Rear Passenger Window will not move - Replaced motor and switch - still fails - Ideas? - 2014 DCSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UBYBC, Aug 5, 2019.
  1. Aug 5, 2019 at 7:55 PM
    UBYBC
    UBYBC [OP] Well-Known Member
    2014 Tacoma TRD OR
    Rear passenger window was stuck down.
    I checked the fuses, replaced the rear passenger window motor and it starting working again.
    It was good for a month and got stuck up for a second failure.
    I checked the fuses and just tried replacing the drivers power window switch panel and still no luck with the window operating.
    The rear passenger switch will go down but not back up. So right now the windows is about an inch down.
    Any good further troubleshooting ideas to share? Thanks.
  2. Aug 5, 2019 at 10:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This may help:
    http://www.customtacos.com/tech.old...toyewd/06toypdf/ewd/2006/tacoma/h/em01d25.pdf
    TnShooter likes this.
  3. Aug 5, 2019 at 11:45 PM
    Muddinfun
    Muddinfun Well-Known Member
    The rear door switch panels are the same. Swap them and see what happens.
  4. Aug 7, 2019 at 1:05 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Seen corossion on those rear switches plenty of times. Like above said, swap the switches side to side and see what happens. Next time try that first
    Also check for corossion on the connector
  5. Aug 7, 2019 at 2:32 PM
    UBYBC
    2014 Tacoma TRD OR
    After giving the switch hell it went back up, but now stopped operating again. Thanks, will try the switch swap this weekend.
  6. Aug 7, 2019 at 2:35 PM
    Superhulk LB
    Superhulk LB Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    In the meantime have someone engage the rear switch to go up while doing the same at the driver switch.
    Had this happen a few times on my 2007 taco and that got the window back up.
  7. Aug 7, 2019 at 4:37 PM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    Had same problem. Take apart the switches and clean the contacts.
  8. Aug 7, 2019 at 6:00 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
  9. Aug 15, 2019 at 10:33 AM
    UBYBC
    2014 Tacoma TRD OR
    swapped the rear door window switches and all switches are now working. Go Figure! You would think on a tough truck like this the switches would not be so unreliable for such a critical component of the truck. Going to take them all apart and clean the contacts except for the drivers door which is brand new. Thanks for everyones help, all the suggestions couldn't have been more helpful. Thank you.
    Muddinfun likes this.
