Rear frame mounted tow hooks?
Discussion in '3rd Gen. Tacomas (2016+)' started by phsycle, Apr 9, 2018.
  1. Apr 9, 2018 at 7:47 AM
    phsycle
    phsycle [OP] Well-Known Member
    CA
    Saw these on a Wrangler. I was wondering if anyone makes these for Tacoma's. Something that hangs down and sticks out from the bumper.
    The main reason for this inquisition is, I've got BSM and no bumper manuf makes a legit BSM compatible rear bumper. Those that do, people are reporting that performance isn't consistent. It's a highly calibrated piece of equipment, so it is no surprise that they'd be finicky bolted on an aftermarket product.
    So I was thinking instead of replacing the bumper, I could at least give it some protection. Something like these hooks, combined with a hitch slider (i.e. Skidmark) would at least keep the bumper from getting scraped up too bad. I'm only doing mild trails, so these would keep the bumper from dragging. (i.e. Fins n Things).
    Anyone know of something similar to this for a Tacoma?
  2. Apr 9, 2018 at 7:55 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    An aftermarket steel bumper is one of the best upgrades you can do, plus you can sell your plastic OEM bumper locally for up to $300.
    Some like Fab Fours need the factory tow hitch and are cheaper $700-$800 and others have integrated tow hitch and will cost more $1000+. Definitely get one that has the shackle mounts.
    16tacoblue and El Latigo like this.
  3. Apr 9, 2018 at 9:10 AM
    dilbert
    dilbert Well-Known Member
    PNW
    2019 DCLB TRD Off-Road
  4. Apr 9, 2018 at 1:02 PM
    Tacos in Gensokyo
    Tacos in Gensokyo Bohemian Archive in Japanese Red
    2017 SR 4cyl MT SSM
    Rokblokz Mudflaps, 2015 TRD Pro Suspension
    Just to make sure I understand, you want protection for the bumper, not more recovery points? Like, mini-skid plates for the rear bumper?
    EDIT; Something like this?
  5. Apr 9, 2018 at 1:43 PM
    phsycle
    CA
    Yes, correct. Thanks for reading through the entire post. I looked into Avid Offroad and called them, but they weren't willing to make anything that was BSM compatible. I thought of buying it and cutting off the part that would interfere with the BSM sensors, but thought I'd see if there were other options first.
    Tacos in Gensokyo likes this.
  6. Apr 9, 2018 at 1:48 PM
    Grossomotto
    2017 4WDV6LB6MT
  7. Apr 9, 2018 at 2:13 PM
    phsycle
    CA
  8. Apr 9, 2018 at 2:13 PM
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    Probably going to need custom fab work for what you want. I found this bumper, seems pretty open but no idea if it interferes with the BSM. I think I see the sensors for the BSM in this pic.
    shakerhood likes this.
  9. Apr 9, 2018 at 2:15 PM
    Grossomotto
    2017 4WDV6LB6MT
    So much tech didn’t even know what sonar was or it even existed. Is BSM backup SENSOR monitor? Is it to detect incoming drones?
  10. Apr 9, 2018 at 2:21 PM
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    Could you weld a piece of DOM tubing to the skidmark, so that it was parallel to and lower than the bumper?
  11. Apr 9, 2018 at 2:29 PM
    SpearJoshuaTree
    SpearJoshuaTree They put me in time out :(
    2017 sky silver 4x4 TRD-OR DCLB
    I’m on the same page as you.. thought those circles in the back were the BSM....
    and many leagues down does that sonar reach ?:anonymous:
  12. Apr 9, 2018 at 2:34 PM
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    Here's a pic of the BSM sensor. It's in the man's hand.
  13. Apr 9, 2018 at 2:40 PM
    Grossomotto
    2017 4WDV6LB6MT
    BSM is backup and Sonar is for parking, just looked it up. There’s already a rear camera, why do you need any of this?
    No disrespect to the OP
  14. Apr 9, 2018 at 2:43 PM
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    BSM, or Blind Spot Monitoring, is to alert you if the lane you are merging into is occupied.
    In this situation, BSM would tell you that both lanes are not safe to merge into, as they are occupied.
  15. Apr 9, 2018 at 2:44 PM
    SpearJoshuaTree
    Ahhh I just looked up BSM (blind spot monitor)...I see, so you don’t have to turn your head and also check your mirrors.... I wouldn’t want to lose all that extra money I paid for the extra tech, I see where the OP is coming from....
  16. Apr 9, 2018 at 2:45 PM
    Grossomotto
    2017 4WDV6LB6MT
    Do they work off road?
    My point he was looking for an aftermarket bumper, or tow hooks or something
  17. Apr 9, 2018 at 2:47 PM
    SkolChipz
    SkolChipz Well-Known Member
    Jared
    Anchorage, Alaska
    '16 DCLBOR BBP
    LEDs, Snow, Dirt, Dogbed
    Do you swap your bumper depending on what you're doing? I'm going out on a limb here to suggest he wants an additional feature on his vehicle without needlessly sacrificing features it already has.
  18. Apr 9, 2018 at 2:50 PM
    Tacos in Gensokyo
    2017 SR 4cyl MT SSM
    He wants armor that won't render the BSM system inoperable. The tow hooks were suggested merely as supplementary armor for the stock bumper.
  19. Apr 9, 2018 at 2:50 PM
    Grossomotto
    2017 4WDV6LB6MT
    In that case he should just get a tow hitch and put a 2” shackle mount in it, that would be cheapest.
    SpearJoshuaTree likes this.
  20. Apr 9, 2018 at 3:11 PM
    SpearJoshuaTree
    Sounds like best option unless he has someone make him a custom bumper... or wait till someone makes that armor that works with the BSM (which Most off-road vendors seem to not care about)
