REAR PASSENGER SIDE WHEEL LOCKED UP!!!!!!!!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HumanityForPresident01, Apr 10, 2018.
  1. Apr 10, 2018 at 5:12 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I'm not mechanically inclined so when they completely break, I'll take the truck to a mechanic. They are completely fine except for those few events.
    I could be wrong but I believe the exact issue was the shoe was seizing to the drum. Water couldn't drain out from the drum and when parking brake was applied, the shoe and drum seized.
  2. Apr 10, 2018 at 5:14 PM
    forana
    Kaneohe, Hawaii
    I should also add that I pushed for the rear brakes to be replaced since it was under warranty and also the second time I had to tow it to toyota.
    It took 2 days to get fixed, they had to send pictures off to somewhere (headquarters?) to see if it warranted replacement but OF COURSE IT DIDN'T.
  3. Apr 10, 2018 at 5:20 PM
    Clearwater Bill
    Billy
    Largo Florida
    That was at 10:30 ish this AM.
    Didn't you get a call?
  4. Apr 10, 2018 at 5:24 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Shhhh, sleeping
  5. Apr 10, 2018 at 5:26 PM
    POi_YOTA
    POi_YOTA Member
    Jdf
    88 t4r SAS , 2013 access cab TACOMA, 2000 T4R
    If you're familiar with the rear brake components in the tacoma .. the spring on the bottom has a guide of some sort and I pretty sure it catches on that guide ....
  6. Apr 10, 2018 at 5:28 PM
    POi_YOTA
    POi_YOTA Member
    Jdf
    I had a 2014 a couple years ago and it happened a couple times , did the brake trick and it released.. no extra maintenance
  7. Apr 10, 2018 at 5:30 PM
    POi_YOTA
    POi_YOTA Member
    Jdf
    AND AGAIN I've seen it happen to tacomas mostly at the beach I go to ....
  8. Apr 10, 2018 at 5:38 PM
    forana
    Kaneohe, Hawaii
    Mine was beyond the spring getting caught.
  9. Apr 10, 2018 at 5:55 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    In the first post OP claims to take meticulous care of his truck but usually when the brake gets stuck he just gasses it and it breaks loose. When something goes wrong with my truck that I take reasonable care of I figure out what is wrong and fix it. Gassing it to get it to break loose isn’t what I would call meticulous care. Hope you get it fixed.
    Hawco636 and POi_YOTA like this.
  10. Apr 10, 2018 at 6:04 PM
    forana
    Kaneohe, Hawaii
    I can relate to OP. I take really good care of my truck. First few times this happened, the brake was clearly stuck but upon giving it a little more gas, it'd pop loose and be fine. Sometimes it'd pop loose fairly easy, sometimes needed a little more gas. So I don't think we can make judgements by what the OP tried to do. I'm sure his struck is well cared for.
  11. Apr 10, 2018 at 6:15 PM
    L J
    Illinois
    I’m not convinced by your argument. Having to give it a little gas sometimes and more other times indicates a chronic problem. But I digress...it’s your truck do whatever makes you happy. I’d rather fix it and move on. Not saying I’m right but that’s my process.
  12. Apr 10, 2018 at 6:25 PM
    ryanshougo
    ryanshougo Member
    Oahu
    08 Super White DCSB 4x4
    Happened to me mulitple times. Usually after i washed my truck and parked it with the parking brake engaged. I learned after a couple times of it happening to not engage the parking brake after washing it. I feel like i read somewhere on here that its a combination of the brake dust, water, flash rust and the parking brake being engaged that causes that mixture to be almost like a cement/glue mixture that causes it to lock up. I replaced the rear drum brakes, shoes and hardware with new and it has not locked up since.
  13. Apr 11, 2018 at 3:52 AM
    HumanityForPresident01 [OP] Let 'er eat
    Trevor
    2006 Dark Blue Tacoma V6 SR5 EXT Cab TRD Off Road
    2.5" rancho 9000xl lift with UCA's, custom rock sliders, custom rear tube bumper, road armor front bumper, k&n air intake, winch, lights etc.
    holy cow, i'll have to read all these replies when i get home today but as an update: I had it towed to a local garage and they confirmed that my parking break cable seized in place. I've been driving in a lot of salt because of winter. My truck is getting both passenger and drivers break cables today. parts labor and towing is 440$.
    thanks everyone! i love you guys.
  14. Apr 11, 2018 at 4:26 AM
    Awsomeo67
    Awsomeo67 Well-Known Member
    08 reg cab long bed
    It happens to semis all the time even not in salty climates the drums rust to the shoes. Driving with the axles locked usually breaks them free but if not you just beat the drum with a hammer with the parking brake released to free them
    Canoehead likes this.
  15. Apr 11, 2018 at 5:01 AM
    #35
    Blandino
    Blandino Well-Known Member
    Damien
    2011 Double Cab Tacoma
    Whistle Tip Exhaust
    No issues so far out of my 4runner rear disc conversion...
  16. Apr 11, 2018 at 5:01 AM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    Thanks for letting us know the result.
    Now then, I'd be doing some serious frame inspection. I'm not talking about sticking your head under and peeking.
    I'm talking probing with a pry bar, banging with a ball peen, inspecting the insides with a borescope.
    What that much corrosion on a semi sealed system (sheathed brake cable) that should have been regularly washed and lubed under the meticulous care plan, the frame could be in trouble.
  17. Apr 11, 2018 at 5:04 AM
    #37
    Clearwater Bill
    Billy
    Largo Florida
    His ebrake cables failed.
    Yours can too.
  18. Apr 11, 2018 at 5:10 AM
    #38
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Waste of time and money on your part, but okay.
  19. Apr 11, 2018 at 5:12 AM
    #39
    TacomaMike37
    13' DCLB MGM
    Fix what? It happened to my brand new truck. Gave it some gas and it moved. Happened again two years later. YOu are making a mountain out of a mole hill.
    forana likes this.
  20. Apr 11, 2018 at 5:33 AM
    #40
    Blandino
    Damien
    Whistle Tip Exhaust
    What e-brake cable?
