Rear lift setup?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Littlebro 5, Apr 24, 2011.
  1. Apr 24, 2011 at 8:42 AM
    Littlebro 5
    Littlebro 5 [OP] Well-Known Member
    Tyler
    Wilsonville or
    01 4x4 3.4L sr5 manual all-pro lift
    6" deck plate mod, sweet bed bar.
    I am looking to get the deaver 8 leaf pack with billstein's and a 1" lift toy tek shackle Will this get me 3" of lift in the rear?
  2. Apr 24, 2011 at 4:55 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    You'll probly end up with 3.5-4" with that combo no doubt. what's in the front of your truck for a lift?
  3. Apr 24, 2011 at 4:56 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    what kind of bilsteins? i'd suggest 5125's for more flex but thats just me
  4. Apr 24, 2011 at 5:49 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Agreed. For that much lift you would need 5125s. You would have to measure to get an exact size though. 5100s in the rear are only good for up to 2~"
  5. Apr 24, 2011 at 6:07 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Screw 5125s, 5150s are only 99 bucks off allpro :D
  6. Apr 24, 2011 at 6:11 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    99 for the pair? or each?
    $295 shipped for 4 from DSM (front 5100s & rear 5125s)
  7. Apr 24, 2011 at 6:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    99 each. Allpro sells the 5125s for 79 each
    What is DSM??
  8. Apr 24, 2011 at 6:22 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
  9. Apr 24, 2011 at 10:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    x2 on Downsouth. Call Marco, he'll hook you up.
    If its the j59 Deaver 8 leaf pack, that'll give you 1.5" alone. Usually, extended shackles are advertised by the anoount of added lift they give. so a 1" extended shackle added to the j59s should give you a combined +2.5".
    Rear shocks do not add any lift.
  10. Apr 25, 2011 at 8:01 PM
    Littlebro 5
    Tyler
    Wilsonville or
    Ok cool thanks guys I will check out the 5125 or 5150. I am doing the toy tek front 3"+ coilovers, I am trying to get a 3.5" lift in the rear so that I get a vary slight rake.
  11. Apr 26, 2011 at 2:08 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    then id look at allpros expedition leaf packs. They will give you lots of lift and are great springs too. The shocks don't provide the lift
  12. Apr 26, 2011 at 10:53 AM
    Littlebro 5
    Tyler
    Wilsonville or
    ok but what about the remounting of the mounts to fit the all pro's do you have them?
  13. Apr 26, 2011 at 11:06 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I have them but I'm kinda confused with your question. Are you talking shock mounts?
  14. Apr 26, 2011 at 7:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think he means the leaf spring mounts as it states on allpros site you need to put on new ones. But i think and Jlee will have to straiten this out as he has them and i dont, that you dont have to do that anymore? i contacted all pro about them for my 96 cuz its a different year with a different leaf and was told that they would bolt right up.
    Jlee..please speak up and correct me :D haha
  15. Apr 26, 2011 at 7:46 PM
    Littlebro 5
    Tyler
    Wilsonville or
    oh sweet i thanks i am just going to do the normal rear 3" kit. i love the price of the kit +$40 and you get the 1150.
  16. Apr 26, 2011 at 9:21 PM
    Toycrawler
    Toycrawler All Pro Sales
    Kurtis
    Hemet, CA
    98 trd
    fabtech 6in front with radflo coilovers, All-Pro rear 5in springs, Super charger, underdrive pulleys, 37in BFG Krawlers
    For the Tacoma springs from All Pro you do not need to change any of the spring hangers. You have an 95-04 the only thing you have to change is the shock mounts but only if you do a u-bolt flip kit other wise its a direct bolt in spring.
  17. Apr 26, 2011 at 9:40 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ya i am wishing i had done that now, cost me 500 for my wheelers 5 pack even tho i was in the GB. for about a 100 more i couldve had the expedition and shocks and shackles from all pro. oh well haha
  18. Apr 26, 2011 at 10:18 PM
    Littlebro 5
    Tyler
    Wilsonville or
    Ok thanks. Yeah I didn't understand the info of the springs.
