Rear wheel extended stud replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cavemanliketaco, Jul 30, 2018.
  1. Jul 30, 2018 at 10:35 AM
    Cavemanliketaco
    Cavemanliketaco [OP] Member
    2016 Toyota Tacoma SR5
    Leveling kit
    Hello world,
    I just recently bought some new wheels but will require extended lug studs to ride safely(only grabs the third thread). I’ve watched videos on how to change out the fronts but yet to see one for the rear wheels. There isn’t enough space behind the studs to fit extended ones. It seems I may have to take the brake drum off. I want to stay away from wheel spacers with extended lug studs because the new tires and wheels will already extend them out. If anyone has dealt with this please advice, thanks!
    2016 Tacoma 6 lug
    3 inch leveling kit.
  2. Jul 30, 2018 at 12:33 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    if I remember from my past 3 Toyota trucks, you have to take your brake drum off and there should be a hole in the back of the axle housing and you can replace the studs one at a time thru the hole, it may have a rubber grommet over it...just can't remember which Toyota I replaced one of them on?..good luck
  3. Jul 31, 2018 at 12:51 PM
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
    That grommet and hole is for adjusting the brake shoes, it's not big enough to fit a stud through. I had to drill a 3/4" hole in the backing plate to get ARP studs into the hub. I bought some 3/4" rubber plugs from Amazon to seal off the drilled holes.
  4. Jul 31, 2018 at 2:52 PM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    That’s not what I was talking about, I had a hole somewhere back there and I punched the stud thru it and replaced it with no problem, just can’t remember which vehicle?
  5. Jul 31, 2018 at 3:05 PM
    squarenone
    SoCal
    I didn't see any hole when I was back there on my 3rd gen
  6. Aug 1, 2018 at 12:10 PM
    kgilly
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    I could be wrong, sorry, haven't even had the rear drums off of this one yet, I got 90k miles on the rear drums on my T100..
  7. Aug 1, 2018 at 3:52 PM
    tacoma dude
    tacoma dude Member
    David
    2017 inferno orange tacoma
    trd pro grill so far
    I just bought a set of extended length lug nuts for my aftermarket wheels they work great.
  8. Aug 14, 2018 at 12:48 PM
    Cavemanliketaco
    Leveling kit
