Rear Leaf Spring Recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CGYToyota Taco, Dec 1, 2015.
  1. Feb 27, 2016 at 4:46 AM
    #41
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I feel bad for all you guys with sagging or inverted springs. My rear springs look nearly perfect, and don't seem to be showing any signs of fatigue. That said, I bottom out on even small bumps in the road, and the bed sags with pretty light loads. Just glad it doesn't sag all the time!
  2. Feb 27, 2016 at 4:57 AM
    #42
    BuffaloScout
    BuffaloScout Well-Known Member
    Minnesota
    10 4x4 TRD
    Weathertech, Wet Oaks, Baby Car Seat, Flashlight Mod
    I have the add a leaf TSB done on my truck, so i was suprised I received a letter from toyota telling my to watch out for my leafs. Been keeping an eye on them and so far they look fine. If toyota wants to replace them they can as long as I get the same amount of leafs in return.
  3. Feb 27, 2016 at 5:16 AM
    #43
    niterider
    niterider Active Member
    Norm
    '07 Sport Taco
    Stereo
    The bill to Toyota was $1300. My copy was 0. But they put in all new hardware and bottom plates. Then maybe you just buy helper springs? My truck is an '07 ac 4x4 sport.
  4. Mar 2, 2016 at 10:51 AM
    #44
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    Does anyone know on the new remedy, do they just replace the spring as a unit? Or do they have to assemble them with centering pins and attach the ubolts etc? I still have some friends that work at a dealership, wondering if I can talk them into installing my AAL while they are doing the springs for the campaign.
    Thanks.
  5. Mar 2, 2016 at 10:53 AM
    #45
    T4RFTMFW
    T4RFTMFW Well-Known Member
    New leaf packs, unbolted at the front and rear hanger (or shackle) and installed. No need to disassemble and reassemble a leaf pack when replacing them takes far less time and effort.
  6. Mar 2, 2016 at 11:04 AM
    #46
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Mine are getting worse every day it seems. Last week I picked up 12 packs of stones and 4 bags of mulch for landscaping around the house. Each bag of stone weighed 50lbs (600lbs total), the mulch probably weighed about 20 lbs each (80lbs) so thats a grand total of maybe 700lbs. My springs were on the bump stops and my nose was pointing at the sky. It was actually a little embarrassing when the guy loaded it, 700lbs shouldn't make a TRUCK meant for carrying heavy things sag like a 1990's ford tempo.
    I keep hearing 2 thoughts, either toyota will give us recall people brand new springs or that toyota is just going to apply an extra clamp on 1 side to make sure if it does break it won't puncture the gas tank. maybe I'm overly optimistic but I'm leaning toward option 1. If toyota was just going to apply a clamp why would it take them over a year to start fixing the issue. Having said that, wtf is taking so long? I got the recall notice in Nov. of 2014!!!
    Beaglesridefree likes this.
  7. Mar 2, 2016 at 11:08 AM
    #47
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Just read this, what state are you in? When did you say you got that? Good to know they are finally sending out the resolution letters, still waiting for mine...
  8. Mar 3, 2016 at 8:25 AM
    #48
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    After reading this I went back online to the Toyotaowners.com site and sure enough it now says "remedy...replace". Called my dealer and have an appt. for next saturday to get the rear springs replaced!! Only took a year but I'm not complaining, I know they still won't be up to the quality of an aftermarket, heavy duty set but still a hell of a lot better than my worn out old 3 leaf springs. I'm assuming these new ones are the 4 leaf spring sets?
  9. Mar 7, 2016 at 10:03 AM
    #49
    Norton Guy
    Norton Guy Well-Known Member
    North East
    2011 Double cab SR5 Sport
    Finally made into the schedule of the local dealer in Kingston MA, dropping it off for new springs tomorrow (3/8).
    el_turks likes this.
  10. Mar 7, 2016 at 11:03 AM
    #50
    yazmatic
    yazmatic Well-Known Member
    Paul
    2012 DCSB TRD SPORT
    Bilstein 5100's Eibach 620 springs SCS Stealth 6 Matte Bronze BF Goodrich All Terrain TA KO2 265/70/17 SOS Front Bumper Full Hoops Safari AirFlow Snorkel
    is this the same thing as the TSB that includes 2012 models?
  11. Mar 7, 2016 at 2:01 PM
    #51
    JerseyDevil
    JerseyDevil New Member
    Lee
    2007 Gray Tcacoma Pre
    Had my springs inspected about a week ago. I was told that about 99% of all fail and qualify for new springs. Got mine installed today and the difference in ride is noticeable. The rear sits higher. Had the three and the replacement
    for me was the four. I am happy with the outcome.
    BTW Hello to all. My first post. Great forum!!!.
  12. Mar 7, 2016 at 3:04 PM
    #52
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    No. It's for model years 2005-2011.
  13. Mar 8, 2016 at 4:30 AM
    #53
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    This is a recall, not a tsb.
  14. Mar 8, 2016 at 11:25 AM
    #54
    Norton Guy
    North East
    Dealer swapped the springs this morning , no hassle.
  15. Mar 8, 2016 at 11:53 AM
    #55
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I need to inquire about this with the local service department. My springs broke 3 years ago and I installed aftermarket 3 leaf replacements which suck just as bad as the originals did. The parts guys told me they wouldn't replace them because they were non-factory springs. I called Toyota and they said they would consider reimbursement if I mailed them an invoice. Which of course I can't find. Emailed the company I bought the springs from last week. No answer.
  16. Mar 8, 2016 at 12:18 PM
    #56
    jliberatore92
    jliberatore92 Well-Known Member
    Troy, MI
    06 Tacoma TRD Off-road
    5100s with OME 885 coils. OME Dakar leaf and OME nitrocharger sport shocks., 265/75/R16 Duratracs
    I just did the same and they emailed back with instructions on where to send my invoice and proof of ownership. I'm hoping they will reimburse my Dakars I bought online and installed myself. It seemed like they were looking for a dealership invoice for parts and labor though...
  17. Mar 8, 2016 at 1:15 PM
    #57
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Did you initiate your request over the phone?
  18. Mar 8, 2016 at 2:18 PM
    #58
    jliberatore92
    Troy, MI
    No, I initiated via Email.
  19. Mar 8, 2016 at 4:52 PM
    #59
    BuffaloScout
    Minnesota
    10 4x4 TRD
    Bump for ^^^^^^^^Toyota's answer^^^^^^^^^^^
  20. Mar 11, 2016 at 10:18 AM
    #60
    Ahougland89
    Ahougland89 Well-Known Member
    Anthony
    Orting, Washington
    2007 Tacoma 4x4 6spd Manual
    3inch lift 33inch TOYO M/T
    Well I called to get my leaf springs checked out and they said they are still in preliminary stages of the recall and don't have a fix yet. Not sure how you guys are all getting your stuff fixed
