Rear Leaf Spring Debates
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dbryan1426, May 9, 2013.
  1. May 9, 2013 at 8:37 PM
    Dbryan1426
    Dbryan1426 [OP] Member
    Hello there,
    New to the community.
    Currently have a 09 Tacoma, 4x4 access cab, 6 spd...Putting in a lift soon. My question is to do with the rear leaf springs;
    As my truck is Canadian it come with the TSB leafs.
    I am installing a 2" progressive add a leaf from toytec, but I am also adding airbags at the same time. I am using the truck to haul my camper (800lbs), sometimes my sled, (400lbs) and sometimes pulling a heavy trailer (3000lbs) But the majority of the time, it will be unweighted.
    What you you guys think? Remove the TSB? Remove the Overload as I am running airbags? Keep the O/L but retain the TSB?
    The Toytec guys say keep everything (TSB, O/L, plus thier 2" progressive add a leaf, and airbags) but I think that will make the truck ride too harsh.
    Opinions or thoughts would be greatly appreciated.
    Oh and the fronts will be 885/5100s with LR UCAs
    Cheers,
    Dave
  2. May 9, 2013 at 8:44 PM
    916 YATES
    916 YATES Well-Known Member
    Brian
    Sacramento
    2010 DCLB Grey TRD Sport
    emblems and decals removed, added TRD special edition badges, Sway A Way's front and rear, SCS stealth 6's, Toyo A/T II 265/70/17
    check out Wheelers Off Road Heavy Duty Add A Leaf. Progressive with heavier leafs. Check with YotaDan.
  3. May 9, 2013 at 9:45 PM
    Dbryan1426
    Thanks, but I already ordered from Toytec. Eventually going to go with OME...or perhaps Wheelers..
  4. May 10, 2013 at 7:23 PM
    Dbryan1426
    anyone?
    Cheers,
    Dave
  5. May 10, 2013 at 7:35 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    all I can say is that if you start with all leaves, and don't like it, you can remove some and re-cut your centering pins. if you start with fewer leaves and decide you need more, you also need to buy new centering pins. only you will know whats right and comfortable. that's how I would do it
  6. May 10, 2013 at 7:40 PM
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
  7. May 11, 2013 at 10:05 AM
    Dbryan1426
    Thanks guys,
    And thank for that link!
    I think ill removed the O/L springs, used a 1/2" block to compensate for the loss of height, and keep the TSB.
    Cheers,
    Dave
