rear shackles vs AAL for rear lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rob1208lv, Dec 1, 2011.
  1. Dec 1, 2011 at 8:45 AM
    rob1208lv
    rob1208lv [OP] Well-Known Member
    Rob
    Las Vegas
    02 PreRunner V6
    I can't decide on either rear grease-able shackles or AAL for my rear lift.
    Both are priced the same, both seam easy to install.
    From what I have read the Shackles add flex, but I'll have to re-rout my exhaust hanger. And the AAL will Decrease Flex but is easier to install as no re-routing is necessary. Also I currently have the axle wrap mod on the truck, and from what I read, the Shackles will help with axle wrap?
    As for the front I'm just going to do spacers.
    Goals - 2.5" lift front rear, to put bigger wider tires (31x10.5) on truck daily driver hardly off road ..
    Thoughts
  2. Dec 1, 2011 at 8:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd do the AAL because the shackles do increase flex. Increasing the flex will quickly wear out your stock leaf pack. Also, look into 5100's for a front lift instead of spacers. Spacers are cheap and you'll get what you payed for.
  3. Dec 1, 2011 at 10:21 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
  4. Dec 1, 2011 at 10:35 AM
    Pugga
    Massachusetts
    I kind of have to laugh that it's called a comfort ride system. Spacers generally ride like crap. It will work for a cheap lift, but if you want lift and a good ride, I'd save up a little more and do something else with the front instead of the spacers. Check out the Bilstein 5100's at Downsouth Motorsports or Toytec. Between the 5100's at an AAL, you'll be around $250ish but the ride will be better (plus none of the other issues that come with spacer lifts).
  5. Dec 1, 2011 at 10:41 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    How can they charge $160 for freaking spacers??????????????
    You can get bilstein 5100's for $185 plus the TW discount from DSM and free shipping. Thats mere pocket change compared to those spacers...
    http://downsouthmotorsports.com/i-1...pre-runner-4wd-front-pre-load-adjustable.html
    Run these on the 2.5'' lift setting, will ride a lot better than spacers. Or run these till you can save up for eibach coils and ride even better with more lift!
  6. Dec 1, 2011 at 10:44 AM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    +1 Everyone here is going to tell you the same thing, stay away from spacers.
  7. Dec 1, 2011 at 10:52 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    so this ? w/ the 5100 option added ?
  8. Dec 1, 2011 at 11:02 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    What about for the rear?
  9. Dec 1, 2011 at 11:04 AM
    Pugga
    Massachusetts
    No, these and the AAL of your choice. The one you linked is a rear AAL, rear shocks and a spacer up front, just like the kit from 4WP. You want 5100's up front, an AAL for the rear and rear shocks if you can afford to do so.
  10. Dec 1, 2011 at 11:05 AM
    Pugga
    Massachusetts
    The $160 is for spacers and an AAL. Still no great bargain but it is a complete lift front and back.
  11. Dec 1, 2011 at 11:09 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    ok so above plus =gtg
  12. Dec 1, 2011 at 11:11 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    its actually 143.99 for the complete kit..
  13. Dec 1, 2011 at 11:14 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    though, I've never had a problem with AAL's limiting too much flex
  14. Dec 1, 2011 at 11:23 AM
    Pugga
    Massachusetts
    Yes, if you set the 5100's up front to 2.5, that 2" AAL should be all you need in the back. Let one of the 1st Gen guys chime in though and say at what point should you look into longer rear shocks depending on your use. Since you don't off road, I don't think you'll have a problem although new rear shocks to better dampen the AAL is a good idea (not required).
  15. Dec 1, 2011 at 11:26 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    thx - are the mods pretty easy to do? or how much should I expect a local shop to install it for?
  16. Dec 1, 2011 at 11:29 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Thats weak.
  17. Dec 1, 2011 at 11:31 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Your mom.
    OP- prices depend on the shop but you shouldnt have to spend too much; the swap/installs are pretty simple
  18. Dec 1, 2011 at 11:33 AM
    Pugga
    Massachusetts
    I can't speak to the fronts for the 1st Gens but the rear is a piece of cake with basic tools. You'll need a floor jack, jack stands, wrenches, a torque wrench and a C-clamp.
    Here's a 2nd Gen AAL install thread with pics. It's the same for 1st Gens.
    http://www.tacomaworld.com/forum/suspension/54186-aal-install-second-gen.html
    evzz and Elwing like this.
  19. Dec 1, 2011 at 11:34 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Yeah its a piece of cake! order the coils installed on the shocks or you will be hating life!
  20. Dec 1, 2011 at 11:53 AM
    rob1208lv
    Rob
    Las Vegas
    02 PreRunner V6
    any brand of aal better than the other?
