rebuilding engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudjunkie, Oct 19, 2008.
  1. Oct 19, 2008 at 1:00 AM
    mudjunkie
    mudjunkie [OP] Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    http://tampa.craigslist.org/psc/pts/884447722.html
    what do you guys think is it wirth trying or what i want to put this with a tranny in my buddies suzuki sami but i wonder what we will be getting into i love the toyota engine so it may be worth it
  2. Oct 19, 2008 at 2:52 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Go for it man! Sounds like a fun project.
  3. Oct 19, 2008 at 8:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    For $100.00, why not! Low end knocking sounds like the Con rod bearings, or main bearings. Easy swap to new ones for about $30.00. Then have the head done, maybe new pistons, and your good to go! :D
  4. Oct 20, 2008 at 5:35 AM
    NavyNate06
    NavyNate06 yeah i fix F/A-18s
    Virginia Beach, VA
    99 Tacoma SR5
    Toytec 3 inch coilovers, OME springs/shocks, Toytec shackles, rattle can paint job, lc headers,
    is it a replacement for the same engine or is it gonna be a complete swap. i just went through this with my truck since i was unlucky enough to blow mine up. if its a replacement, definately go for it. if its a swap, do as much research as you can before you start. you'll need the computer, wiring harness, accessories, exhaust, mounts, adaptors for the tranny. if its going into a suzuki, are you going to use the original tranny and rear end? what size engine are you replacing in the suzuki. the drive train might not withstand the abuse of a bigger engine. i was trying to swap my 3rz for a chevy 305 but decided against it because of cost and time. don't get me wrong, the project sounds fun as hell, but make sure you've got everything covered so nothing comes up and surprises you.
  5. Oct 20, 2008 at 12:13 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    excellent pint
  6. Oct 20, 2008 at 1:08 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    I would not do it.. Unless..
    1. you can get the wiring harness and CPU
    2. are ok with a full rebuilt.
    3. have you done this before?
    Or if you hav ea car with this motor now and are just placing it have fun..
    But it will need a full gasket kit and a tube of RTV to reseal it up and a T-belt and water pump.
  7. Oct 20, 2008 at 4:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For $100.00 what better way to learn how to rebuild.
    X2 on the gasket kit and RTV. :)
  8. Oct 21, 2008 at 3:44 AM
    NavyNate06
    Virginia Beach, VA
    99 Tacoma SR5
    true, theres no better way to become truly intimate with the workings of an engine than tearing down and rebuilding. now for 100 bucks. i would most definately buy it. but don't get ahead of yourself with thoughts of throwing it in a truck an vroom vroom. i'd take that engine and tear it down, new bearings, new piston rings, new valves, cams, headers, injectors. definately tune that mother out. take your time, get a nice tranny to hook up to it and a nice set of diffs and THEN through it under that sami. i can't imagine what that little monster would be like with a tuned 3vz and danas under it, haha.
