Rear view of 08 not "level"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SongDog, Apr 18, 2008.
  1. Apr 18, 2008 at 7:37 PM
    SongDog
    SongDog [OP] Active Member
    DFW, TX
    SR54x4 Sport
    Tint, Husky floor liners, UWS low profile toolbox, 2.5 lift, 265/70/17 BFG A/T, Moto Metal 951 17X9
    Hello to all! 1st Tacoma and I love it except for one concern.
    I've always been considered to be a bit to "anal", but some of you might be able to relate to my attention to DETAIL.
    I noticed that my truck looks a bit un-level from side-to-side, not front to rear as that is expected on stock suspension. I measured the height from a level garage floor and the distance from ground to flare is 36" on drivers side and 36-3/4" on passenger side at the center of the rear wheels.
    I've tried taking off toolbox, loading it differently, unloading it completely, but STILL SAME RESULTS!
    Dose anyone else have this "problem"? Would the TSB on the leaf springs fix this? This bothers me becuase it makes my NEW truck look like it has some sort of defect!
  2. Apr 18, 2008 at 7:50 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the gas tank sits on the drivers side...so that'll make a difference, depending on how full it is
  3. Apr 18, 2008 at 8:10 PM
    SongDog
    DFW, TX
    SR54x4 Sport
    Sorry, I foregot to add that I questioned that too! I measured it with varying levels of fuel but still got nearly the same results.
    I would appreciate any personal measuring results if possible. I plan on consulting the dealer about this...but we all know how that goes.
    Thanks in advanced for your help!!!
  4. Apr 18, 2008 at 8:38 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    There simply is more weight on the Drivers side. This is a VERY common thing.
  5. Apr 18, 2008 at 10:05 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    It is refered to as the "Tacoma Lean." I have deliberately avoided measuring mine because I know that knowing the exact measurement would bother me. The Tacoma's are based on the Hi lux, which is a right hand drive vehicle. hence all the heavy shit ie battery, fuel tank, etc. are on the left hand side of the truck. Have an average person sit in your passenger seat and repeat your measurements, it should be nearly perfect.
  6. Apr 19, 2008 at 10:57 AM
    SongDog
    DFW, TX
    SR54x4 Sport
    OK Thanks so much for the input. It makes me feel better to knowing that there is nothing wrong!
  7. Apr 21, 2008 at 9:00 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    the majority of tacomas have this, go to any tacoma site and type in "tacoma lean" or "tacoma tilt" and you'll find tons of post mentioning it
  8. Apr 21, 2008 at 9:05 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Gas tank + battery + your ass in the seat most of the time = driver's side lean. :p
    I'm really surprised that they didn't put something on the passenger side to balance these things out.
  9. Dec 27, 2008 at 6:55 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I just discoverd this on my '08--yesterday. I took the measurements after the TSB and Bilstein 5100s installed at 1.75. Mine is off by 1/2". This is ridiculous as the manufacturer could correct it with stiffer D/S springs.
  10. Dec 27, 2008 at 7:29 PM
    Punisher
    Punisher Billy Reuben
    Massachusetts
    2008 Access Cab TRD Off-Road
  11. Dec 27, 2008 at 10:26 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    Or you could just adjust your Bilsteins...
  12. Dec 27, 2008 at 10:47 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    I offer a 1/2" solid spacer that bolts to the bottom of the leaf pack and corrects this lean in back. I also offer offset custom steel blocks to correct this for the guys that use blocks. They are welded inside and out and use grade 8 bolts for the pins, they are the strongest blocks on the market guaranteed....upgraded u-bolts too.
  13. Dec 28, 2008 at 6:12 AM
    grivera
    Hanover, MD
    The next adjustment up would be 2.5, that's 3/4" more, which would then be higher on the D-side. I don't weigh enough to level out 1/4".
    I love my truck but this is an example of the Toyota not giving a sh*t as long as their product sells. Prior to buying this Tacoma, I had seen others thta leaned but I attributed it to frame or spring damage. Never in my wildest dreams would I have thought that Toyota simply didn't attempt to correct the platform for the American market....
  14. Dec 28, 2008 at 6:58 AM
    jbrooks
    jbrooks Active Member
    Tucson, AZ
    Prerunner SR5
    Maybe this design was on purpose by Toyota. If the majority of the roads are crowned; that is higher in the middle than the sides to facilitate drainage, the the truck would seem more level if the right side was slightly higher to offset teh slope of the road.
  15. Dec 28, 2008 at 10:00 AM
    toyohtadude
    toyohtadude Well-Known Member
    Eric
    Austin, TX
    2017 4x4 Tundra SR5 CrewMax
    Bone stock
    You beat me too it. I questioned the tech at the dealer and this is exactly what they claim the difference is for. :D
  16. Dec 28, 2008 at 1:45 PM
    nomad
    nomad Well-Known Member
    Just date/ marry a really fat chick... no more tilt.
  17. Dec 28, 2008 at 2:27 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I try to haul my scaffolding for work on the right side of the bed to counteract any lean.
  18. Dec 29, 2008 at 4:29 PM
    grivera
    Hanover, MD
    That tech is BS'ing. I'm sure Toyota didn't put all that much thought into it. Also, apparantly not all Tacomas lean this way. Futhermore, the adjustments made during an alignment compensate for the crown in the road. Finally, the Hi Lux is right hand drive, wouldn't it look really goofy leaning the other way?
