But your truck doesn't have an LSD, man. The A-LSD system senses tire spin, and simply tells the brake on that side to apply pressure to stop the spinning wheel. It doesn't physically do anything within the differential itself. Like others have said, it hasn't done that since 2009. Hence why every Tacoma (I believe, at least PreRunners and above) has A-LSD. It's simply an electronic system. None of us from 2009 on have a true LSD differential.
  13. Jan 6, 2014 at 12:05 PM
    #53
    magnetic11
    "some nuke plant"
    11 trd sport
    $2000 for all repairs.
    I never drive with the LSD on.
    but the did say that it was the spider gear for the LSD
  14. Jan 6, 2014 at 12:16 PM
    #54
    The_Hodge
    SC
    ^^exactly. the auto LSD has nothing to do w/ the gears. it's a computerized braking system.
  15. Jan 6, 2014 at 12:17 PM
    #55
    mick478
    Bott
    Stockton, CACA
    I tried....
  16. Jan 6, 2014 at 12:17 PM
    #56
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I'd like to see what costs $2k, and what's actually broken. An assembled 8.4 third costs under $700 from East Coast Gear Supply.
  17. Jan 6, 2014 at 12:22 PM
    #57
    mick478
    Bott
    Stockton, CACA
    Labor?
  18. Jan 6, 2014 at 12:23 PM
    #58
    magnetic11
    "some nuke plant"
    11 trd sport
    what ever it is, its in my rear diff
  19. Jan 6, 2014 at 12:27 PM
    #59
    mick478
    Bott
    Stockton, CACA
    I would also make sure a bj comes with it... Once a day for 8 days. Especially for 2k
  20. Jan 6, 2014 at 12:31 PM
    #60
    magnetic11
    "some nuke plant"
    11 trd sport
    $1400 parts and almost $400 labor
