Rear recovery point
Discussion in '3rd Gen. Tacomas (2016+)' started by Brobrady, Mar 21, 2016.
  1. Mar 21, 2016 at 1:06 PM
    Brobrady
    Brobrady [OP] Well-Known Member
    What does everyone use as their rear recovery point? I was checking out a receiver d-ring but had some concerns about the strength of the receiver. What is everyone using?
  2. Mar 21, 2016 at 1:12 PM
    DrFunker
    DrFunker is Funkified!
    Didums
    Shackle receiver, unless you put a plate bumper on.
    whopper likes this.
  3. Mar 21, 2016 at 1:12 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
  4. Mar 21, 2016 at 1:13 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  5. Mar 21, 2016 at 1:37 PM
    Brobrady
  6. Mar 21, 2016 at 1:47 PM
    geekhouse23
    Thanks been used and abused and has held up phenomenally.
  7. Mar 21, 2016 at 3:15 PM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    Ive used this type for years no issues
  8. Mar 21, 2016 at 6:02 PM
    maccus
    maccus Member
    Custer,SD Black Hills
    2019 Sport TRD
    If you want to go cheap this should work. 9.99 from HF
    D-ring receiver hitch....Harbor Freight SKU 66212
    EDIT....Originally I had a web site click on listed to the above product...........it did not work so just go to HF and enter the SKU and you should see a cheap D-ring hitch.
  9. Mar 21, 2016 at 6:04 PM
    2000TRDTaco
    2000TRDTaco Well-Known Member
    Corey
    Angier, NC
    00 Prerunner
    Your tow hitch is very strong....I have used mine as anchor and recovery points before with no worries
    geekhouse23 likes this.
  10. Mar 21, 2016 at 6:11 PM
    geekhouse23
    I land mine on rocks constantly
  11. Mar 21, 2016 at 7:35 PM
    GrayYota
    GrayYota Well-Known Member
    Todd
    16' 4X4 DCLB Magnetic Gray
    I use the shackle receiver with my hitch.
  12. Mar 21, 2016 at 7:53 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    The rear receiver is very strong, no worries. The front is where the problem is. No good solutions without a plate bumper or front receiver install.
  13. Mar 21, 2016 at 8:00 PM
    geekhouse23
    Jimcho and Krezz like this.
  14. Mar 21, 2016 at 8:10 PM
    qnyla
    NM
  15. Mar 21, 2016 at 8:11 PM
    geekhouse23
    Just means you're using your vehicle for its intended purposes :mudding:
  16. Mar 21, 2016 at 8:18 PM
    GrayYota
    Todd
    I went with the Bullet Proof mount as well, I hope I don't run into problems with it.
  17. Mar 22, 2016 at 4:55 AM
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    I bought that HF D-Ring hitch about four years ago and have used it to pull logs/brush etc on my property. Used it once to get a F-150 out of some deep snow. It's cheap and it works, like most HF products. It's rated for 10K lbs.
