Rear leaf spring trouble
Discussion in '1st Gen. Tacomas (1995-2004)' started by HamerMan, Aug 28, 2013.
  1. Aug 28, 2013 at 4:45 PM
    HamerMan
    HamerMan [OP] Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    I've heard many things about these rear leaf springs sucking a big one, and mine are no exception. I assume the springs aren't supposed to sag like this. Anybody have a good fix other than helper springs and an OME suspension swap?
    I also have axle wrap:(:(
    EDIT: anyone know how to rotate a picture -.-
  2. Aug 28, 2013 at 4:46 PM
    Madjik_Man
    Colorado Front Range
    Turn your monitor 90* :eek:
    My springs looked like that about 70,000 miles ago. Still riding on the same ones.
  3. Aug 28, 2013 at 4:48 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Except mine do the wonderful CLUNK sound when I stop
    :pout:
  4. Aug 28, 2013 at 4:49 PM
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    EDIT: anyone know how to rotate a picture -.-[/QUOTE]
    Turn your phone landscape (side ways) instead of portrait (upright)
    That's what I do if i post a pic on TW. If not, it will turn out like yours.
  5. Aug 28, 2013 at 4:52 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    I sent it to my laptop haha I think I forgot to rotate it after I saved
  6. Aug 28, 2013 at 4:58 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    I just used the clamp part and it worked great. Read this thread.
    Axle wrap
  7. Aug 28, 2013 at 5:01 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Could I just clamp where the contact points with the helper springs are with just a clamp sort of deal and call it good?
  8. Aug 28, 2013 at 5:03 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Really check out the springs to make sure one is not broken somewhere. If they look good, then you could do an aal if you don't mind some lift.
  9. Aug 28, 2013 at 5:11 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    I'm trying to keep the pre-runner sort of look with the front end a bit higher than the front. I have heard of people using springs from a 3/4-1 ton pickup. Would that work?
    EDIT: Or desert-runner, or Baja truck or some other fancy jazz.. don't mind me I'm just slightly stupid
  10. Aug 28, 2013 at 5:21 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I dont think there in that bad a shape, mine are actually negative arched. I so want new ones. When i stop and go to back up my drive way i can actually feel the rear end try and rotate upward.
  11. Aug 28, 2013 at 5:26 PM
    LSC15
    LSC15 Southern Retrofits
    Logan
    2008 TRD D-Cab
    2008 Double Cab - Current 2002 4runner - Sold 2001 Double Cab - Sold 1995 Xtra Cab - Sold
    Don't get a cheap aal from a vendor. Get some OMD springs
  12. Aug 28, 2013 at 6:39 PM
    tacoma04
    Bruce
    Tennessee
    That is what I did. I bought just the clamp part at O'Reily's and put it on.
  13. Aug 28, 2013 at 6:43 PM
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    My 03 springs look just like yours.Wheeler's has an AAL for $77.50,that's what I'm gonna get..
  14. Aug 28, 2013 at 7:02 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Explain OMD please
  15. Aug 28, 2013 at 7:05 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  16. Aug 28, 2013 at 8:11 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
  17. Aug 29, 2013 at 5:56 AM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    You can either add the leaf spring helpers or if you want to save some $$, go to o'reilly's auto parts (or your favorite parts store) and pick up a set of 2 1/2" square u-bolts and install them approx. 6" in front of the axle. They sell them in a kit and it took care of my axle wrap problem.
    The Klunk maybe due to the slip yoke needing to be lubed or u-joints.
    Good luck.
  18. Aug 29, 2013 at 12:40 PM
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Is there a how to thread on greasing the slip yoke, and the u-joints?
  19. Aug 29, 2013 at 1:57 PM
    tacoma04
    Bruce
    Tennessee
    Just get a grease gun, crawl under, wipe off the zerk fittings and pump some grease in them. Make sure you look inside each pivot point along the drive shaft and get all the zerks. The slip yoke at the back will take more than a u-joint if it is dry.
  20. Aug 29, 2013 at 2:20 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
