Rear seals "HELP"
Discussion in '1st Gen. Tacomas (1995-2004)' started by Muleman R.D., Nov 5, 2010.
  1. Nov 5, 2010 at 1:37 PM
    Muleman R.D.
    Muleman R.D. [OP] Member
    R.D.
    Arivaca, Az.
    01 SR5 4WD
    Had a local mechanic rplace rear axle seals. 10 months later they are leaking again. Tried a different mechanic and two days later I have a leak both sides. He tried a second time with same results.
    Is there a trick to doing the rear seals ? Should I have to replace the bearings also ?
    I'm trying to save my duckets by not going to the dealership. Should I just knuckle under and go to the dealership ?
  2. Nov 5, 2010 at 2:14 PM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    Check the vent sounds like its building pressure. I bet if you take the vent out it will sound like there is air pressure behind it.
  3. Nov 5, 2010 at 2:36 PM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    I had the same problem on my 2000 taco and found out that the breather was plugged up. do the breather mod on it and it will solve your leakage problem... Of course if the guy cut the seal while installing it then thats a different issue. I install seals on a daily basis and sometimes you just screw up..Always lube the seal lip with oil or grease when installing it...good luck
  4. Nov 6, 2010 at 8:17 AM
    Muleman R.D.
    R.D.
    Arivaca, Az.
    01 SR5 4WD
    Thanks you guys !! I will put my mechanic on straight away.I'll let you know the results.
  5. Nov 6, 2010 at 12:38 PM
    Muleman R.D.
    R.D.
    Arivaca, Az.
    01 SR5 4WD
    I found what I think is the vent cap. Aprox.3/8" pipe thread with a 14mm head and a loose fitting cap on top aprox. 3/4" tall on top of the axle just left of the differential. I removed it and blew thru it. It appears to have a one way valve in it. when I blow through it it makes a popping sound as if it is kinda sticking but it does not take much effort.
    Can I clean this vent or is it better to replace ?
    If it can be cleaned, what should I clean it with ?
  6. Nov 6, 2010 at 6:58 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Extended it up high, off of the axle. It is a common mod to extend the breather. Check this link:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/15223-diy-differential-breather-extension.html
  7. Nov 7, 2010 at 7:52 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    If you pull it apart again look at where the seal rides on the axle itself, if there is a grove in the axle the seal needs to be positioned so not to ride in that groove( dont't press it into the axle tube as far or a little futher pass the groove ) or speedy sleeve the axles.
  8. Nov 7, 2010 at 8:05 AM
    Muleman R.D.
    R.D.
    Arivaca, Az.
    01 SR5 4WD
    Wow !! This site is friggin cool!! As you all can see I am new to Tacoma World. TRD Desert Man turned me onto it at camp last week while we were out hunting. Naturally the conversation went from hunting to the Tacos we both drove. He won the Taco sniffin contest as he is way ahead of me. But give me time, I am now on the journey.
    "Waste Management", "Vidman" thanks. "Digiratus" special thanks ! Those are great pics and ideas on the breather mod. I'm on my way to the parts place now.
  9. Nov 7, 2010 at 9:05 AM
    WASTE MANAGEMENT
    Travis
    Umatilla Florida
    Yeah, this place is great. you can clean that breather with brake cleaner, just keep spraying till clean.
  10. Nov 7, 2010 at 12:46 PM
    Vidman
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    X2 speedy sleeves work wonders
