Rear view mirror location
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd, Aug 27, 2007.
  1. Aug 27, 2007 at 9:53 AM
    nd
    nd [OP] Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    The location of the rear view mirrror is something that has bugged me since i first got my truck, i just haven't taken the time to complain about it. But today i read a post in the new member forums and one of the newbies was complaining about the same thing, so i thought i would start this tread.
    In my opinion, the rear view mirror is located in a very inconvenient spot. It's right in my field of vision. when i'm making a turn or going through an intersetion i have to duck my head to look under it to make sure it's not covering up a car. I havn't heard this complaint before so maybe not everyone experiences it. placement may be different on different cabs. I have the double cab. It's a fairly irritating/dangerous problem and i find it hard to believe Toyota didn't pay any attention at all when they chose to place the mirror, so i didn't know if it was just me or if others have noticed this. I'm 6ft tall, if i were 6'3 or 6'4 i dont know how i would deal with it. I have considered moving it but there are two problems with that.
    1) im afraid if i move it up it will not be at the right angle and i will not be able to see out of the back of my truck
    2)directly above the mirror are raised black bumps and im afraid the adheisive wont stick well to them.
    does anyone else have this problem with their mirror? has anyone come up with any solutions? if i move it up can i still see out of the back? any suggestions or feedback would be appreciated
  2. Aug 27, 2007 at 1:04 PM
    TJOPILOT
    TJOPILOT Well-Known Member
    Hey ND, same freakin problem for me. This is what was posted on TN:
    The rear view mirror can be moved, if you look the base where it is mounted to the windsheild, you will notice that it can rotate, (like a ball joint) just ratate it up and it will get it out of your way.
    I can't get my damn mirror to do what he said. I just pm'd barlowrs and asked for pics. If this doesn't work I am going to just have it moved up onto the black nub things. They are the antenna right?
    Oh and ND, get some daylight pics up in your gallery!!!!
  3. Aug 27, 2007 at 1:09 PM
    nd
    Nate
    Greenville, SC
    Sure thing TJO, i'll try to get somepics up tonight. let me know if you figure out the mirror thing
  4. Aug 27, 2007 at 2:35 PM
    nd
    Nate
    Greenville, SC
    alright TJO, i took some pics and just finished loading em up. Mine's pretty much bone stock except for the tinted windows and traded grille
  5. Aug 27, 2007 at 3:50 PM
    stinger86
    stinger86 Well-Known Member
    San Diego, CA
    2016 Double Cab Limited
    finally being under 6ft has an advantage!!! no such issues for me thankfully, im 5'9" though I have a sitting hight of 6'2" so odd that I don't get that issue apparently im so close to the mirror it doesn't matter lol.
  6. Aug 27, 2007 at 3:55 PM
    ghostsix
    ghostsix Well-Known Member
    A WI farm, Sonora, Sedona, Lake Havesue and Canyon
    Impluse Red 2006 Toyota Tacoma TRD Off-road 4x4
    A Roo Bar comes to mind. I also protected the tail lamps. It is a farm and you back over stuff; Willows mostly. All of the factory options are on it. The dealership owner bought it for himself.He put a topper on it and pricey tyres. The Power Wagon does the heavy lifting.
    My only blind spot is forward of the rt.r. door. just look out the window.
    Choppers would be hard to see but you can hear them.
    I am very pleased with the rear visibility on mine. I am used to good mirrors on my other trucks. These are not as big but are good enough to save me turning my head.
    I mainly use the side mirrors. I would not miss the rear view a bit. You may just want to remove it.
    Different truck though.
  7. Aug 27, 2007 at 4:58 PM
    LQQKatmy06
    LQQKatmy06 Carolina Alliance
    T-VILLE, NC
    06 SR5 V6 DC LB TRD Sport 4x4 AUTO. 3" TOYTEC 885 coils w/AALs, ALL-PRO UCAs, 285/70/17 NITTOs, KMC HOSS in BLACK
    I thought the same thing about mine, it took me about 2 months to get used to it.
  8. Aug 27, 2007 at 5:30 PM
    TJOPILOT
    Hey ND, your trucks looks good buddy! Good pics and thanks for getting them up. I totally brainfarted on the mirror relocation thing. The mirror is double hinged. Push the mirror itself as far as it will go up on the lower hinge. Then bend the mirror itself down on the upper hinge. Believe it or not it bought me a good couple inches of visual space. Good luck and DON'T rip it OFF!!!!!!
