Rear passenger wheel locked
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djadonis206, Feb 18, 2018.
  1. Feb 19, 2018 at 7:26 AM
    djadonis206
    djadonis206 [OP] Well-Known Member
    2016 Black Tacoma SR5
    In the video, the truck is in 4Lo. Finally filmed after trying for about an hour to get the wheel unlocked.
  2. Feb 19, 2018 at 7:29 AM
    djadonis206
    Honestly, I just need a good stretch of dry pavement. Unfortunately, the temps are going to continue to drop for the next few days.
    I have to wait until tomorrow to get a tow truck up there. The upper lodge is closed on weekdays. The tow will have room to get my truck up on a bed. They’ll tow it to the low lands. I’m pretty positive it’ll roll away.
    The problem is, I can’t drive my truck in cold weather anymore.
  3. Feb 19, 2018 at 7:30 AM
    corprin
    corprin Well-Known Member
    corprin
    Where do you live, and is this your first expierence with these conditions and this truck?
  4. Feb 19, 2018 at 7:31 AM
    Brenden J
    Brenden J Well-Known Member
    Brenden
    2016 Tacoma TRD sport
    Same thing happened to me back in January. Try and wiggle your parking brake line that runs into the rear drum. Thats what did it for me. Dealer said its because my new leaf springs from the lift doesn't have that little cable bracket, its causing my brake to lock up (which is bullshit in my opinion). Basically when I would release my parking brake, the releasing motion wouldn't travel all the way back to the drum so I had to manually wiggle it myself. Hope this helps
  5. Feb 19, 2018 at 7:31 AM
    djadonis206
    Washington state. This is the 4th or 5th time it’s happened. Took it to the dealership last time. I was told the locked wheel is a result of the type of differential I have to get better tires.
  6. Feb 19, 2018 at 7:40 AM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    Yus. Lift it at the pumpkin with a garage jack and try to spin or take a hammer to the drum to break ice if there buildup.
  7. Feb 19, 2018 at 7:42 AM
    Comatose
    Miguel
    San Diego, CA
    Kinda brings a whole new meaning to Locking Rear Differential.
  8. Feb 19, 2018 at 8:02 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    They need to replace that brake assembly and drum (if they are too ignorant to diagnose this one) and check the e-brake cable adjustment. Drum brakes have been around forever. Yes, they OCCASIONALLY lock up, but if they had been locking up this regularly for the 100 years they have been used...well, they would never have been used for 100 years.
    Seems like they are trying to tell you that you should expect to have to drag the ass end of the truck around for some period just to get it to operate. Insanity. Passenger cars with smooth low rolling resistance tires have NO issue with this. They don't even have a driven rear axle!!
  9. Feb 19, 2018 at 8:30 AM
    trdt44
    trdt44 Well-Known Member
    Trent
    Utah
    2017 Tacoma TRD OR
    I had this happen a few times in my 1st & 2nd gen. It usually would happen after driving at night when there was moisture and then parking at camp. To minimize it I make sure to not use the emergency brake but then it would still lock up sometimes. Maybe you could pull emergency brake a little bit and let it drag before you parked. It might warm it up enough to remove the moisture.
    BillsSR5 likes this.
  10. Feb 19, 2018 at 8:50 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Your going to have to determine if the parking brake cable is sticking or the shoes are freezing to the drums. If the shoes are freezing have the dealer remove the drum and clean out the drum with brake clean. Then brake clean the shoes and hardware. Lightly sand the shoes with some medium coarse sand paper. Moisture combines with the brake dust to cause the issue. Reinstall and everything should be fine.
  11. Feb 19, 2018 at 9:19 AM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    If the brake is the problem why does the tire look like it moves a little before it stops rolling?
  12. Feb 19, 2018 at 9:24 AM
    Heepspo
    Heepspo I wouldn't say I'm missin' it, Bob...
    Washington State
    2016 TRD OR DCSB, Prem & Tech w/JBL, Towing
    Fuel Vector D600 17" Wheels, Toyo 285/70-17 AT2 Tires, Tuff Country 52907 3" Leveling Lift, Full Katzkin Leather (Black with Platinum Stitching), SOS Concepts Streamline Front Bumper, 3M Scotchgard PPF, "no vtec 4me" BHLM, Husky X-act Contour Floor Liners, Cali Raised Faux Pro Grille, Predator Sliders, WeatherTech Mudflaps, UnderCover Ultra Flex Tonneau Cover, OEM Bed Mat, Headlight Revolution Supernova V.4 Headlights/High Beams & Carbide Canbus 2.0 Amber LED Front Turn Signal Bulbs, Salex Console Organizer, Rhino Seat Belt Extenders (removes annoying dinging), 15% Window Tint, JDM ASTAR 800 Reverse Lights, LED Interior Lighting Package, Stant Locking Gas Cap, Redline Tuning QuickLIFT PLUS Hood Struts, Gentex Compass Mirror w/Homelink, mesojdm Ultimate Turn Signals, Hondo Garage Un-Holey Dash Mount and AR15 Bolt Radio Knobs, CBoy808 Custom Bedside Decals and Flags, De-Badged Doors, Tailgate and Interior Visor Stickers.
    :rimshot:
  13. Feb 19, 2018 at 9:34 AM
    pjensen641
    Boone, IA
    Drum brakes have a certain amount of backlash due to the self energizing mechanism. Also, there would be a little axle wrap going on as well.
  14. Feb 19, 2018 at 9:37 AM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Toyota is so lame for still forcing us to have these dinosaur drum brakes
    Syncros likes this.
  15. Feb 19, 2018 at 10:04 AM
    #35
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I knew that was coming.
    stu8319 and Taco Addiction like this.
  16. Feb 19, 2018 at 10:15 AM
    #36
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    You were forced into buying a truck?!
  17. Feb 19, 2018 at 12:01 PM
    #37
    Syncros
    Syncros Well-Known Member
    Yeah it definitely wasn't ideal. They would get jammed with dust & sand in the summer time too.
    Damn, that's no good. Mine always broke free but it was a 2nd gen, so maybe a bit different.
  18. Feb 19, 2018 at 1:32 PM
    #38
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    The 2nd gen has the same brakes as the 3rd gen.
  19. Feb 19, 2018 at 2:49 PM
    #39
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What he do, blow on it? Maybe Toyota will issue the TSB using official hand warmers and duct tape for the drums :)
    FMRAV4 likes this.
  20. Feb 19, 2018 at 4:36 PM
    #40
    Syncros
    4.0L has enough low end to overcome the brakes..
    :stirthepot: :luvya:
    Superdave1.0 and svassh like this.
