recommendations for 60k mile service? first solid milestone for me...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hamNswiss on rye, May 11, 2011.
  1. May 11, 2011 at 2:47 AM
    hamNswiss on rye
    hamNswiss on rye [OP] ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    I purchased my 07 4x4 base model AC in late December of 2010 and am about to roll over to 60k miles. I recently replaced the air filter and have had two oil changes and a tire rotation since then, i.e. basic maintenance. Because I bought the truck used at 51k miles, I'm not sure what big services have been done to it. What i'm wondering is what would you guys recommend for my 60k mile service (or should i wait until like 75k?). I've done a bit of research, and the list below is what i seem to be coming up with. thoughts? should i be inspecting/changing anything else?
    Also, i bought my truck as a CERTIFIED used vehicle. Does the fact that it was supposedly well taken care of when i bought it change any of this? would toyota have done any of these services already in its certification?
    thanks
    -Replace cabin air filter
    -Replace spark plugs
    -Re-torque propeller shaft bolt (?)
    -lube propeller shaft (4WD)
    -Replace front differential oil (4WD)
    -Replace transfer case oil (4WD)
    -Replace rear differential oil, including limited-slip
    -Replace automatic transmission fluid
  2. May 11, 2011 at 3:20 AM
    RCBS
    RCBS How long you willing to tolerate this crap??
    Harden your bark, there are storms on the horizon.
    Goodbye 06, Hello 21. TRDORDCSBMT
    Tornado intake, Duralube, Fartcan.
  3. May 11, 2011 at 5:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  4. May 12, 2011 at 10:35 AM
    NormInOakley
    NormInOakley New Member
    California Delta
    stock PreRunner
    None
  5. May 12, 2011 at 10:44 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    You do not need to replace the auto trans fluid until 100k. The new transmission design requires an elaborate (and expensive) process for changing the fluid. Only if you regularly tow with your vehicle, or otherwise subject it to heavy-duty purposes, does Toyota recommend doing this at 60k.
    Also, TW already has a couple good threads going on this already: read this
  6. May 12, 2011 at 10:50 AM
    Pugga
    Massachusetts
    I understand it's a sealed unit, but how is it any harder to change the transmission fluid? It's a bit harder to get to the filter but how is the process any different than any other automatic transmission?:confused:
  7. May 12, 2011 at 11:27 AM
    mountainwolfpup
    Vancouver, WA
    It looks pretty complex to me, beyond my DIY skills anyway.
    1) You need to use a "special" WS fluid, supposedly only available at your Toyota dealer.
    2) The drain and fill procedure is involved, including preheating the fluid to a certain temperature.
    This external blog/thread explains it somewhat... read this
    Nice Youtube how to on it: view
    So, I am not saying you couldn't do it yourself, and certainly you could find a shop that could do it besides a dealer.
    Now that's just a fluid change. But what about a transmission flush, that is the recommended service? Need a machine for that. read this
  8. May 14, 2011 at 4:17 PM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
    thanks for all the help guys! ill probably bag the trans fluid for now, and look into those links. any other advice?
  9. May 14, 2011 at 9:26 PM
    jeepmor
    jeepmor Well-Known Member
    Stumptown
    Nice to know.
  10. Jun 14, 2011 at 12:08 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I'm almost at 60k on my 08.
    In addition - Also going to look for...
    Rear axle seal leaks
    Timing chaing chain leaks
    Basically power wash the undercarriage and then crawl around and look for residue that looks like it could be a leak
  11. Aug 18, 2011 at 1:59 PM
    airsoft_warrior
    airsoft_warrior Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    Just got to 63k. Was pricing Transmission changes but if I dont need one til 100k then heck I will wait. I will need brakes soon and a new cabin filter (thats never been replaced) the front and rear diffs have never been changed. belts are squeaking under the hood. I guess I should take it in to the dealer for something.
