Rear Locker Diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thumper06, Apr 1, 2010.
  1. Apr 1, 2010 at 4:13 PM
    Thumper06
    Thumper06 [OP] Active Member
    David
    Arizona
    06 Double Cab 4x4 TRD
    Rear Locker Differential, 3" Revtek Lift Kit, K&N Filter
    Sorry it this has been answered B4, I've done a search but haven't found it.
    I just bought my 1st Toyota, an 06 Tacoma SR5, TRD off-road, double-cab short bed with 3" rev-tech lift kit, K&N Filter. Other than that it's pretty stock with 39K miles. Pardon if this is a dumb question but can the rear diff be locked in 2WDH or does it need to be in 4WD? I haven't had it in slippery conditions and haven't wanted to try on pavement so I figured I'd just ask the experts out there.
    Also, is the locker air activated or electronic?
    Thanks
  2. Apr 1, 2010 at 4:14 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    it can be in 2x4
  3. Apr 1, 2010 at 4:15 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    locker is electric and will only work in 4 low
  4. Apr 1, 2010 at 4:15 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    You gotta be in 4x4 low until you do this one mod for it then it can be used in 2x4.
    Oh if you haven't looked in the AZ section we are doing a Mod day / BBQ if you want to come out.
  5. Apr 1, 2010 at 4:27 PM
    Thumper06
    David
    Arizona
    Thank you all; I didn't even realize there is an AZ section, I'll look for it. It seems that you don't all agree on when the locker engages but 2 out 3 say in 4WDL only.
    Thanks again
  6. Apr 1, 2010 at 4:31 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Factory it is ONLY in 4x4 low. But there is a mod that you can do that will allow you to engage it in 2x4 or 4x4 high.
    AZ Section
    http://www.tacomaworld.com/forum/arizona/
  7. Apr 1, 2010 at 4:39 PM
    Thumper06
    David
    Arizona
    Thanks amaes, I'll check it out.
  8. Apr 1, 2010 at 9:49 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    It is stressed the rear locker is for getting unstuck or out of a situation only when you have 4WD... so, it will only work in L4 and engaged while you are stopped. I used it many times for steep hill climbs with my '01 and '05 Tacomas.
    I do not know what it is limited to on the 2WD Tacomas that come with it. I briefly toyed with the idea to do the MOD. described here in TW to get it to work in 2WD... until I realized that the AUTO LSD MODE ('09 +) is pretty close to the locker action in 2WD. Seriously, if you can just put it in H4 if your tires slip and solve the problem, no need for a 2WD locker for us 4WD trucks... right?
    As for us '09 + Off Road 4WD Tacomas... well NINE drive modes is enough! LOL
  9. Apr 2, 2010 at 11:00 AM
    Thumper06
    David
    Arizona
    Well as I understand it, in stock condition the locker will only engage in 4WDL. What I was hoping is the if I'm out doing mild off-roading in 2WD and momentarily get stuck, all I'd need do is push the locker button, get unstuck, turn it off and be on my way. Sounds like unless I do the mod; I have to fiddle with that silly 4x4 twist dial, shift into neutral and wait for 4WDL to engage (at which point I probably won't need to engage the locker anyway) get unstuck and then reverse the silly dial process. Not a big deal, just learning what my options are with my "new" truck.
    Thanks
  10. Apr 2, 2010 at 11:07 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If a 5spd prerunner has a locker then where does it have to be to be engaged?..............and nobody say offroad please :D
  11. Apr 2, 2010 at 11:09 AM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Anytime man. With a prerunner it doesn't matter. and we can go faster with it on.
  12. Apr 2, 2010 at 2:51 PM
    David K
    Hi David,
    I had an '05 and now a '10 both with the dial 4WD selector... and there is nothing EASIER than to get into H4... FAR, FAR easier than locking the rear end, and H4 engages every time.... but L4 and the RR Locker often take a couple of attempts as well as stopping, etc.
  13. Apr 2, 2010 at 2:54 PM
    David K
    What does your owners manual say about using the locker in 2WD... I am sure I can go as fast as I can with the rear locked in 4WD, but it goes against the factory recommendation...?
  14. Apr 2, 2010 at 2:56 PM
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    In the prerunner we don't have to be in low gear to have it on. I'm done 60 through a wash with it on before. and anytime I'm in the sand I keep at a pace of 20-30 with it on. THe manual states to use it when stuck in mud.
  15. Apr 2, 2010 at 3:16 PM
    David K
    Well that's what our manual says too... so you should NOT be using the rear locker anytime you want, either... It is just a traction enhancement to get you through a difficult section of terrain.
    Perhaps it physically will work fine at 60 mph, but there are steering issues with lockers, so Toyota may be just protecting itself and its truck owners.
    We with 4WD have AUTO LSD in H2, H4, L4, A-TRAC all to use before the RR Locker would be suggested... all the other traction modes being prefered over the locker.
    Interesting...
  16. Apr 2, 2010 at 4:03 PM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    I have an 07 with the locker mod done,And find it handy for situations I encounter on damaged fire roads and off road trails.I had a detroit locker in my 91 and got use to making a trail a challenge using only 2wd.The mod is like 10 bucks and 10 minutes,plus since you already have it on a simple push of the clutch puts you locked in 4lo to stay moving.
