Recommendations for portable tire inflator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaboDawgs, Aug 18, 2020.
  1. Jun 28, 2021 at 10:39 AM
    #61
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Nothing corrosive in cave water. Same stuff people drink. I seldom even rinse my gear afterward.
    Al scuba tanks float when empty. Steel tanks are neutral or a few pounds negative when empty. With a drysuit, steel tanks eliminate the need to wear lead weights.
    Out of the water Al 80 tank only weights about a lb less than a steel 100.
    EatSleepTacos[QUOTED] likes this.
  2. Jun 28, 2021 at 1:48 PM
    #62
    Otto-x
    Otto-x Well-Known Member
    Seattle, WA
    2021 Cement DCLB OR
  3. Jun 28, 2021 at 2:01 PM
    #63
    Dads97Taco
    Dads97Taco Well-Known Member
    Ooltewah, Tn
    1997 straight cab Tacoma, 4WD, stock with roller windows
    Factory upgraded am/fm radio with cassette
  4. Jun 28, 2021 at 2:08 PM
    #64
    dagobert
    dagobert Well-Known Member
    A tank is a tank is a tank....now the one from Power Tank do come in pretty colours and with a nice mounting bracket. The real benefit is the regulator and valve from power tank. Works for both CO2 and Nitrogen, won't freeze, max 250 psi and flows 45 CFM which more than enough to run air tools (most require 35-40CFM). Wont find that at your local welding shop/brewing supply house.
    EatSleepTacos likes this.
  5. Jun 29, 2021 at 8:01 AM
    #65
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    I like the size of the Milwaukee and Makita ones. Much more compact than the Dewalt, which is almost the same size as some of their smaller jobsite radios.
  6. Jul 7, 2021 at 3:28 PM
    #66
    P4NDEMONIUM
    P4NDEMONIUM Well-Known Member
    Adam
    2019 TRD Off-Road
    I used a ni-cad Porter Cable set until I was 21 or so, and was lucky enough to move in with someone who was split across Milwaukee and Dewalt, and knew what they were doing.
    I almost opted for DeWalt, knowing I wanted an inflator and was more attracted to the auxiliary tools. I like the low pressure option DeWalt has, but there are cheap tools that run on 9v batteries that will do the same thing. Milwaukee, the 12v line especially, won me over for power-to-weight and portability, as well as their large selection of auxiliary items compared to DeWalt
  7. Jul 7, 2021 at 6:09 PM
    #67
    amudie
    amudie Veteran Member
    Andrew
    Pennsylvania
    2018 Tacoma TRD-OR DCLB
    AluCab Canopy SSO Slimline Hybrid Bumper w/ 10k winch and 20" Hiese light bar.
    If you aren't in a hurry to inflate...the DeWalt one is a great budget option.
  8. Jul 8, 2021 at 7:43 AM
    #68
    RETR0spec
    RETR0spec Well-Known Member
    Sacramento, CA
    JDFab +4 LT
    I brought this on the trail once.
    I was aired down to ~15psi and it took an unbearable amount of time to reach 25psi on a 33” tire.
    I dont recommend it.
    ORtoCOTaco likes this.
  9. Jul 8, 2021 at 7:44 AM
    #69
    P4NDEMONIUM
    Adam
    2019 TRD Off-Road
    All of the 12v inflators are pretty slow. There's a runtime limit on the milwaukee one I have, but the portability is nice.
    There are tankless under-hood mounts that I think would do a much faster job
  10. Jul 8, 2021 at 7:59 AM
    #70
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
    I have the same one but I just looked up the SCFM and it's only 0.5 the Viair one the others recommend for around $160 is 2.4 SCFM... so that should inflate almost 5 times faster. It did take me a fair bit to inflate 4 tires from 19psi to 34psi with the dewalt.
    Just saw the viair 88p seems like a good deal 3x the inflation speed and cheaper than my dewalt. Might just sell mine and buy that.
    tonered likes this.
  11. Jul 8, 2021 at 8:17 AM
    #71
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I do very much like my Viair, but to be perfectly honest, the air chuck that comes with it is a pain to use. It does let air flow through when not connected to a valve. If you swap the air chuck for a nice, common air tool one, you need to be able to shut off the Viair when not connected.
    So, my recommendation is to either get an automatic version, like the 400P Automatic, or make a pressure switch and relay setup like I did with my 300P. It was fun to do:
    https://www.tacomaworld.com/threads/viair-automatic-mod-vam.680478/
    There are many others ways to mod it for power control.
    All of that leads into DIY'ing an inexpensive multi-tire inflator:
    https://www.tacomaworld.com/threads/shellshocks-diy-inflator-deflator.613122/
    :sorry:
  12. Jul 8, 2021 at 9:18 AM
    #72
    Crosbaugh
    Crosbaugh Well-Known Member
  13. Aug 6, 2021 at 1:46 PM
    #73
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Had my portable tire inflator fail and came across this thread in researching a replacement. Seems like the better quality products like Viair all hook up to the battery only for power, or perhaps cigarette lighter as well. Is there not a high quality product that can use either a standard 120vac plug or connect to a vehicle battery? If I’m filling up family bike tires or the boat trailer, it’s really inconvenient to be limited to a battery.
  14. Aug 4, 2022 at 3:14 PM
    #74
    Stagger Lee
    Stagger Lee Well-Known Member
    NorCal
    2015 Tacoma TRD OR 4x4 6spd
    Thinking about grabbing the Milwaukee M18 Tire Inflator. Anyone else using this one?
    https://www.milwaukeetool.com/Products/Power-Tools/Plumbing-Installation/2848-20
    The only consistent bad reviews are that the pressure gauge is a little questionable at low psi. Other than that, supposed to be really efficient.
    Im pretty well invested in the Milwaukee tool environment so it makes sense, but just wondering if I should get something else.
  15. Aug 4, 2022 at 3:18 PM
    #75
    Toyko Joe
    Toyko Joe Here for the pictures
    come into the dark side... https://www.tacomaworld.com/threads/milwaukee-tools.667467/ I think the consensus is that it is not really worth the money IIRC.
  16. Aug 4, 2022 at 3:24 PM
    #76
    Stagger Lee
    NorCal
    Thanks Joe! Checked that thread and there seems to mainly be info on the M12. I’ll keep digging for more on the M18 in there.
  17. Aug 4, 2022 at 3:40 PM
    #77
    Toyko Joe
    start here
    Stagger Lee[QUOTED] likes this.
