rear view camera install
Discussion in 'Audio & Video' started by 808trdsport, Jun 19, 2009.
  1. Jun 19, 2009 at 5:20 PM
    808trdsport
    808trdsport [OP] Well-Known Member
    Honolulu
    08 Tacoma TRD Sport Prerunner
    6000k HIDS, double tint in the back and tint front side windows, CGS cat back exhaust, AFE Pro Dry filter
    I just got me one of those rear view license plate cameras, and wanted some help on wiring it up. I know how to wire it up, but i wanted some info on where you ran the wire, how you went into the cab. also with my Kenwood, it's asking to install a wire to the backup lights. Any suggestions on that one?
  2. Jun 19, 2009 at 6:05 PM
    JDrew
    JDrew Well-Known Member
    Evansville, IN
    '08 Tacoma TRD RT
    Kenwood DNX9140, DRL Mod
    Run the camrea wire next to the frame on the driver side.. Once you get to the cab, you'll see drain plugs in the floor, use one of those.. make sure you seal it properly.
    The reverse wire for the back-up cam will be in the driver side kick panel.
    (Not my photo, but from this site.)
  3. Jun 19, 2009 at 6:43 PM
    808trdsport
    Honolulu
    this is not for a 2009. I got a 08'. and I'm hooking it up to my Kenwood ddx712
  4. Jun 19, 2009 at 6:54 PM
    JDrew
    Evansville, IN
    '08 Tacoma TRD RT
    I have an 08 as well, DNX9140..
    The wire is in the same place.. I installed mine, I think the wire is red w/ white tracer.. let me go look
  5. Jun 19, 2009 at 7:02 PM
    JDrew
    Evansville, IN
    '08 Tacoma TRD RT
    Same location. Red wire wtih white tracer.
  6. Jun 21, 2009 at 6:09 AM
    oshky
    oshky Well-Known Member
    OHIO
    05 Taco
    3" Revtek Lift, 2"AAL/5100's(Rear) BHLM, Foglight Mod,Smoked Tails, 17"Eagle Black wheels, 33" Nitto's, Kenwood DNX7180..More to come!
    What camera did you get?
  7. Jun 22, 2009 at 9:52 AM
    808trdsport
    Honolulu
    some cheap ass ebay one. I hope it works. lol
  8. Jun 22, 2009 at 9:54 AM
    808trdsport
    Honolulu
    sweet! so this is the reverse lamp wire? i think thats what the installation instructions was asking to tap into.
  9. Jun 22, 2009 at 10:45 AM
    JDrew
    Evansville, IN
    '08 Tacoma TRD RT
  10. Jun 22, 2009 at 12:41 PM
    808trdsport
    Honolulu
    thanks JDrew. So will this allow the rear view camera to turn on automatically when i throw the truck into reverse? Or will i have to turn the deck to av in? Also, will I be able to view the camera while going forward?
  11. Jun 23, 2009 at 10:35 AM
    808trdsport
    Honolulu
    bump bump
  12. Jun 23, 2009 at 4:02 PM
    JDrew
    Evansville, IN
    '08 Tacoma TRD RT
    Yes, that wire will send the signal needed for when you place your truck in reverse which will give you the reverse view, provided you have the radio settings for it to do so. (Meaning it is designed for a rear camera in mind. The radio should have a specific rca for the reverse cam, usually yellow.)
    If you unit will allow the camera to be displayed while moving, this can be tricky. It depends if the camera has to be wired to the reverse wire too. If so, then it wont. You would then have to run the camera reverse wire to a 12 volt lead then it would work anytime you decide to view it. Some cams dont require the cams to be spliced into the reverse wire.
  13. Jun 23, 2009 at 4:46 PM
    808trdsport
    Honolulu
    so if i do go into a 12v connection, that means the camera will be always on? Unless i switch it? Or if I put it into the accessory switch?
  14. Jun 23, 2009 at 4:48 PM
    JDrew
    Evansville, IN
    '08 Tacoma TRD RT
    Not knowing your camera wiring, I'm guessing. Tell me what wiring comes with your cam.
  15. Jun 23, 2009 at 4:54 PM
    808trdsport
    Honolulu
    1 yellow rca video out. And 1 mini adapter plug with red+ and black- coming out the other end. That's all there is.
  16. Jun 23, 2009 at 4:58 PM
    JDrew
    Evansville, IN
    '08 Tacoma TRD RT
    Sounds like to me that you have a video lead (RCA), power and ground. Pretty simple it sounds like. Power wire to key switched 12v, black to ground and your RCA to cam input on hu.
  17. Jul 5, 2009 at 9:26 AM
    hramo
    hramo New Member
    Los Angeles
    09 PreRunner
    JDrew,
    Do you know how to tap into the factory camera? I have a Kenwood DDX514 which will allow for camera view, but I have a factory camera on the handel of the tail gate.
  18. Jul 6, 2009 at 5:52 PM
    JDrew
    Evansville, IN
    '08 Tacoma TRD RT
    no clue..
  19. Jul 6, 2009 at 5:56 PM
    808trdsport
    Honolulu
    i got mine hooked up with my kenwood. It's works only when I throw it into reverse.
  20. Oct 31, 2009 at 11:38 AM
    atebit
    atebit What's all this, then?
    The basement of the Alamo
    18 Inferno TRD OR 4x4 AC
    If I'm looking at the same connector in my 09 Access Cab, the wiring colors are are different. I appear to have a solid red wire instead of the red/white wire. No voltage appears on this wire when I put the truck in reverse (but the reverse lights are on).
    Did they move this wire around for 09 or am I just crazy?
