Recommendations for a Bit More Rear Lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by socal4x, Mar 5, 2011.
  1. Mar 5, 2011 at 10:37 AM
    socal4x
    socal4x [OP] Well-Known Member
    CA
    '16 MGM DCSB OR 4x4 6MT
    Double Cab, Short Bed, 4x4, Billys up front at 1.75 with Trd Sport coils, billy 5100s w/ toyota tsb rear leafs. About 6k miles on the lift/springs.
    I had a shell on when I lifted the truck, but the rear has settled a bit more than the front, so now I am ass low about 1/4 to 1/2 inch, which gets worse, of course, when I load up the bed, even w just a bit of weight.
    I'd like it to be closer to level, and I don't want to do blocks, does anybody have any recommendations? AAL?, or shitcan the tsb leaf and put in a lift?
    Thanks!
  2. Mar 5, 2011 at 10:40 AM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    Just get a rear leaf pack and be done. All pro, alcan, deaver ...
  3. Mar 5, 2011 at 10:41 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    1.5" aal
  4. Mar 5, 2011 at 10:51 AM
    Special_K
    Special_K o_o
    Eddie
    Alexandria, VA
    2019 Tacoma Cav Blue
  5. Mar 5, 2011 at 11:09 AM
    socal4x
    CA
    1.5" aal and remove the tsb leaf? otherwise the lift is too much
    How much lift would I get from the shackle flip?
    Heres a pic w/ stock tires.
  6. Mar 5, 2011 at 11:13 AM
    Special_K
    Special_K o_o
    Eddie
    Alexandria, VA
    Their site says 0.5 inches but it sounds like you can get it custom to the height you like. I'm not sure what the limits are.
  7. Mar 5, 2011 at 3:24 PM
    socal4x
    CA
    I guess I can contact them...sounds like it may be the way to go.
    I was also considering the toytec leaf, they have a tsb and non-tsb kit, I'm confused if the tsb kit replaces the tsb spring, or is just a lesser lift aal.
  8. Mar 5, 2011 at 3:53 PM
    nrm
    nrm Well-Known Member
    NC
    2011 4.0 DCSB TRD Off-Road
    4-leaf TSB and Eibach 620 coils with Bilstein 5100's set to 0". AFE intake and Gibson cat-back exhaust. Bestop canvas topper
    Well this has just made up my mind about what setting to go with on my 5100's. I had the TSB done a couple months ago and gonna install the 5100's up front tonight. Going .85"
  9. Mar 5, 2011 at 7:30 PM
    Special_K
    Special_K o_o
    Eddie
    Alexandria, VA
    just heard back from ATO regarding the shackle flip kits for those interested...they are pretty close now and are testing a few kits so they should be available soon
    I can't really quantify that so....yeah....
    hopefully the kit price remains the same, around $100. much less than a new leaf pack if you're not looking to add a ton of lift
  10. Mar 8, 2011 at 9:17 AM
    socal4x
    CA
    If I didn't have the shell on it would be level at 1.75".
  11. Mar 8, 2011 at 9:18 AM
    socal4x
    CA
    I just got an email back from them, they are still testing them out, and should be ready soon.
  12. Mar 8, 2011 at 10:08 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I believe the two springs sets are just arched differently to acheive the same total amount of lift whether you have the TSB or non-TSB springs .
  13. Mar 8, 2011 at 10:13 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Your right. I think the non-TSB has a higher arch so will give a slight higher lift but will be too stiff for TSB springs. I just remember another member mentioned one time about needing to do some cutting to make it work.
