Rear lowering only leveling Kit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lugnuts088, Apr 5, 2019.
  1. Apr 5, 2019 at 6:14 PM
    lugnuts088
    lugnuts088 [OP] Member
    2018 Blue Tacoma Sport
    Is there a kit out there that just lowers the rear to level the truck? Every kit I find raises the front. I just want to lower the rear as I very rarely will be hauling over 400-500 pounds in the bed so there is no reason for the extra height.
    All the lowering kits I find, lower the front too. Am I a niche market here?
    Any ideas would be appreciated!
    Thanks in advanced.
    AlanKidd22Taco likes this.
  2. Apr 5, 2019 at 6:31 PM
    ferntr33
    ferntr33 Well-Known Member
    Never thought about that. I wonder if there is a shackle change you can do. Though it will cost more than a little spacer for the front. I’m in a similar boat. I’m gonna do a 63” leaf spring swap and want to keep lift under 2”
  3. Apr 5, 2019 at 6:32 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    o_O
  4. Apr 5, 2019 at 6:34 PM
    Shellshock
    Iowa
    Just drive around with some weight in the back for a while. Before long the springs will sag, then you can remove the weight and you’ll be set!
    outlawtacoma, YF_Ryan, inksin and 3 others like this.
  5. Apr 5, 2019 at 6:40 PM
    TacoTheTaco
    TacoTheTaco Well-Known Member
    DC
    2018 TRD Sport 4x4 DBL Cab
    I’m all for the sport truck look, but a Tacoma? :violent:
  6. Apr 5, 2019 at 9:36 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    I looked into this too and couldn’t really find a way to lower the rear. Maybe some other can chime in. I ended up going with a spacer in the front.
  7. Apr 5, 2019 at 9:50 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Yup. Throw some sand bags back there...
  8. Apr 5, 2019 at 9:51 PM
    JCOOR
    TRD Burglar
    Could probably pull one of the leafs from the pack
    Wulf likes this.
  9. Apr 5, 2019 at 9:52 PM
    eon_blue
    Azusa, CA
    Remove a leaf? Not sure how much that'll drop a 3rd gen or how much is needed to level it, but generally it's the easiest way to lower the rear aside from putting a bunch of weight back there.
  10. Apr 5, 2019 at 10:40 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
  11. Apr 5, 2019 at 11:36 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    That only works for spring under axle setups. We have a spring over axle setup hence the reason people put blocks to lift the rear.
    Siblue and BadCow like this.
  12. Apr 5, 2019 at 11:44 PM
    wood714
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    Shit...forgot about that.
    inksin[QUOTED] likes this.
  13. Apr 6, 2019 at 12:36 AM
    inksin
    Hawaii
    Haha, I figured you knew that but the brain farted
    BadCow likes this.
  14. Apr 6, 2019 at 5:03 AM
    BadCow
    BadCow Well-Known Member
    David
    2019 Tundra TRD PRO Super White
    Nothing like a Bonafide Brain Fart.
    inksin and TacoTheTaco like this.
  15. Apr 8, 2019 at 8:01 AM
    lugnuts088
    Sorry I should have put it in my OP that blocks don't work on our Tacoma's for lowering. My last vehicle I messed with the shackles and the blocks to get it at a height I liked.
    The drive around with a load in the back defeats the purpose of lowering the rear of the truck for me , trying to squeak out more MPG. While the bed cover helps, I think getting the rear down 1-2" will help some more. Not going for sport truck look at all, just I have no reason for the rake.
    I might look into the spring pack. It scares me removing a leaf as you really mess with suspension dynamics then. Looking at the lowering kit SOS Performance offers https://drive.google.com/file/d/0B_Kt2Q_-iRXpZW9GMHA1a3NEUFk/view , looks like it takes shackles, perches and u-bolts to lower the rear. But no one offers just the rear at a height to make the truck level. I might just bite the bullet and lower the whole truck. Figuring my Chevy Luv could make it through 12" of snow, a slightly lowered 3rd Gen Tacoma should have no issues either.
    P-Dawg likes this.
  16. Apr 8, 2019 at 10:44 AM
    inksin
    Hawaii
    If you will be rarely carrying weight in the bed then pull the bottom overload spring. That'll drop it about 1/2 inch without affecting ride quality as I think that leaf only engages when under heavy load. If you want more drop and don't want to put weight in the bed to let it sag over time then go on CL or something and find a used set of springs that have sagged already and got swapped out for a new set of Dakars or something
    lugnuts088[OP] likes this.
  17. Apr 8, 2019 at 12:41 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    I far as I can tell it looks like the lowering kits I'm seeing are 2in drop on the front and 3.5in on the rear.. I would try and call one of these companies and see if they could sell you just the rear hardware. The difference in drop seems to be 1.5in more on the rear then the front so I'd add a 2in lift block on the rear.. at least in my mind that should yield you a 1.5 in drop without having to lower the front axle..
  18. Apr 8, 2019 at 1:17 PM
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    Maybe you can buy a lowering kit for 2inch drop and add a block 1inch for only a 1 inch drop.
    Cheapest and easiest is to buy 5100 and raise the front, but i know you dont want to do that.
  19. Apr 8, 2019 at 2:15 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
  20. Apr 8, 2019 at 3:06 PM
    inksin
    Hawaii
    That lowering kit flips the axle to run on top of the springs. yes, It'll lower it 3.5 inches but you can't run blocks to lift it up any higher after that cause the axle is on top of the spring. You could probably use an AAL to lift the back up some but you stiffened up the ride a bit and would want to put some sandbags or something in the back to make it ride better (which OP already said he doesn't want to do)
