Rear main seal leaking
Discussion in '4 Cylinder' started by Slick8810, May 8, 2009.
  1. May 8, 2009 at 8:40 PM
    Slick8810
    Slick8810 [OP] Well-Known Member
    Panama City, FL
    01 Tacoma Prerunner SR5
    3" lift, 20% tint, billet grille
    I was wondering if anyone has had any oil leaks with there 2.7l before. Mine has a very small oil leak that looks like the rear main seal. it takes literally 2-3 months to even move on the dipstick thats why i havent messed with it yet but i can see it on the engine block when i get under the truck. it now has 125,000 miles.
  2. May 9, 2009 at 5:58 AM
    river rat
    river rat Tool Geek
    Midwest
    '11 Timberland Mica regular cab.
    I haven't heard of these leaking on 2.7s but anything can wear out on any individual engine, I suppose.
    Might be a good time to put in a clutch if you have a manual trans, and replace it while you have it exposed.
    If you have an auto, I'd just keep an eye on it until it really needs replaced. Unless you're afraid it will suddenly blow your oil.
  3. May 11, 2009 at 8:55 PM
    wawireguy
    wawireguy Well-Known Member
    125K and a minor leak.. Keep on driving!
  4. May 12, 2009 at 10:10 AM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    My 04 Tundra had a very small leak at same approximate area and it appears it was from a quality issue on assembly line. It seems the sealant was not applied correctly around pan to block area and caused a misting/weepage of oil. Never really left a drop on driveway but was present on block and pan at oil changes. Dealer pulled pan and used correct sealant in right area to solve the problem. Perhaps your Tacoma has same issue.....
    Motoretro
  5. May 12, 2009 at 10:38 AM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    x2
  6. Jun 3, 2009 at 5:52 AM
    1999tacoma
    1999tacoma Member
    i have busted my front right CV axle seal and i drove on for like a week but get it fixed soon man
  7. Jun 3, 2009 at 7:53 PM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    x2 forget aboutit!!! just make sure you are good on oil until you get the funds to repair, or just keep oil in it until you need a rebuild
