Rear LT Tundra Axel swap
Discussion in 'Long Travel Suspension' started by Only Danks, Jan 14, 2014.
  1. Jan 14, 2014 at 2:45 PM
    Only Danks
    Only Danks [OP] TRUKWERX : Desert Racing Products
    Bryant
    San Diego, CA
    05 Black TRD O/R 4x4
    3" MID-TRAVEL LIFT: Fox 6x2.5 Front RR C/O's, Fabtech unibal UCA, Fox 10x2 Rear RR Shocks, All-Pro Leaf Pack, Fox 2x2.5 Air Bumps all 4, Strapped all 4, TC Gussets:, Lower Arm Cam Tabs, Front C/O Bucket Tower, Spindles, OTHER: Custom Front Bumper skid, Custom Rear Tube Bumper, McNeil Racing 3" Fiberglass Fenders, McNeil Racing 4" Fiberglass TT Bedsides, 2 Matching Vertical Spares, GrillCraft black mesh, 07 LED Tails(black), Headlights (black), Viper 5204 Alarm, Remote Start, Cobra 19 CB Radio, 6 ft Red LED Firestick Whip, High-lift jack, Black Emblems, STEREO: Custom Nexus7 inDash, Rockford 3sixty.3 to SPDIF, Rockford T1 6.5 Comp Front, Rockford T1 6x9 rear, Rockford PBR300x4 Amp, Rockford P310 (x2) rear seats, Alpine 1100w amp, USB DAC via SPDIF, USB Audio ROM, FUTURE MODS: TC +2" LT Kit, 8" LT Coilover, 16 Rear Piggys, L/T CV Axle Shafts, Heim Steering, DMZ SUA kit, Bedsaver cage, Shackle Crossmember, Motor Mount Gussets, Box Frame
    Are there any issues or concerns with a rear tundra axel swap to match to front +3.5" kits. Not an expert, so maybe there's some things i need to consider...?
    I believe 1st gen tundras are 6 lug 5.5" pattern like the 2nd gen tacomas..
    But are they 7" wider than 2nd gen tacomas or 1st gen?
    Can i just weld my spring perches on and bolt on my leafs?
    If nothing else i figure some sensor or combobulator will throw a code..
    I'm coming up short on literature with my search button, please school me,
    Has anyone done it?
    Seems like most of you LT guys are running rear wheel spacers?
    anyone with over 1.5" spacers ?
  2. Jan 14, 2014 at 3:16 PM
    Supermoto
    Supermoto Well-Known Member
    Landon
    Encinitas/San Diego
    The tundra axle is only like an inch wider than your axle
  3. Jan 14, 2014 at 3:24 PM
    Findus11
    Findus11 Well-Known Member
    Durango
    2012 TRD DCSB
    1.5'' spacers in the back here, would not go wider.
  4. Jan 14, 2014 at 3:35 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 4x4> 03 SR5 4x4 total> 14 Crewmax TRD
    Had tons on the old Taco's.... new Tundra is pretty stock
    This.
    66" 1st gen Tundy vs 65" 2nd Gen Tacoma.
    1st gen Tacoma is 60" though so it matches LT kits on 1st gen's well, in which case it's pretty much set up spring perches and drop it in I believe.
    Jberry813 did the swap in his LT 1st gen.
  5. Jan 14, 2014 at 9:29 PM
    Anthony250
    Anthony250 E-Fabber
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    TC Kit, Methods Double Standards, Sway Away, King Shocks. Prp Seats, 35's
    Every person with a 05 up taco runs wheel spacers to clear shocks, nobody runs a tundra axle becuase its not worth it only roughly a inch wider per side.
  6. Jan 15, 2014 at 2:01 PM
    Only Danks
    Bryant
    San Diego, CA
    ok thanx for the info guys,
    i assume the 2nd gen tundra axel is longer but the lug pattern makes that swap impossible?
  7. Jan 15, 2014 at 2:03 PM
    Only Danks
    Bryant
    San Diego, CA
    so the mismatched track width isnt a big deal?
  8. Feb 19, 2014 at 10:17 AM
    Findus11
    Durango
    2012 TRD DCSB
    no but you will never be able to drive a straight line ever again :p
  9. May 10, 2016 at 8:43 PM
    06HAOLE
    06HAOLE Well-Known Member
    Sherman Oaks, CA
    Yes
