Rear O2 sensor bypass/CEL fix.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mod, Apr 17, 2014.
  1. Apr 17, 2014 at 8:53 AM
    Mod
    Mod [OP] Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    First off want to say that someone else figured this out,not my idea, but it was too good to not share on here. Back in about 04-05 I had my catalytic converter sawzall'd off and stolen. On comes the check engine light. Didn't think to much about the light being on because I knew what it was after a very short period of time. Climbing a steep grade with a load and putting more heat on the system, the light would go off. Once crested the hill and things started to cool off,,the light would come back on. Rear O2 sensor sending the signal that something was amiss. Truck never gave me any problems so no need to by a code scanner and I knew what the CEL light was from. (For the sake of arguments, lets say I had a really good idea why the light was on). Anyways,,here we go.
    Radio Shack part #
    1 micro farad cap 272-1055
    1 mega ohm resistors 271-1134
    On my truck there are 4 wires that lead to that rear O2 sensor from the connection plug at the manual transmission tail shaft. 2 black and a sold white and solid blue I split the distance in the length of those blue and white wires and cut them in two at the center. You will probably have to pull back or remove the tubing/covering that covers those wires. I slit that cover down the center with a razor to about 1/2 distance, then cut around it, removing that portion. Snip and strip back the blue and the white wire that leads forward to the connection plug,,I left the two black wires intact and connected to the sensor. The reason I cut the blue and white wires at equal lengths between connection plug and sensor,,was so that they could be easily reconnected again if needed.
    As you see the pic above of the constructed Mod unit:)o),,the right side of the unit connects to the blue wire you cut and stripped back a 1/2",,and the left connects to the white wire that you also prepared the same way. (connection plug side)
    Assemble the unit as you see in the pic noticing lettering up on the blue capacitor and color rings on the resistor. Right side of assembled unit connects to the blue wire, and the left side of above pic connects to the white wire.
    You can solder connections if you wish, or you can crimp connect so long as you have good crimping tools and supplys. I did a little of both. A bead of silver solder was melted by iron down into the bottoms of those crimp connectors you see above. The unit was then crimped and soldered to the prepared blue and white wires down by the sensor that lead to the plug connection
    Snipped white and blue wires leading to the sensor were covered with heat shrink tube. I didn't pull any connection plug or the sensor out of the pipe,no real need because I had the wire length I needed.
    Total cost to turn out the check engine light due to a rear O2 sensor code,,about $4.
    Pull battery connections BEFORE you start cutting. Not a bold typed set in stone rule,,but It's the way I did it. The ECU will need a reset anyways after doing the work.
    I'm no electronics expert so keep the questions with that in mind.
  2. Apr 17, 2014 at 8:58 AM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Good stuff. Might end up going this route.
  3. Apr 17, 2014 at 9:20 AM
    Mod
    CR, WA
    stock
    Thanks. It's really easy and cheap and you can re connect those wires if needed.
    If the CEL light stays lit after doing this, then you might have another code waiting to be read.
  4. Apr 17, 2014 at 7:29 PM
    Mod
    CR, WA
    stock
    About 4 days on this,,so far no light.
  5. Apr 24, 2014 at 2:45 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    hmmm.. my rear o2 sensor was recently broken off when a rock pushed my exhaust piping up into the bottom of my cab.. this might be a good route to take.
    any idea if it will work w/ my auto trans? any difference in wiring?
  6. Apr 24, 2014 at 5:20 PM
    Mod
    CR, WA
    stock
    Rock auto shows a 4 wire heated sensor,,so I think it would work. Can't say for positive because mine is manual. The part numbers don't match between yours and mine on the sensor.
    Easy to slit the covering/insulation that covers the wires to the sensor and see if you have 2 black, a white and blue wire. So long as that sensor wasn't mashed heavy on the rocks, and the heated circuit on it is still good.
    After some more fine print reading, I am leaning twoards that heated circuit being intact and doing it's thing at the sensor.
    So far, no CEL and damned if it didn't help the idle/warmup. I am idling down in about 45sec, compared to a full minute. Might be the season change.
    $4 in one hand,,and a whole bunch in the other to fix it. Pretty easy choice or check.
