Recalibrating the speedometer after regaring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BR Pipke, Feb 10, 2017.
  1. Feb 10, 2017 at 2:49 AM
    BR Pipke
    BR Pipke [OP] Well-Known Member
    Drayton Valley Canada
    11 TRD short box 6speed std with 3" lift bilstein 5100 struts pro comp UCA AFE air cleaner and throttle spacer ultra rims 265-70/18 dual exhaust
    has anyone recalibrated their speedometer after they regeared their Tacoma? I'm changing the gear from 3:73 to 4:56 with 285-70/17 tires.
  2. Feb 10, 2017 at 8:27 PM
    BR Pipke
    So no one out there has changed gears and went with bigger tires have not issues with their speedometers? So what does everyone do just leave it a lone.
  3. Feb 10, 2017 at 8:58 PM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Auto or manual? Manual the speedo will be farther off because it takes off the tcase. Auto uses the abs sensors for speed. So when I regeared to 4.56 with 235/85/16 the speedo stayed correct.
    Dakota digital makes a system for changing the input signal to the speedo
  4. Feb 10, 2017 at 8:59 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I'm hoping someone has some input.
  5. Feb 11, 2017 at 4:46 AM
    BR Pipke
    My truck is a manual
  6. Feb 11, 2017 at 5:10 AM
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    I haven't regeared but when I lifted and went to 33's I installed a hypertech. Its a super simple process. You plug it into a computer and put the CD in to download the software, then you enter your stock tire size and gear ratio in one column and the new size and ratio in the next one. That's the programming stage. Then you pop your dashboard off and plug it in behind the instrument cluster. There's a wiring harness that you unplug, then plug the hypertech into it. That's it, done deal.
    Most guys just leave it as is and estimate their speed or go with traffic, but I don't want to have to do calculations to figure out my speed, I wanted my speedo and tachometer to be accurate. I'd recommend going this route. The nice thing is that you can always reprogram it if you change tire size or gear ratio down the road.
    Dave4ep and Drainbung like this.
  7. Feb 11, 2017 at 5:15 AM
    mbmack1
    matt
    az
    SAVAGE silver '06
    Drainbung likes this.
  8. Feb 11, 2017 at 7:26 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    mbmack1 - does your hypertech correct both speedometer and odometer ? Reason I ask, my truck (like a lot of Tacoma's) was almost zero error on odometer, speedometer displayed 2-3 mph high with oem tires compared to GPS.
  9. Feb 11, 2017 at 11:17 AM
    badger
    badger Well-Known Member
    07 SR5
    I used Dakota Digital on my manual, but you cannot calibrate the speedo and odo separately. If you have a scan gauge you can calibrate that independantly. If you have both, calibrate the Dakota first, and then the Scangauge.
  10. Feb 11, 2017 at 11:27 AM
    BDub
    BDub Well-Known Member
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
  11. Feb 11, 2017 at 2:29 PM
    BR Pipke
    BDub is the hypertech you mentioned is for 12-15 and mines a 11. So is that compatible? edm3rd thx for youinput it greatly appreciated. Thx to everyone who helped thx and cheers
  12. Feb 11, 2017 at 2:31 PM
    7six2Fan
    7six2Fan Well-Known Member
    Dave
    Maine
    '13 TRD Sport DC LB
    I'm on stock gears with 295/70/18 and the 10% rule is very accurate for me.
  13. Feb 11, 2017 at 2:41 PM
    BDub
    Brandon
    Byrnes Mill, MO
    2015 DCSB Off-Road
    Just look up your year. It might be a different part number. :notsure:
