Recommend me a reman caliper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Apr 9, 2018.
  1. Apr 9, 2018 at 6:06 PM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    See title.
    I went with some reman caliper from partsource and it seized after 14 months. Who makes the best remanufactured calipers? I'm currently looking at the raybestos zinc coated ones. I'm in Canada so there's penguins and polar bears and igloos and shit so they use caribou and moose to salt the roads.
    Drainbung, Canadian Joe and tacoma16 like this.
  2. Apr 9, 2018 at 6:46 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
  3. Apr 9, 2018 at 7:01 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Subd as well. Was going to go with ones from Toyota parts direct. $400cnd compared to 575-600 at the dealer (Per side :annoyed:)
  4. Apr 9, 2018 at 7:05 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Fuck! I was hoping you would have an answer..... You always have an answer...
  5. Apr 9, 2018 at 7:06 PM
    Bishop84
    Bishop84 Well-Known Member
    It's hit and miss with calipers, I've seen cheap ones rust instantly and I've seen expensive ones seized from the parts store.
    I'm not a huge fan of Raybestos brake pads, but that caliper looks decent. Lately I've been leaning towards the black coated calipers for their anti-corrosion so they don't rust instantly.
  6. Apr 9, 2018 at 7:11 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    The raybestos ones I'm referring to are electro zinc plated. You can grab any remanufactured part and rattle can spray it. To zinc plate you would need to do it with a fully disassembled cast. I even saw a powder coated set available but I would imagine zinc plated would last the longest.
  7. Apr 9, 2018 at 7:24 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    If your changing your calipers you may want to take a look here https://www.tacomaworld.com/threads...unner-bbk-upgrade-for-2nd-gen-tacomas.504234/
    Can get a bbk just by swapping to 4runner calipers,rotors and pads.
    I have been on the hunt but after reading I may just go oem for the reliability. Got almost 200k on my stock ones.
  8. Apr 9, 2018 at 7:30 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I've looked at that same thread countless times. Always said to my self that when the time comes I'd go for that kit. Time came and money dictates otherwise. I may go oem also. Still would like input if anyone knows of anything worth while. What's frustrating is that remanufactured is oem, just rebuilt. If we can find someone that can rebuild to actual oem standards we could get some actual life out of them. My originals lasted 155k.
    tacoma16[QUOTED] likes this.
  9. Apr 9, 2018 at 7:32 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Subd to hear some input. More moneys saved means more money to spend elsewhere....
    Thyces[QUOTED][OP] likes this.
  10. Apr 9, 2018 at 7:32 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Would it be douchebaggery to qoute myself in my Sig...
    tacoma16 likes this.
  11. Apr 9, 2018 at 7:35 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Too late....
    tacoma16 and Manfred like this.
  12. Apr 9, 2018 at 7:37 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    dont have much of an opinion. never really had issues with this, BUT am interested to see what you end up with
  13. Apr 9, 2018 at 7:38 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Eclipse makes some damn nice reman calipers. Stay away from cardone.
    tacoma16, Manfred and Thyces[OP] like this.
  14. Apr 9, 2018 at 7:38 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Fuck. Really? How many km on you current calipers?
  15. Apr 9, 2018 at 7:39 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Explain what seized.
    Usually when a piston seizes due to rust it is because the boot ripped or tore and then you have exposed metal. Did you coat the piston with caliper grease and then reinstall the boot?
    Without knowing what exactly failed or how it is hard to blame the part vs the person who installed it or didn’t properly maintain it.
  16. Apr 9, 2018 at 7:40 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thats the piece of shit I got from partsource... Cardone motherfucking cock suckling.....
    Bebop[QUOTED] likes this.
  17. Apr 9, 2018 at 7:41 PM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    I wanna say they're original... so 192 xxx lol.
    maybe i should be checking these.... haha
  18. Apr 9, 2018 at 7:41 PM
    Bebop
    Nick
    Try the Napa total eclipse calipers. I use them all the time on my customers vehicles and have yet to have one fail. Cardone is garbage. All they do is spray paint the cores they get and put them back on the shelf
  19. Apr 9, 2018 at 7:43 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I've never removed the boot to lubricate. My understanding was to replace the caliper, grease all moving parts (slide pin, back of pad inside piston ring, ect) is it necessary to remove the boot and grease the piston?
  20. Apr 9, 2018 at 7:45 PM
    Bebop
    Nick
    No. But if the boot is ripped that is what allows for corrosion to grow. I would chock it up to shitty cardone calipers before an installation error.
    tacoma16 and Thyces[QUOTED][OP] like this.
