Rear Suspension
Discussion in 'Suspension' started by Project.Shadow, Feb 2, 2017.
  1. Feb 2, 2017 at 9:50 PM
    Project.Shadow
    Project.Shadow [OP] Active Member
    Cal
    2015 Black Tacoma TRD Sport
    3" leveled, Go Rhino led installed bullbar
    Lets say hypothetically i have a 1" add a leaf lift and a 2" spring lift, does that end up being a 3 inch rear lift or does it not work that way? Thanks in advance
  2. Feb 2, 2017 at 9:50 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    What do u mean by "spring lift"?
  3. Feb 2, 2017 at 9:53 PM
    Project.Shadow
    Cal
    Bilstein 5160's for rear SHOCKS, my bad:rofl:
  4. Feb 2, 2017 at 9:54 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Rear shocks provide 0 lift, they only control (dampen) the leafs. Lift in the rear is from thicker leafs, blocks &/or longer shackles.
  5. Feb 2, 2017 at 9:55 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Shocks in the rear won't give you any lift... If you wanted to go with a add a leaf plus a block (blocks not really recommended) then the lifts would add up. I'd recommend shackles before blocks...
  6. Feb 2, 2017 at 9:56 PM
    Project.Shadow
    Cal
    ??? it says they increase the rear by 1.5 inches?
  7. Feb 2, 2017 at 9:59 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    When it says "1.5" lift" referring to rear shocks, that's basically saying that it's a longer shock that can be run with up to 1.5" of lift. The shocks themselves don't provide the lift.
  8. Feb 2, 2017 at 10:00 PM
    Project.Shadow
    Cal
    OHHHHHHH, okay thanks!
    Styx586[QUOTED] likes this.
  9. Feb 2, 2017 at 10:00 PM
    dumontrider
    La Habra, CA
    14 GX460
    Think of it as what they can accomodate, not provide.
  10. Feb 2, 2017 at 10:01 PM
    Project.Shadow
    Cal
    So i can put a 2" add a leaf with those springs?
  11. Feb 2, 2017 at 10:04 PM
    Project.Shadow
    Cal
  12. Feb 2, 2017 at 10:08 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  13. Feb 2, 2017 at 10:10 PM
    dumontrider
    La Habra, CA
    14 GX460
    With 4" Maxtracs up front & 2" AAL in the rear those shocks will be perfect for a budget. Your prior post you said 5160 shocks which are an upgrade to 5100's but as long as what you buy accomodates 0-2" you'll be fine with an AAL. Probably sit damn near level with 4"/2".
    Edit to add: new posts poppin up quick. If you have extra pesos a new leaf pack is a great investment. OME Dakar or AllPro are the big names, the AllPro Expo pack is for frequent heavy loads. Let your credit card decide for you!
  14. Feb 2, 2017 at 10:13 PM
    Project.Shadow
    Cal
    thats what im thinking, because i have a 3" spacer on right now to "level it":help: but its 1" higher in the front. so a 2" difference between the front and rear i think will be great. :fingerscrossed:
