Rear leaf spring TSB's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardtaco, Jan 22, 2017.
  1. Jan 22, 2017 at 2:41 PM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I am noticing some serious sag after having my rear leafs replaced under the TSB this past year. I am guessing maybe 1 - 1.5" difference from before. This is on a 2008 DCSB Prerunner. If I were to install an airbag kit and inflate them to raise the truck around 1.5", would this basically make it feel like there would be no suspension in the rear at all going over bumps ? What are my options ? Are the air bags a good solution ? Aside from a load of mulch and helping people move, my truck sees very little heavy hauling and no towing.
  2. Jan 22, 2017 at 3:21 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    it would probably be more cost affective to just upgrade the leafs. you don't need to put All Pros or Dakars but there are some good after market leafs that are an oem replacement, just better haha i cant think of any off hand because i haven't looked into it but ive read some threads about them so i know they exist haha I'm sure some one will chime in here with some suggestions
  3. Jan 22, 2017 at 3:22 PM
    Fitz235
    Fitz235 Well-Known Member
    New Hampshire
    Black '05 AC TRD Offroad 4WD
    - Bilstein 5100's Set to 1.75" - Wheeler's 2" AAL - Toytec 1/4" Driver's Side Spacer - ECGS Bushing - Powdercoated Tundra Wheels - 265/70/17 Toyo Open Country 2's - TRD Catback Exhaust - Access Lorado Tonneau - Factory Tube Steps - Jumper's Interior LED Map/Dome Lights - Pioneer AVIC 5100 NEX - Sony Speakers - Depo Black Tail Lights - Kleerz Third Brake Light - HomerTaco Satoshi Grill
    Why not go with an AAL (less expensive option), or new leaf pack (more expensive option)?
    To know for sure how much they sagged, or not, measure from center of hub to bottom of fender. Typical measurements are ~20" front, ~22" rear, on a factory non-lifted Tacoma. That way you can determine how much lift (or not) you need.
  4. Jan 22, 2017 at 3:30 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    I think wheelers has some leafs you could try, the 4 leaf pack would bring you back to stock height I think or General leafs, there's lots of info on here for that kind of stuff, I just did a quick search.
  5. Jan 22, 2017 at 3:32 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    I had the TSB leafs done a few months ago. The dealer would not put my AAL from my older leaf pack on the new TSB leafs. They would however order one and install it for $299. I said nothank you and that I would like my AAL put in the bed of my truck to take with me. When I got home I dropped the TSB leafs and added the AAL to them. I actually took the first leaf off and replaced it with the AAL. Great ride height and ride. PS. I could feel the axle wrap on the new TSB leafs on the way home.
  6. Jan 22, 2017 at 3:33 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Thanks guys. No recommendations on doing bags, correct ?
  7. Jan 23, 2017 at 6:01 AM
    Satelliteguy
    Satelliteguy Active Member
    Sonoma county
    06' Taco DCSB
    Pelfreybuilt bumpers, home built roof rack, bed rack and rock sliders. Taco tunes 10" sub box, a lotta spunk
    Thanks guys! This has been helpful. The dealer replaced my springs and I noticed right away that the rear end was sagging. I think I'll add some leafs. Any recommendations for which brand?
  8. Jan 23, 2017 at 1:34 PM
    Bocsy44
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
  9. Jan 25, 2017 at 10:22 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Well, I did some center hub to bottom of fender measuring and came up with 20" in the front and 22" in the rear. I guess I have no saggage after all.
