Rear shock Bilstein Help!
Discussion in 'Suspension' started by Scott41984, May 1, 2009.
  1. May 1, 2009 at 1:12 PM
    Scott41984
    Scott41984 [OP] Well-Known Member
    Birmingham, AL
    00 TRD Prerunner V6
    (I posted this on TTORA too)
    I received my Bilstein 5100 rear shocks today. The 3/4" bushings are included.
    However, it didn't contain the other bushings/washers/nuts for the new shocks. Do I need to contact Toytec or do I use the ones that already support the shocks I'm replacing?
    Also, when putting in the bushings into the shock... do I put the skinny end of it into the mount first? It fits but falls out easily..?
    Thanks,
    Scott
  2. May 1, 2009 at 1:27 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    I think you use the hardware on the stock shocks. not sure though. someone will chime in shortly that knows for a fact.
  3. May 1, 2009 at 1:30 PM
    Scott41984
    Birmingham, AL
    00 TRD Prerunner V6
    Bump for help... appreciate the response
  4. May 1, 2009 at 1:52 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Have to check again but IIRC, my rear 5100s came with a bag of bushings/washers/nut from DSM. Have to look again to be sure.
  5. May 1, 2009 at 1:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    x2. They should have come with the new hardware.
  6. May 1, 2009 at 2:26 PM
    FlawedXJ
    Paul
    NorAla
    oops. i was wrong. sorry to mislead you.
  7. May 1, 2009 at 3:20 PM
    Scott41984
    Birmingham, AL
    00 TRD Prerunner V6
    I attempted to install the right side shocks earlier. Both nuts were very seized up... I sprayed them with WD40 and worked and worked.
    I stripped the bottom bolt off with the assistance of a pipe on the end of the wrench. I replaced the bolt with one I had laying around that fit.
    I couldnt get the top nut off to save my life... I attempted with an impact wrench but that didnt seem to help. So now I just bolted the factory shock back up and try tomorrow since Ive got to head to work...
    Any ideas how to loosen the top bolt? What nuts are used for the shocks?
    Thanks
  8. May 1, 2009 at 3:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Maybe heat it up a bit with a torch.. BE CARFULL to not burn the truck down.
  9. May 1, 2009 at 3:23 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Just soak the nut in mystery oil or some penetrating oil that creeps into the metal. Let it soak for a half hour or so, and then you should be good to go! Thats what I use on the rusted nuts and bolts at my work.
  10. May 1, 2009 at 3:23 PM
    FlawedXJ
    Paul
    NorAla
    I don't know why yours are on there so tight. If an impact wrench (assuming its a good one) wasn't helping then i don't know what will. Try two people. I know it sounds stupid but 2 people is always better than one. When i was installing my front suspsension, i couldn't get the damn pins out to replace them with longer ones for a spacer. I beat on them with a hammer for about 5 minutes....nothing....passed them over to a guy helping me. They popped out first try.
    If you start to get sore/tired/whatever during an install, its always good to have a helper around.
    Edit....if you are using a torch, stay away from the break lines.....I know somebody who was putting a lift on a truck, had to use a propane torch to pull something off, hit a break line....and the rest went up in flames.
  11. May 1, 2009 at 3:33 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  12. May 1, 2009 at 3:59 PM
    Scott41984
    Birmingham, AL
    00 TRD Prerunner V6
    thanks for all the replies... i'll see what i can do... it will have to wait.:-(.. i gotta work this weekend and then off to the beach :)
  13. May 1, 2009 at 4:02 PM
    Scott41984
    Birmingham, AL
    00 TRD Prerunner V6
    I have the 2000 model. My shocks are mounted differently.
    It's not the nut spinning... I can't get it to move at all...
    I guess it won't budge because these are the original shocks I had on the truck. I'll try some penetrating oil, and some friends to help... but if that doesnt work, I guess I'll have to take it somewhere and get them to do it
  14. May 1, 2009 at 4:09 PM
    FlawedXJ
    Paul
    NorAla
    try a cheater bar too. like a 3 ft one.
  15. May 1, 2009 at 4:19 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    oh ok, my bad for not seeing you were 1st gen. Yea i would try a big ass cheater bar or a cutting torch :D
  16. May 2, 2009 at 6:21 AM
    Scott41984
    Birmingham, AL
    00 TRD Prerunner V6
    I used a cheater bar with the lower bolt and stripped the head right off... I managed to unscrew the rest of it with a flathead.
    There isnt enough room up top to use the cheater bar I have.. I went to Autozone this morning and got some PB Penetrating oil and well see how that works.... I'll keep yall updated when I try it.
    If I remember reading correctly... isn't one side more difficult?
  17. May 2, 2009 at 4:32 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Just put my rear 5100's on, and WOW what a difference:) Install was cake and took me about 30min. thanks to all who told to get rid of my crappy lesschwab shocks.
  18. May 3, 2009 at 7:22 AM
    Scott41984
    Birmingham, AL
    00 TRD Prerunner V6
    Well, I took some PB to them this morning and finally got them un-bolted and switched out.
    However...
    Further inspecting them, both shock part numbers end with D560-TO. Is that a problem? I did get the left side to mount up correctly even though it is a longer shock and made for the passenger side lol.
    It is on a 2000 model.
  19. May 3, 2009 at 7:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You will be fine with 2 of the same part numbers.
