Rear Whine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pep, Jul 12, 2019.
  1. Jul 12, 2019 at 8:16 AM
    Pep
    Pep [OP] Active Member
    Howard
    Just purchased a 19 Tacoma and it has around 5 or 6 hundred miles total. First Taco for this 67 yr fellow. I seem to have whine on deceleration and I,m thinking it may be the differential. Anyone else have this problem??
  2. Jul 12, 2019 at 8:22 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Yes. - Everyone else with a 3rd gen probably
    Taco_Coma likes this.
  3. Jul 12, 2019 at 8:24 AM
    tcjacado
    tcjacado Well-Known Member
    Search rear diff howl
    shakerhood likes this.
  4. Jul 12, 2019 at 8:28 AM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    I have experienced whine at various speeds, many others have as well; I had the rear diff inspected with no fault. There are a variety of discussions about it on this site that have been going on for years with no clear solution for everyone.
    Bottom line, in my opinion, is that it is just one of the quirks when it comes to these vehicles. If Toyota's engineers have not found inherent mechanical flaws - and without the hundreds of thousands of 3rd gen Tacomas not imploding on the roads today - it should not be something to be concerned with.
    ryan760 likes this.
  5. Jul 12, 2019 at 8:55 AM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    There is a TSB, you are correct that the noise is from the differential. Certain trucks have it worse than others due to harmonics, my understanding is the fix toyota will perform is a spacer or rubber block to break the resonance. If it's a new truck can't hurt to have the dealer check it out. You'll also hear it if you go between light and no throttle at highway speeds.
  6. Jul 12, 2019 at 9:11 AM
    Pep
    Howard
    I had no idea it was this prevalent. I hung up my wrenches and the thought processes that went along with them many years ago. On the bright side my hearing is pretty bad. It doesn't take much for me to ignore it. I'll have it checked though to make sure it's paper worked. I'll be watching for a fix and will post if I solve it. I'm thinking it may have something to do with the driveshaft carrier bearing. All these rears can't be bad for so many years. Somethings putting abnormal vibration or stress on them. Just have to have someone with brains figure it out. I even get some vibration in the steering wheel under load.
  7. Jul 12, 2019 at 9:13 AM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    Turn your radio up. JK
    Welcome OP! :)
  8. Jul 12, 2019 at 9:13 AM
    chaotic_taco
    ATX
    2017 DCSB TRD OR MT
    There's nothing wrong, it's just gear whine. The fix is to change the metal to metal noise conduction. This is what the rubber spacers are for.
    I haven't had the fix applied to my truck, it doesn't bother me.
    ryan760 likes this.
  9. Jul 12, 2019 at 10:43 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Have your dealer check TSB 0013-18. It addresses that. New rear frame isolators do a good job and reducing the whine.
  10. Jul 12, 2019 at 11:20 AM
    SpeySquatch
    2016 TRD OR DCSB
    Give it a 1000 miles first
  11. Jul 12, 2019 at 11:26 AM
    Pep
    Howard
    I've owned and driven a whole lot of vehicles in my time but I've never had one vibrate in the steering wheel on acceleration. Anyone else have this? My last truck was a Tundra and I'm starting to wonder if I made a mistake by going down in size. The MPG on the new Tundras is horrible driving my choice to the Tacoma.
  12. Jul 12, 2019 at 11:44 AM
    tcjacado
    Yup, another search is in order.... "steering wheel vibration Tacomaworld "... type that into Google and get something to drink.
  13. Jul 12, 2019 at 11:56 AM
    Pep
    Howard
    Scotch is my preferred drink and Macallan is preferred brand. Thanks for the excuse.
