Recall Procedures: Noise after Ignition Off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yak13, Jan 31, 2013.
  1. Jan 31, 2013 at 3:08 PM
    yak13
    yak13 [OP] Well-Known Member
    WA
    Tacoma Off Road
    My new '13 Sport makes a errrkkk noise for a couple seconds everytime I turn off the ignition.
    I called Toyota care 1-800#, was told this is not normal and contact my local dealership.
    Dealership thinks noise is coming from the air pump, they need to record the noise and include in DPR. They did a vehicle comparison with in stock units, spoke to the local FTS.
    They hava a TAS case opened and DPR filled out.
    I was told by a Toyota shop foremand that the Tundra's had a similiar issue and it was an actual part failure and the noise was the beginning signs of a failure.
    With the Tacoma they claim the noise is considered part of the system function. If Toyota Motor Corp receives enough negative customer feedback they may redesign the system to minimize the noise, per shop foreman.
    Hopefully Toyota Motor Corp and your local Dealership will receive an abundant of these complaints to warrant a RECALL if your '13 has this issue please be pro-active.
    Fyi- I do not know what DPR, FTS or TAS abbreviation stand for.
  2. Jan 31, 2013 at 3:11 PM
    Large
    Large Red
    At least you posted some helpful info, most new users come here and bombard the forums with questions. You are not the only one having this issue though, there have been several threads with this already.
  3. Jan 31, 2013 at 3:22 PM
    B3AS7808
    B3AS7808 Well-Known Member
    San Diego, CA
    13 DCSB 4.0 4x4
    TRD S/C,URD 2.8 Stealth pulley, DTLT Headers,URD ypipe, URD rear O2 Sims, TRD catback, Powerstop rotors and pads, weathertech floor liners. RCD 4.5 lift. Nitto Trails 295/70R/17, KMC XD125's.
    Yeah this sound is normal on the 12's-13's with the redesigned emissions system.
  4. Jan 31, 2013 at 3:29 PM
    MGM Tacoma
    MGM Tacoma Well-Known Member
    Dunn NC
    13 DCSB MGM TRD OR
    I don't mind it I pretend its my blow off valve :) lol
  5. Jan 31, 2013 at 3:35 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    DPR: Dealer product report. The dealer submits out of the ordinary issues to corporate.
    FTS: Field Technical Specialist. These guys are sent from corporate to investigate special issues on vehicles that may be hard or impossible to figure out.
    TAS: I cannot remember the specific meaning, but it is the Technical Assistance hotline for Toyota and Lexus Techs that need help with an automotive related issue.
    IF the noise you are hearing is the smog air pump shutting down, it is not dangerous and will not be a recall. It does seem to be annoying to a lot of new Tacoma owners, so it could develop into a reflash procedure, and could turn into a TSIB, which is a technical service bulletin.
  6. Jan 31, 2013 at 3:44 PM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
  7. Oct 14, 2013 at 3:51 AM
    foreman
    foreman Member
    Bill
    Missouri
    2011 Toyota tacoma
    I also contacted Toyota and took it in to have it looked at and as usual they said it is normal. I owned a 2007-2011 Tacoma and no noise so it's something they did on the 2013 and I don't like it. Keep the complaints coming and hopfully they will figure it out!!
  8. Oct 14, 2013 at 4:19 AM
    Valsmere
    Valsmere Well-Known Member
    Brian
    New Jersey
    EXPENSIVE
    tail gate lock, rear view mirror bracket, hood hinge brackets, and the list grows.
    Mine has the same, freaked me out at first too
  9. Oct 14, 2013 at 5:56 AM
    smd3
    smd3 Well-Known Member
    Mine too, I'm not sure why everyone thinks modern cars shouldn't make any noises. It's pretty obviously an electric motor/blower sound, at least to me.
  10. Oct 14, 2013 at 6:05 AM
    craigb
    craigb Well-Known Member
    Craig
    Pa
    2013 TRD Sport
    Leer Cap Bilstein Shocks under bed lighting all weather mats window rain guards bed mat
    My 2013 also does it, before I bought it the salesman pointed it out. Said it was normal on 2013.
  11. Oct 14, 2013 at 7:46 AM
    Foxone
    Foxone Well-Known Member
    My '12 only does it if the engine is only ran for a minute or two, like backing out of the garage or something, never after full warm up.
  12. Oct 14, 2013 at 7:48 AM
    InSight Retrofits
    InSight Retrofits Closed
    Mine makes a noise after shutting off, sounds like it comes from the air tube to the fender.
    Basically it's how you can hear a cold air intake sucking air in, its basically just blowing it back out once you kill the engine and it stops sucking
  13. Oct 14, 2013 at 7:49 AM
    fenderpicks
    fenderpicks Well-Known Member
    I hear it all the time, after I turn it off.
    I just thought it is some sort of air system, never bothered me. Figured it is normal since it happened since day 1
  14. Oct 14, 2013 at 7:52 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Mine does it after I turn it off. It also cycles the fuel pump (or some thing else under the truck) at random times throughout the night and day when parked. Couldn't figure out what was humming in the garage, finally isolated it to underside of truck.
  15. Oct 14, 2013 at 8:55 AM
    GoHuskers
    GoHuskers Well-Known Member
    Nebraska
    2012 White DCLB TRD Sport
    My '12 does EXACTLY like that. If yours is similar then it's normal.
