Rear Tail Light Heaters?-for blizzards
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reg boulette, Dec 29, 2009.
  1. Dec 29, 2009 at 4:34 AM
    reg boulette
    reg boulette [OP] Well-Known Member
    09 Tacoma AC
    After having driven through two extreme snow blizzards, found that tailgate become solidly crusted with snow, as well as LED tail lights which did not generate enough heat to melt snow on the lenses. As such, was practically invisible to vehicles following truck. Not a problem on previous trucks which had the regular incandescent bulbs which melted snow.
    Most will suggest getting out and wiping lights every so often, but in extreme white out conditions, this is probably more dangerous.
    Generally like the look of the LED tail lights so don't want to swap to older version. Have thought of a couple of mods to solve problem:
    -drill and install incandescent bulbs in the tail light casings which would come on with the regular tail lights and provide some heat.
    -using the snowmobile hand warmers as another forum member has posted for creating heated mirrors, having a separate wiring system to activate these on tail lights when needed.
    Anyone else with possible simple elegant solution?
  2. Dec 29, 2009 at 6:17 AM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Would rain-x keep the snow from sticking?
  3. Dec 29, 2009 at 6:32 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    very interesting...i never thought about leds not generating enough heat to melt snow. maybe some canada / snow belt people will chime in. maybe rain-x or aquapel the hell out of them so its harder for the snow to stick....beats me on this one.
  4. Dec 29, 2009 at 6:34 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Maybe run some magnetic trailer lights when you drive in those conditions?
  5. Dec 29, 2009 at 7:57 AM
    Crooked Beat
    Crooked Beat Well-Known Member
    GTA
    2021 Tacoma DCLB SR
  6. Dec 29, 2009 at 8:13 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I did not know this, thanks for posting.
    Maybe I need to swap my 06 tails back in for winter driving?
    Or rig up a glow stick on those nasty days, like today.
    Will try the rain-x tho, good tip!
  7. Dec 29, 2009 at 8:16 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    When I had snakes i used this stuff called Flexwatt. It is a roll of plastic with internal wiring that can get pretty darn hot. You would want to run a rheostat to it so you can change the heat output.
    I would post some links, but work blocks it all. There are a bunch of different sizes to choose from. it is very low draw aswell. Check it out.
  8. Dec 29, 2009 at 9:37 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    this is a good thread,cause i was wondering when this was going to come up.i see this on BIG trucks all the time.L E D s just dont have the heat as a regular bulb does.
  9. Dec 29, 2009 at 9:40 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Here's a link:
    http://www.bigappleherp.com/Flex-Watt-Heat-Tape
  10. Dec 29, 2009 at 11:17 AM
    Afwrestler1986
    Johnstown, NY
  11. Dec 30, 2009 at 1:28 AM
    reg boulette
    Thanks for the replies!
    The FlexWatt tape is a good idea, but does not seem to run on 12 volts DC. (at least can't find any reference to this on a search of several web sites) I'll see if I can't get some RainX and try this out. The magnetic trailer lights are also a good idea - a bit cumbersome - but have changed my mind about replacing my trailer tail lights with LEDS!
    There have been several people on snowmobiling forums that have wired in a small 'peanut' bulb that seems to have worked well on the newer sleds with an LED tail light. Apparently it doesn't take much heat to at least partially clear the tail light lens.
  12. Dec 30, 2009 at 4:09 PM
    Afwrestler1986
    Johnstown, NY
    It should work just fine.
