Rear lock install
Discussion in '1st Gen. Tacomas (1995-2004)' started by 757yotas, Jan 30, 2017.
  1. Jan 30, 2017 at 8:29 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Are there any good videos or write ups on how to install (more so wire up) a toyota e-locker on a 04 tacoma? I have the rear axle under the truck but no clue how to wire it up to a switch to make the locker work. Ive been researching for the past 2 hours on many sites and have found nothing
  2. Jan 30, 2017 at 8:34 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    The wiring on the truck's end of the harness might already be there. At least that's what Toyota did with 80 series Land Cruisers. If that is the case, you'd need an switch(OEM would be plug and play) and the connector for the actuator on the rear axle would be tucked away somewhere. I thought I saw a write up or something here on TW. I'll see if I can find it.
  3. Jan 30, 2017 at 8:37 PM
    757yotas
    Virginia
    2007 TRD Sport
    Thanks, the whole wiring deal and what plugs in where and what not is so confusing to me. I dont have any wiring yet or a switch, all i got my hands on was the whole new rear axle with the locker. I did find this wire kit but not sure id it would be a simple plug and play type deal. If so i would just buy this- http://www.lowrangeoffroad.com/inde...rness-kit-by-low-range-off-road-tdi-elwh.html
  4. Jan 30, 2017 at 8:38 PM
    cruiserguy
    Elijah
    SEKS
    757yotas[OP] likes this.
  5. Jan 30, 2017 at 8:40 PM
    cruiserguy
    Elijah
    SEKS
    If it's as easy as the link appears, I'll be keeping an eye out for an e-locked rear end... :drool:
    757yotas[QUOTED][OP] likes this.
  6. Jan 30, 2017 at 8:46 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    There was just a fella a couple weeks ago on here swapping a complete elock axle under his truck. You dont need the complete oem wiring harness either. Just a switch a bit of wire and (i think) a DPDT(possibly even just a dpdt switch is all that'd be necessary but akways good to have a relay) relay since polarity needs switched to run the actuator for the locker. It really is easy!
  7. Jan 30, 2017 at 8:47 PM
    757yotas
    Virginia
    2007 TRD Sport
  8. Jan 31, 2017 at 8:16 AM
    Wulf
    Wulf no brain just damage
    rock raisin