    If you give it a shot, please say so and the outcome. Thanks all.
  7. Jun 24, 2014 at 10:24 AM
    dan476
    dan476 Well-Known Member
    Hey, you mentioned that someone else figured this out, do you by any chance have original link? Also how is it working now? Any fuel mileage increase? Thanks.
  8. Jun 24, 2014 at 2:45 PM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    I did this and didn't have any luck. Maybe someone can point out where I went wrong? FWIW I got the URD sim kit and haven't had a problem since. :confused:
    And yes I taped everything up after this.
  9. Jun 24, 2014 at 3:28 PM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, easy-out heavy duty tonneau cover, sliders, hood/bed lighting, always-on 12v outlets, dashcam, 3G remote start/security system
  10. Jun 25, 2014 at 5:29 AM
    dan476
    After doing some research I'm seeing that capacitor goes between blue and white wire, resistor thought has to be on blue only below the capacitor. That could be your issue.
  11. Jun 25, 2014 at 6:19 AM
    mustangstephen
    Stephen
    by da creek
    02 Tacoma TRD
    :shrug: I've had the URD sim in for over a year now. I'm not going to pull it out and try anything else. Just figured I'd share my experience.
  12. Jul 5, 2014 at 8:02 AM
    Mod
    CR, WA
    stock
    Stephen, did you unplug the URD sim from the system before the adaptation for the radio shack stuff?. Never had one of those so I don't know where they plug in at.
    I disco'd the radio shack setup, just to see if it kicked the cel light back on,,and it did as I kinda knew it would. Reconnected that and reset the ECM, light went out once again.
  13. Jul 5, 2014 at 1:10 PM
    mech160
    mech160 Active Member
    50th
    1995.5 Tacoma
    Tried the "hot rod/heavy mod" scene for decades. Can't beat a clean, all original, factory specs vehicle.
    sub'd
  14. Jul 6, 2014 at 5:45 PM
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    '99 4Runner
    231mm Tundra Brakes B&M 70264 Transmission Cooler
    May have to try this on my 4Runner. I've got the dreaded P0420 coded that I've pretty much ignored for 2 years.
  15. Jul 6, 2014 at 5:51 PM
    thekidcatcher
    thekidcatcher Well-Known Member
    Waco, TX
    05 TRD offroad SR5
    Legs- --Helo rims --Duratrac 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    Got mine after adding a full JBA exhaust kit, definitely going to try this!
  16. Jul 6, 2014 at 5:54 PM
    thekidcatcher
    Waco, TX
    05 TRD offroad SR5
    Dang it, its only 1st gen isn't it.
  17. Jul 23, 2014 at 12:13 PM
    Mod
    CR, WA
    stock
    Pimpin my own thread,,to keep it at the top unashamedly.:rolleyes:
    It might work with a 2nd gen,, but cant verify. A few bucks and some time is all it takes. Work smart and it a easy reversal if needed.
    No codes or cel so far, still truckin along.
    MoreMonkey likes this.
  18. Jul 23, 2014 at 3:53 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I'd be curious to see air fuels. The rear narrowband o2 sensor is used not just for cat efficiency, but to calibrate the forward primary wideband sensor on 01+ Trucks and 98 or something 4runners. That means if the solid state components are not finely selected, IMO it may be able to pass you on your cat diagnostics, but could be throwing off air fuels a bit.
  19. Jul 24, 2014 at 12:55 PM
    Yoda the Taco
    Yoda the Taco Well-Known Member
    Chase
    Kingsport
    Majestic White Stallion
    00 front end swap 3 inch spacer/block 01 dash swap Flux capacitor 04 center console tach cluster swap avatar-10 hyperdrive 02 door panels powerlocks/keyless entry electric fan swap 4runner seats
    Mod
    Dumb question, but is it the blue wire that needs to go on the red stripped side of the resistor? My brain is fried from work, so I just wanted to ensure before I give it a go. Also, any noticeable loss or gain of MPG? Thanks :D
  20. Jul 24, 2014 at 12:58 PM
    Robb235
    Chattanooga, TN
    '99 4Runner
    Never heard of this before. I've always heard that the rear O2 did not have any bearing on fuel trims.
