Rear shocks clunking again - something’s off
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Nov 27, 2022.
  1. Nov 30, 2022 at 12:31 PM
    #61
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    will a bad ujoint clunk? & apologies. I should have put intermediate shaft.
  2. Nov 30, 2022 at 12:36 PM
    #62
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You'll feel a bad u joint as the cyclical vibration you mentioned earlier.
    You're looking for something moving.
    Kristi with a K[OP] likes this.
  3. Nov 30, 2022 at 12:43 PM
    #63
    Kristi with a K
    Western MA
    while I’m checking this out because regardless, there’s definitely gear oil evidence, is there a way to check the slip yoke? I mean other than overgreasing could there be something else up?
    Like I stated earlier somewhere, I did take it apart, cleaned & regreased. I had seen something about them getting overgreased, so decided to follow the instructions on that thread. Did the front as well.
  4. Nov 30, 2022 at 1:22 PM
    #64
    Kwikvette
    Fresno County
    4 run, 2 don't
    If you "over grease" it'll just push out the old stuff so no, no such thing.
  5. Nov 30, 2022 at 1:38 PM
    #65
    Kristi with a K
    Western MA
    So whilst I have the truck jacked up in the rear & prior to removing the drive shaft, I played around with the rear tires.
    The left one seems solid.
    The right one, when I pull & push on it, straight out towards me, I can hear a thumping. I can’t say as I feel tire move though or at least it doesn’t move much. But definitely a thumping.
  6. Nov 30, 2022 at 1:58 PM
    #66
    Kristi with a K
    Western MA
    Yeah. That’s what I had thought. This is something about how Toyota may have outdone themselves in how tight the fit is. I just happened upon it on here when i did a search for cleaning up the yoke/splines.
    “Slip yoke binding” is what I guess can happen if there’s too much grease. & I say can. Not sure why it happens to some & not others.
    It’s a “thing” though.
  7. Nov 30, 2022 at 2:05 PM
    #67
    Kristi with a K
    Western MA
    I can do a vid of the rear tire thump if needed….
  8. Nov 30, 2022 at 4:28 PM
    #68
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    Have you pulled on the exhaust system for contact with the frame? Grab the tail pipe and shake it as hard as you can..
  9. Dec 11, 2022 at 7:32 PM
    #69
    Kristi with a K
    Western MA
    Back on this - Vibe seems to be worsening at highway speeds. I think some of the clunks could have been attributed to a bad outboard cv axle joint. However, there are still clunks. They are almost assuredly from the rear.
    Inspected the rear again - the wheel is not jumpin'. It's my amateur lack of vid skills.
    I have not done anything to the rear wheels/axle. I am guessing since this is happening on one side & not the other that something's up, whether it explains vibe &/or clunks....
    Hopefully they're loud enough - I did them with my reg camera & there's no sound adjust.
    https://youtu.be/wWXPUtnqur4
    Wigglin it back & forth
    https://youtu.be/lej7qs0PNPY
  10. Dec 11, 2022 at 7:52 PM
    #70
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Not to add to the production work but can you cap a vid from the other side so we can have the backside of the wheel and surrounding area in view?
    I'm thinking something is going on inside the drum. You may have already covered that, I need to re-read the thread.
  11. Dec 11, 2022 at 8:05 PM
    #71
    Kristi with a K
    Western MA
    Can do. 1st thing tomorrow. & no need to re-read. I didn't get very involved in this area of the truck. I think it was heading there, however I got sidetracked by a u-joint & cv axle.
  12. Dec 11, 2022 at 8:15 PM
    #72
    Area51Runner
  13. Dec 11, 2022 at 8:38 PM
    #73
    Kristi with a K
    Western MA
    Lugs are tight.
    I just checked & no signs of leakage.
    & yes. The brakes feel ok. I did notice though, when I bled them not long ago, this one has less of a flow to it.
    I don't believe there's a wobble. I will do a vid of that as well tomorrow just in case it's not obvious.
    Area51Runner[QUOTED] likes this.
  14. Dec 12, 2022 at 10:14 AM
    #74
    Kristi with a K
    Western MA
    Here are some vids. Might need some with better lighting set up. If so, just let me know. It is also happening on the right after all. Just not that clunk when I quickly rotate back & forth. Also worth noting, that when I do that to the right wheel, there are two sounds. The initial, echoed by a 2nd. That 2nd one is coming from where the intermediate driveshaft meets the transfer case. I posted a vid of that noise at the transfer case earlier in this thread & @Andy01DblCabTacoma stated that it was normal. At the time I(we) did not realize there was an accompanying noise at the right wheel. Clear as mud?
    This was simply to see if the wheel was wobbly. Looks ok, I think.
    https://youtu.be/KBIJl6iOWQs
    https://youtu.be/z9JLZ-_-WLg
    I didn't do this one very well. I can hear the transfer case/intermediate drive shaft noise throughout it. At around 23 is where I have it making both noises.
    https://youtu.be/AuhmpplpqDg
    Inside right - done for sound
    https://youtu.be/vZTcQUEZCao
    Inside left- same
    https://youtu.be/b_YETIq5DPk
  15. Dec 12, 2022 at 10:27 AM
    #75
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    The pings/tings are normal as you change directions as the gears in the various parts of the driveline mesh.
    This one sounds like a bearing to me. Was the right wheel the one you said moved in a out a little?
    The left not as much. The right has more of a "marbles" sound.
  16. Dec 12, 2022 at 10:44 AM
    #76
    Kristi with a K
    Western MA
    Yes. This is the right (in & out) - the left may be doing this as well to a lesser degree.
    https://youtu.be/cn6CAXm1BAk
  17. Dec 12, 2022 at 10:47 AM
    #77
    Kristi with a K
    Western MA
    Would it help to have another vid with light on the in & out? I really just did this vid for sound.
  18. Dec 12, 2022 at 10:48 AM
    #78
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I wouldn't consider that excessive, but together with the sound when spinning the wheel when the camera (phone?) was close to the axle housing. I'd lean towards the bearing being bad. but I'd also suggest getting a second opinion, cause taking guesses over the internet is fun and all, but I could easily be incorrect. And it's a lot of work to do the bearings if you don't already have a press or access to one.
  19. Dec 12, 2022 at 10:50 AM
    #79
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    With the truck up on stands still- if you use a pry bar (or a long enough 2x4, etc..), do you get any vertical play in that side?
  20. Dec 12, 2022 at 11:28 AM
    #80
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    The wheel shouldn't have any in and out play. It's a roller ball bearing. If you have in and out play there's an issue.
    2. CHECK BEARING BACKLASH AND AXLE SHAFT DEVIATION (a) Using a dial indicator, check the backlash in the bearing shaft direction. Maximum: 0.7 mm (0.028 in.) If the backlash exceeds the maximum, replace the bearing
