Rear Helper Spring Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LizellaFella, Feb 10, 2012.
  1. Feb 10, 2012 at 5:12 AM
    LizellaFella
    LizellaFella [OP] Well-Known Member
    Eddie
    Reno Nevada
    2016 Tacoma SR5 4x4
    Looking for information on a rear helper spring kit for my 2010 Tacoma DCSB Sport model. I am pleased with the way it rides now, but when I hook my 18ft bass boat to the truck the ass-end sits lower tan I'd like.
    Dips and bumps cause the rear to drop quite a bit more. Sometimes even feeling like its almost hitting the bump stops.
    Any recommendations on a spring kit to alleviate this issue?
    TIA
    LF
  2. Feb 10, 2012 at 5:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What year is your Tacoma? There is a TSB (Technical Service Bulletin) for the weak leaf springs in the Tacoma. It's covered under the 3 yr 36k mile warranty. If you're out of that, you might want to consider either air bags or Timbrens. Timbrens are basically a taller bump stop that has some give to it and acts as a support spring without the air hoses associated with air bags.
