Recently lifted and clunking on left u turns!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Venomns, Jul 22, 2010.
  1. Jul 22, 2010 at 5:31 PM
    Venomns
    Venomns [OP] Active Member
    nevada
    08 silver sport 4x4
    3" Toytec Ultimate Kit with AAL's
    "SOLVED"
    My stock tires inside wheel weights were hitting the sway bar. problem solved! thanks for the help
    ps... as soon as I solved that not it clanks when I hit the brakes the first time I touch them in forward or reverse... search button here I come! hahaha
    Hey guys,
    First off.. this site is invaluable! thanks for all the reads.
    Now, I installed my Toytec 3" Ultimate lift and noticed on Hard left uturns, I get a clunking sound. I have a 2008 4x4 access cab with the stock tires still on it and the diff drop. Either slow or fast. Almost a double clunk. And it goes with the rotation of the wheel, at exactly the same spot in forward or reverse.
    I took it and got it aligned and it is still there. I tried having someone turn it while I was underneath it but I couldn't see anything binding or clunking. It sounds like it coming from the drivers side.
    I guess I could just not do that hard of a turn but what fun is that!? :)
    Anyone else experience this problem?!
  2. Jul 22, 2010 at 5:33 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    What size tires are you running? Might be your tires rubbing your cab mounts. Grind them off and you will be good if that's the case.
  3. Jul 22, 2010 at 5:39 PM
    Venomns
    nevada
    08 silver sport 4x4
    No... Checked that the tire clearance and its good since im still stock. waiting for my 285s to be mounted on my new rims. It happens in the same spot when I turn and the wheels are turning. sounds like something in the driveline!?
  4. Jul 22, 2010 at 5:48 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    It could be your Steering Column that's causing the clunk.
  5. Jul 22, 2010 at 5:59 PM
    streetdriven
    streetdriven Tampa OG
    Rich
    Tampa Bay
    07 TRD Tacoma
    2007 Speedway Blue double cab. Trd skid,6k hids,thule racks,grill,N-fab,fj wheels 285/75/16's
    Mine does it at full turn too I just live with it. same 3" lift too
  6. Jul 22, 2010 at 6:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You shouldnt have any clunking. Re check the torque on all the bolts you touched when installing the lift.
  7. Jul 22, 2010 at 6:16 PM
    Venomns
    nevada
    08 silver sport 4x4
    ya, I definately won't be able to live with it. lol just when I turn left hard too. It is LOUD. I might try to fab up a bump stop if I can't cure it
  8. Jul 22, 2010 at 6:38 PM
    Venomns
    nevada
    08 silver sport 4x4
    Hey chris,
    I will do that again tomorrow. I am sure I hit every bolt before I threw the tires back on but why not, right?!
    if I crank the wheel though It clunks every time at a certain point in the rotation of the tire. That is why i am thinking it is something with the front drivetrain and only on a hard left turn.... not a right turn.
    :confused:
  9. Jul 22, 2010 at 6:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could be the ball joint, LCA, any number of things. Best ot make sure all is tight first.
  10. Jul 22, 2010 at 6:45 PM
    jeremy.allen
    jeremy.allen Well-Known Member
    Jeremy
    The Ville, Ky
    07 DC, OR
    3" Lift with OME 885's, 5100's front and rear, alcan add-a-leaf. Banks Monster Exhaust, on the way: MM951C 17X9 and 285 MT/R's...
    It could be the extreme angles of the cv axels when you are at full lock. I know that cv joints dont bind as much as traditional u-joints, butthey have their limits too. Just a thought, I have neve had this problem.
  11. Jul 22, 2010 at 6:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ture. If you lifted over 3".
  12. Jul 22, 2010 at 7:00 PM
    vicstacoma
    vicstacoma Guest
    It could also be the backing plate rubbing on the rotor. That happened to me and it would only make that noise while making a left turn. I just pushed the backing plate back a bit and it all went away. But yeah it could be so many things, you just have to get under your truck and look for something that doesn't look right. good luck.
  13. Jul 22, 2010 at 7:03 PM
    Venomns
    nevada
    08 silver sport 4x4
    Thanks guys.... Ill dive under there again tomorrow. Hopefully its something simple I kept it at the pre-set 2 1/2 for the toytec ULK
  14. Jul 22, 2010 at 7:07 PM
    Sleepzombie
    Sleepzombie New Member
    PA
    2019 Toyota Tacoma DBL Cab Limited
    I have something similar goin on with my 2006 Tacoma TRD 4x4 DBL Cab V6 Auto. Its all stock. Bought it used about a year ago. Recently started hear a more aggressive clunking sound from under front end. It is common to hear as I back out of garage making left turn. Driveway has slight downhill grade as I turn around. Sound happens about mid way through turn. Sometimes will hear same clunk when leaving a parking spot with similar uneven ground. I took a look at everything underneath. Found that when I grabbed the front driver's side drive shaft yoke by the front transfer case (drive shaft between driver's side tire and transfer case), I was able to rock the yoke back & forth a great deal more than the passenger side. Not in and out as it would slide, but as to wobble around like the splines are sloppy. Has anyone found the same? Know if this is culprit?
