Rear rake after TSB and 5100's set at 1.75"???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kalei Aloha, Dec 15, 2011.
  1. Dec 15, 2011 at 6:35 PM
    Kalei Aloha
    Kalei Aloha [OP] Member
    Northern California
    2011 DCLB
    I just had the dealer install 5100's set at 1.75" and do the TSB rear leaf replacement and it seems to have a rear rake? Has anyone else noyiced this and what are opinions of how to correct it? Possibly add a 1"block in the rear.... or remove front 5100's and set to .85" and reinstall???:confused:
  2. Dec 15, 2011 at 6:44 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I think I got about 1" - 1-1/2" with my TSB.
    I would try the .85 setting if you have negative rake.
    The other option is to go with the ToyTec 1-1/2" AAL for the TSB spring.
    The TSB ride is a little firmer than stock and the AAL will further stiffen it.
  3. Dec 15, 2011 at 7:54 PM
    Kalei Aloha
    Northern California
    2011 DCLB
    I have 5100's all the way around, and a snug top shell... Which AAL? the 1.5" or 2" or the Wheelers progressive(will it work with the TSB?)
  4. Dec 15, 2011 at 8:11 PM
    coloradotacoma
    coloradotacoma Well-Known Member
    I think I might have a bit of rear rake myself. How are we determining rear rake? Level on the bed rails? Purely visual? Some other method?
  5. Dec 16, 2011 at 5:55 AM
    speedydave
    speedydave Got Boost?!?
    Dave
    Hickory, Nc
    Ecoboost
    That's the problem, the shell. You need a small block or better leaf pack to get back to level. Or set the front a .85.
  6. Dec 16, 2011 at 7:12 AM
    Kalei Aloha
    Northern California
    2011 DCLB
    I'm calling Wheelers today to see if the progressive 3 leaf pack will work with the TSB; anyone have ant experience with AAL with TSB? 1.5" , 2" , or progressive 3 leaf?
  7. Dec 16, 2011 at 10:44 AM
    jflan
    Vancouver, WA
    The progressive should yield a softer ride.
    If they're longer than 28-29" you might have to do some modding to the retainers.
    DownSouthMotorsports carries the Icon 3 leaf AAL - free shipping
    Some have retained the factory overload leaf. I would try for that.
  8. Dec 16, 2011 at 10:52 AM
    Kalei Aloha
    Northern California
    2011 DCLB
    O.K.... I just got off the phone with Down South Motorsports. They said they did not recommend the progressive 3 leaf pack with the TSB and that if I put in the single AAL with the TSB it will over extend my rear shocks, they said a 1.5' AAL and TSB does not work with the Bilstein 5100's. They said it may work b/c of the weight of the shell and/or if I only drive on the street, otherwise I would need another brand of longer rear shocks. I am assuming this would be the same scenario if I installed airbags with rear 5100's and TSB....
  9. Dec 16, 2011 at 10:56 AM
    jflan
    Vancouver, WA
    I wonder why they didn't recommend 5125's which are a custom-length version of the 5100 ?
    Maybe they don't have a single AAL solution and just didn't pursue it further ?
  10. Dec 17, 2011 at 6:55 AM
    speedydave
    Dave
    Hickory, Nc
    Ecoboost
    Did you tell them you have a cap? That will not give you the full lift.
  11. Dec 17, 2011 at 8:27 AM
    tonto340
    tonto340 Well-Known Member
    Gambrills, MD
    I had the dealer in Annapolis install my 5100's at the 1.75 setting and the rear spring TSb at the same time. They installed the spring perches upside down on the 5100s making the front about 2 inches higher than the rear. Once I figured out the problem I went back so they could redo the job.
  12. Dec 17, 2011 at 9:10 AM
    RockRescue
    RockRescue Well-Known Member
    Oregon
    2007 TRD Sport
    Strange becuse my stock Sport 4x4 sits at 20 in the front and 22 in the rear from center of hub to fender . NO TSB . I would think at 1.75 you would be still low in the front with the TSB
  13. Dec 21, 2011 at 9:56 PM
    Kalei Aloha
    Northern California
    2011 DCLB
    I went with the Wheelers 3 Leaf Progressive Add a Leaf(made by Dakar). I placed a jack under the rear trailer hitch and raised the rear of the truck up 1.5" to get a good visual of what it would look like and boy did it look better! So... That being said IMO I think with a camper shell, Bilstein 5100's all four corners, front set at 1.75", TSB, and 1.5" AAL is the way to go!!!