  9. Aug 28, 2007 at 6:04 AM
    nd
    Nate
    Greenville, SC
    Thanks for the advice TJO, its always important not to rip IT off....
    Thanks for the compliments, i will pass them on to my truck
  10. Aug 28, 2007 at 7:32 AM
    gtimark
    gtimark Member
    Hey ND!
    Same dang problem with mine. Do as the others have suggested and it will definitely improve (but not completely fix) the forward vision problem of the Tacoma. I was thinking about some after market mirror that has a greater adjustment range......
  11. Aug 28, 2007 at 12:34 PM
    nd
    Nate
    Greenville, SC
    TJO: you're advice worked great, i never bothered to check to see if it would pivot but it does! I have a much clearer field of vision now, i think originally mine was as low as it goes and felt like it took up the entire windsheild. That was an easy problem to solve :) Thanks TJO!
  12. Aug 28, 2007 at 8:27 PM
    tacomaclay
    tacomaclay Well-Known Member
    SR5 4x4 04
    Flowmaster exhaust, K&N 77 series intake, kobalt aluminum toolbox
    I Just move mine with my hand
  13. Sep 5, 2007 at 4:14 PM
    racerx
    racerx Member
    SF
    '07 prerunner sport
    Thanks for posting this thread NdCouch,
    I was abe to improve my field of vision as suggested by some of the other members.
    and i am continuing to get used to it.
    I may experiment with moving it though. I beleive the black dots are to reduce sun glare and can likely be scaped a bit to allow for a remount.
    Ill repost if in fact i do the modification.
    Drive Safe!
    john
  14. Sep 5, 2007 at 6:24 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Careful, ndcouch you are quickly loosing your reputation as being lazy. Too many more threads like this, and you will win the September prize too. ;)
    Back on subject - I don't have this issue, but then again - the very first time I got in my truck and adjusted the seat - I smacked the rear view mirror all the way up with my head. DOHT!
  15. Sep 5, 2007 at 6:45 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
  16. Sep 5, 2007 at 6:49 PM
    rhoppas
    rhoppas Land of Oz
    Topeka, KS
    07 Double Cab V6 TRD Sport Tow
    Earnhardt Cannons, Terra Grapplers, Viper alarm, Hunter4x4 Bull Bar, 6" Pro Comp Off-Road lights, extra set of bed D-rings, Chrome exhaust tip, Metra Ipod/MP3 adapter, Garmin GPS, CarriageWorks grill, Maglite mounted to driver seat, 9" Stubbie Antenna, WeatherTech floor liners, Saddleman Neoprene seat covers, DeeZee bed mat
    Thanks for the guidance, TJO! I am also 6'2" and that mirror was driving me nuts. It's still not real good though. With the 2 back seat headrests in their usual location you have very little vision out the back window on a DC. Having driven cars my whole life I am not used to this. I am slowly learning to rely on my outside mirrors.
  17. Sep 5, 2007 at 10:30 PM
    TJOPILOT
    Damn Pb, good call! That will push the damn mirror all the way up. rhoppas, open that thread up that Pb posted. It buys you even more room. I'm going to do this tomorrow. You too ndcouch!!!!
  18. Sep 6, 2007 at 12:07 AM
    Mudbug
    Mudbug Well-Known Member
    Amsoil 0w-20 engine oil and Amsoil Full synthetic 75w-90 in the Transmission, transfer case, front and rear Differentials. AFE Cold Air Intake
    I have this same problem! I'm 6'1" and it bugs the hell outta me. Never thought to try to pivot it! I'll try it in the morning.
  19. Sep 6, 2007 at 2:59 AM
    lineberw
    lineberw Well-Known Member
    Summerville, SC
    TRD 4x4
    I'm about 6' 2" and my head comes real close to the roof but, I still have no problem with where the rear view mirror is located.
  20. Sep 6, 2007 at 6:38 AM
    nd
    Nate
    Greenville, SC
    Damn, its amazing how many of us had the problem and that none of us bothered to reach up and try to move the dam thing.... i just assumed it was in a fixed position until i started this thread. rhoppas, i also had the problem with the rear seat headrests.... i just took 'em out, now i see a whole lot better. I dont think anyone in the rear ever uses them anyway, and if they have a problem with it, we can take their car.....
    007, if you want to you can go ahead and give me the September prize, i feel i have deserved it with my one or two helpful comments and threads :)
