Rear supension Upgrades?
Discussion in 'Street Trucks' started by ryoung40911, May 13, 2021.
  1. May 13, 2021 at 6:51 PM
    ryoung40911
    ryoung40911 [OP] Well-Known Member
    Rich
    NH, USA
    2010 Silver Tacoma 2wd Base Model
    DJM 3/4 lowering kit, 18" ford interceptor wheels, Nitto nt555 g2 tires, X runner sway bar, and many more on the way
    I have a 5 lug base model that i want to lower 4" in the back but make the suspension stiffer too. Would a sway bar help? or maybe new leafs.
    BananaMan and pinktaco808 like this.
  2. May 13, 2021 at 6:53 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I was reading someone got some composite leafs from Tundra Racing, might be worth researching but street trucks aren't my expertise.
    pinktaco808 likes this.
  3. May 14, 2021 at 6:36 AM
    NMTOY
    NMTOY Well-Known Member
    Rob
    1998 Dark green 2wd extra cab Tacoma V6, auto
    Clear corner and marker lights, 1997 Cobra wheels, KYB shocks, Powerstop rotors and pads
    Rear sway bar will definitely help the handling.
    JT_670 and geoff w like this.
  4. May 16, 2021 at 6:02 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    My recommendation would be 3 inch blocks with the 4x4 leaf spring. The leaf spring is thicker than the 2wd and consequently gives you some drop. That's what I'm running currently. Also worth noting that you will need a C-notch going that low. I'm autocrossing the truck and it's doing great with that setup.
  5. May 16, 2021 at 8:59 PM
    ryoung40911
    Rich
    NH, USA
  6. May 16, 2021 at 9:00 PM
    ryoung40911
    Rich
    NH, USA
    That would have me about 4"-5" lower probably?
  7. May 17, 2021 at 6:42 AM
    BananaMan
    It will lower your truck about 4 inches.
  8. May 17, 2021 at 10:15 AM
    ryoung40911
    Rich
    NH, USA
    That's good because I'm currently sitting about an inch or so higher in the back. 6 lug leafs would be great for off-road...
  9. Jul 22, 2021 at 4:20 PM
    geoff w
    geoff w Well-Known Member
    malibu
    '14 Tacoma 4x2 SR5
    I bought the SOS rear sway bar kit for my 2014 4x2. The drop links were way too long and hit the tailpipe. I ended putting on OEM rear drop links from the X-Runner and everything lined up just fine. I also used to OEM drop link mounting brackets and they lined up with the holes already in the frame. Drilling out a rivet on each side to get access to one of the holes was a real pain and took a long time; it was the worst part of the project
    JT_670 likes this.
